Missing IP numbers..
PymbleSoftware
Unread postby PymbleSoftware » Fri Mar 05, 2010 1:00 am
I put this wiki article together mostly from the hinv section of nekochan...
http://www.nekochan.net/wiki/ ... stem_names)
I got to wondering .. What happened to IP1, IP2, IP3, IP4, IP5, IP8, IP11, etc.... ???
死の神はりんごだけ食べる
開いた括弧は必ず閉じる -- あるプログラマー
Twitter @PymbleSoftware
Re: Missing IP numbers..
Unread postby jan-jaap » Fri Mar 05, 2010 1:05 am
Several of the IP numbers you mention did exist: http://old.sgistuff.net/hardware/tables.php#ip
The rest probably never made it to a real product. Which makes you wonder what happened between IP35 (Fuel) and IP53 (Tezro).
PymbleSoftware
Unread postby PymbleSoftware » Fri Mar 05, 2010 1:09 am
jan-jaap wrote:Several of the IP numbers you mention did exist: http://old.sgistuff.net/hardware/tables.php#ip
Thanks for the link.
I guess we will never know what the missing ones might have been if they had been released..
That thing with the SW/HW IPs had confused me a little. If someone wants to clean up the table and fill in the blanks..
死の神はりんごだけ食べる
Unread postby foetz » Fri Mar 05, 2010 5:47 pm
jan-jaap wrote:Which makes you wonder what happened between IP35 (Fuel) and IP53 (Tezro).
could be just a joke. 35 <-> 53
zuluchas
Unread postby zuluchas » Fri Mar 05, 2010 7:57 pm
PymbleSoftware wrote:I put this wiki article together mostly from the hinv section of nekochan...
"http://www.nekochan.net/wiki/IP_Numbers(Module_and_system_names)"
Nice work. I've updated it some. Feel free to join in, all -- the water's warm! :)
:A350R: :Onyx2: :4D220VGX: :Indigo: :Octane2: :O2: :Indigo2IMP: :O3x0: :Indy:
PymbleSoftware
Unread postby PymbleSoftware » Sat Mar 06, 2010 3:21 am
I have messed with the wiki topic a little, I hope that is it an improvement..
I noticed something...
For a certain range of time, even numbered machines are always "lower-end of the era", ie workstations as apposed to servers, which explains some of the gaps at least. Some missing odd numbers are times when they designed more workstations than servers.
死の神はりんごだけ食べる
miod
Unread postby miod » Tue Mar 09, 2010 12:23 am
Maybe. But then it got lost when the 1GHz R16000 Tezro were introduced, as these are IP59...
Unread postby josehill » Tue Mar 09, 2010 9:32 am
miod wrote:Maybe. But then it got lost when the 1GHz R16000 Tezro were introduced, as these are IP59...
By then, the Keepers of the Olde Wayes had long departed the building. Those who followed had incomplete knowledge of the Legends.
Unread postby foetz » Tue Mar 09, 2010 9:37 am
hehe, could indeed be true :D
Oskar45
Unread postby Oskar45 » Wed Mar 24, 2010 7:31 am
Just wanted to check it now but got only
There is currently no text in this page.
Anyway, this might have been already noted there but the "Hardware Developer Handbook, Release 2.0" gives "HP1" as processor ID for the Indigo, not IP12 [as per Gerhard's beautiful page] - but maybe it's a typo?
Honorable member of the International Procrastinator's Society
emgaron
Unread postby emgaron » Wed Mar 24, 2010 7:59 am
Yup, that's due to the last ')' missing from the URL when clicking on it in the text. Add a ')' to it in your browser's address line and you'll get there - or try this: http://www.nekochan.net/wiki/index.php/IP_Numbers(Module_and_system_names). Apparently, URLs with brackets don't quite work without the 'url' tags.
Hooked up: :Octane: [R12k/400, V6] :Indigo2IMP: [R10k/195, HI] :Indy: [R5k/180, XL24] :Indy: [R5k/150, -];
Sun U60/2x450, U10/440, U2/2x200, AXi/440; some PCs
In storage: :O2: [R10k/195] :O2: [R10k/150] :Indigo2IMP: [R4k4/250, SI]; DEC VX40;
Sun SS1/1+/2/4/5/10/20/ELC/IPC/IPX/Classic/LX/Classic X/Xterminal 1, U1/1E/5/30, JS1/NC;
DTK Station U-2/2x360; Apple iMac DV G3/400; Toshiba Libretto 110CT + even more PCs
Oskar45
Unread postby Oskar45 » Wed Mar 24, 2010 9:31 am
Thanks, it worked. My above comment regarding Indigo's hardware IP seems to be still valid, though...
Unread postby jan-jaap » Wed Mar 24, 2010 12:47 pm
Oskar45 wrote:My above comment regarding Indigo's hardware IP seems to be still valid, though...
Had a look at an R3000 mainboard and it says "HP1 assy xxx-xxxx-xxx". But I know for a fact IRIX calls it IP12.
The codename for the Indigo was 'Hollywood', maybe that has something to do with it?
Unread postby SAQ » Wed Mar 24, 2010 3:18 pm
HP1 -> Indigo R3000 (IP12)
HP2 -> Indigo R4000 (IP20).
HP1 is all the major components of an IP12 (PI 4D/3x) (minus VME interface) in a different layout. HP2/IP20 has no siblings. I think the only reason that they kept the "HP" number was for historical reasons. HP1 was the first time that they "rearranged" a system board, so perhaps that's the reason they did the different naming. Later (Indy) they gave it a different IP number (essential components of an IP22, but labeled IP24).
Return to “SGI: Discussion”
