ANNOUNCE: pjcap for O2
kshcsuf
Unread postby kshcsuf » Sat Jan 16, 2010 10:35 pm
Hi all,
I've put together an uncompressed YUV 4:2:2 capture app intended for use on O2 hardware with older/slower drives. I am currently able to obtain a real-time 640x480 YUV 4:2:2 uncompressed stream with a single disk. This tool outputs raw video in a format that can easily be transcoded with a compression farm using mencoder/ffmpeg. My goals include adding OpenDML AVI support for both uncompressed and ICE (MJPEG) compressed video with audio support, and will eventually support Octane Personal Video/Octane Compression when I can find them available on Ebay. I use the latest capture techniques such as Direct I/O, VL buffer advising and high priority process scheduling (thank you Chris Pirazzi!).
The very first version can be downloaded here: http://philj.us/pjcap.tar.gz
It will be made available via GPL as soon as I have some additional support implemented.
Please let me know what you think. Thanks!
BTW: you can easily deinterlace and transcode to MPEG-4 using mencoder with:
mencoder -demuxer rawvideo -rawvideo format=uyvy:w=640:h=480:fps=29.97 -lavcopts vbitrate=2000000:vhq:v4mv -vf pp=md -o test.avi -ovc lavc testfile.yuv
You can play the video with:
mplayer -demuxer rawvideo -rawvideo format=uyvy:w=640:h=480:fps=29.97 testfile.yuv
tomo
Re: ANNOUNCE: pjcap for O2
Unread postby tomo » Sun Jan 17, 2010 12:46 am
I will test it as soon as I can get to camera witch means tuesday.
Nice to see that somebody is programing on old O2/ ICE.
http://www.tomosgi.co.cc
Unread postby hamei » Sun Jan 17, 2010 5:58 am
kshcsuf wrote:Hi all,
Thanks very much !
jirka
Unread postby jirka » Sun Jan 17, 2010 12:53 pm
Many thanks! (but I have to find a camera first...)
kshcsuf
Unread postby kshcsuf » Sat Jan 23, 2010 1:48 pm
Hi guys,
Just a brief update. The latest version has camera/CCIR601 capture support (and is available at the above URL). I don't have an O2 camera; would you guys mind giving it a whirl and letting me know if you can capture successfully?
Thanks!
jdboyd
Unread postby jdboyd » Mon Jan 25, 2010 1:35 pm
What about 720x480 or 720x486 video?
jirka
Unread postby jirka » Tue Jan 26, 2010 12:35 am
kshcsuf wrote:Hi guys,
Hello and sorry for the delay.
Many thanks for the app.
I tried it with my O2cam (with the -o switch) and it captures something (I used the yuv file). But Mplayer refuses to play the saved file. Is it a normal behaviour?
tomo
Unread postby tomo » Tue Jan 26, 2010 3:30 am
Hi on my machine everything works fine.
I'v captured video sequence trough
smetiacik 3# ./pjcap -o -f /tmp/pokus2.yuv
PJCap
Copyright (c) 2010 by Phil Jensen (kshcsuf@gmail.com)
All rights reserved.
Capturing 500 frames.
Capturing from camera port.
Enabled a high process priority for video capture.
Capturing NTSC square pixels (640x480).
Capturing uncompressed YUV 4:2:2 (16-bit) video.
Optimizations enabled.
Capturing to /tmp/pokus2.yuv using Direct I/O.
Opening AVI file.
Beginning capture: ............................F.F.F.F..F.F..F..F..F.F..FF.F.F..F..F.F.F..F.F..FF..F.F..F..F.F..F.F..F.F.F.F..F.F..F..F.F..F.FF..F.F..F.F..F.F..F..F.FF..F..F.F..F.F..F..FF.FF.F.F.F.F.F.F.F.F.F.F.F.F.FF.F.F.F.F.F.F.F.F.FF.F.F.F.FF.F.F.F.F.FF.F.F.F.F.F.F.FFF.F.F.F.F.F.F.F.F.F.F.F.F.FFF.F.F.F.F.F.FFF.F.F.F.F.F.FFFFFFFF.F..F.F.F.F.F.F.F.F.FFF.F.F.F.F.F..F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.F.FFF.F.F.F.F..F.F.F.F.F.F.F.FFF.F.F.FF.F.F.FF.F.F.F.FF.F.FFF.F.F.F.FF.F.F.F.FFFF.F.F.F.FF.F.F.F.F.FF.F.F.F.FF.F.
500 frames captured in 25.43 seconds. (19.67 fps)
And played it trough
mplayer -demuxer rawvideo -rawvideo format=uyvy:w=640:h=480:fps=29.79 /tmp/pokus2.yuv
kshcsuf
Unread postby kshcsuf » Tue Jan 26, 2010 9:54 am
Thanks tomo!
I've been grinding away on getting AVI support added--I've got AVI1 support now with traditional indexes. I'm firming up multiple colorspace support (RGB32 and UYVY), and want to get OpenDML indexes successfully written this week. I've got an Octane Personal Video board on the way this week and would like to get Octane support added as well.
(I'll push the new build up to my webserver this morning.) I had to turn off Direct I/O support to write out AVIs, and am looking at ways to re-enable the functionality.
tomo
Unread postby tomo » Tue Jan 26, 2010 10:54 am
Nice - keep on coding :)
jirka
Unread postby jirka » Tue Jan 26, 2010 10:59 am
Hello,
now I can confirm that it works great on my O2 (it's R10k/250).
Output is the same as Tomo's but without these ...F.F.Fs (only with .....).
Many thanks and best regards.
mashek
Unread postby mashek » Tue Feb 09, 2010 9:58 am
What do the F's mean? And the dots?
sales calls & paid consulting only: 865-357-6274
mailto:doug@mashek.com
Mashek Systems www: http://www.mashek.com
:320: :540: :1600SW: :O2: :O2+: :Indigo: :Octane: :Octane2: :Tezro: :Indigo2: :Indigo2IMP: :Indy: :Fuel: :PI: :O200: :Onyx: :ChallengeXL: :OnyxR: :O2000: :Onyx2: :O2000R: :O2000E: :O2000E: :O2000E: :metarouter: :O2000E: :O2000E: :O2000E: :O2000E: :Onyx2RE: :Onyx2RE: :Onyx2R: :Onyx2RE: :O3000: :O3000: :O3200: :0300: :0300: :0300: :0300:...
mapesdhs
Unread postby mapesdhs » Mon Feb 15, 2010 3:44 am
kshcsuf wrote:... I've got an Octane Personal Video board on the way this week and would like to get Octane support added as well. ...
If it works with Octane, will it also work with IMPACT Compression and IMPACT Video in Indigo2?
What would be especially cool is if it supported Cosmo1 and related video I/O.
Thanks for all the efforts!! Great to see O2 being properly exploited.
Ian.
mapesdhs@yahoo.com
+44 (0)7434 635 121
Sacrifist
Unread postby Sacrifist » Sun Mar 14, 2010 11:03 pm
Pardon the naiveté but what hardware is required for capturing with this app? I personally have a R10000 250 MHz O2 with an A/V module. Can it be used with stuff like a SDI dongle? At this stage I cannot test it at all as I had to throw out its hard drive (silicon heaven).
Simon
hazelden
Unread postby hazelden » Thu Jul 22, 2010 7:51 pm
Hi. I recently purchased a used SGI O2 and would love to try pjcap with it to capture high quality video. The link appears broken. Is there an active URL where I could download a copy?
Thanks,
Andrew Hazelden
Andrew Hazelden, VFX Artist
Personal Blog: www.AndrewHazelden.com
:O2: SGI O2, 195 MHz R10K, 320 MB ram, AV1 Video i/o card, 36GB HD
Return to “SGI: Video”
