SI 3D 3.9.2 Install and licensing
pentium
Unread postby pentium » Sat Dec 26, 2009 6:27 pm
Last time I was in vancouver I picked up a pile of mixed cd's (literally a dollar a dozen) and one of the discs was a (backup) copy of SoftImage 3D 3.9.2.
I got around to trying it out today and after a bit of work (it's pretty beat up) I got it to mount on my O2 however after starting the setup it became immediately clear it was not going to behave.
I can't setup the licensing stuff as I'm missing cdinst.dat.
Regardless, I tried running the actual software installer and it went fine presumably and now I have a new toolchest option marked "SOFTIMAGE Products" (is there a way I can shorten that so the toolchest is not stretched so much?) however the only thing that actually runs is the User Tools, Setup Help (though its missing the .htm file), Setup, and Dialog Editor. Everything else does a whole pile o nothing. I'm assuming this is because the software licensing is not setup correctly but I don't know.
Is there actually a way to fix my issues here or is it just better to remove the software and carry on using Blender/whatever else I can find?
Re: SI 3D 3.9.2 Install and licensing
Unread postby foetz » Sun Dec 27, 2009 2:40 pm
even if you could setup the lic stuff you'd still need a lic.
however i don't remember the contents of the cd but even if the dat is missing you should be able to extract the files.
pentium
Unread postby pentium » Sun Dec 27, 2009 2:54 pm
I might have a "temporary" one. I got a lot of text files. I think I saved it someplace.
Even so, where would a license file go? /var/flexlm and be merged with the existing license.dat file?
Unread postby foetz » Sun Dec 27, 2009 7:20 pm
it doesn't matter where the lic is located and you can't merge it because of the separate daemon line.
extract the si lic stuff somewhere, go there and execute
./lmgrd -c /path/to/your/lic
be sure that lic does contain si stuff only and the correct port and daemon
pentium
Unread postby pentium » Tue Dec 29, 2009 2:49 pm
Okay, did I miss something here?
Where did you get lmgrd from?
kshuff
Unread postby kshuff » Tue Dec 29, 2009 3:47 pm
"lmgrd" is the license manager daemon, "man lmgrd" for more info.
-ks
See them all >here<
pentium
Unread postby pentium » Tue Dec 29, 2009 8:26 pm
I don't think lmgrd is even installed. I can't even find a manual page for it.
Unread postby dexter1 » Wed Dec 30, 2009 12:25 am
lmgrd should be in the license-eoe software system or (use to be) downloadable from Globetrotter software: http://www.globes.com/support/fnp_utili ... wnload.htm
Unread postby foetz » Wed Dec 30, 2009 9:27 am
pentium wrote:Okay, did I miss something here?
it's part of the lic toools from si which you should be able to extract as i wrote above ...
pentium
Unread postby pentium » Wed Dec 30, 2009 5:29 pm
Unfortunately there are no eoe files on the disc. The installer is essentially just a graphical installation script that does not require swmgr at any time.
I think it's more like "I'm used to swmgr and now that I have to install something that does no use it, I have no idea what to do".
Unread postby SAQ » Wed Dec 30, 2009 6:48 pm
There are two licensing systems common on SGI: FlexLM and NetLS. Lmgrd is from FlexLM, which should be on your IRIX 6.5.x disks. Open up swmgr or inst and check to see if you can find the lmgrd file anywhere.
The Insight book on licensing might be helpful, too.
pentium
Unread postby pentium » Wed Dec 30, 2009 11:20 pm
If lmgrd is one of my irix discs, I'm going to need to know which one specifically as I'm not going to feed all my discs through the system again.
SiliconClassics
Unread postby SiliconClassics » Thu Dec 31, 2009 6:03 am
If you have a license file (say, "softimage.lic"), put it in /usr/Softimage/Soft3D_3.9.2 (assuming that's where you installed Soft) and then open ".softimage392" in that directory and scroll down to the "setenv LM_LICENSE_FILE" line. Add "$SI_LOCATION/softimage.lic" to that line, save the file, and you should be good to go.
Unread postby foetz » Thu Dec 31, 2009 6:35 am
ajerimez wrote:If you have a license file (say, "softimage.lic"), put it in /usr/Softimage/Soft3D_3.9.2 (assuming that's where you installed Soft) and then open ".softimage392" in that directory and scroll down to the "setenv LM_LICENSE_FILE" line. Add "$SI_LOCATION/softimage.lic" to that line, save the file, and you should be good to go.
he doesn't have the lic apps.
Unread postby recondas » Thu Dec 31, 2009 6:49 am
pentium wrote:If lmgrd is one of my irix discs, I'm going to need to know which one specifically as I'm not going to feed all my discs through the system again.
Might be quicker than another 10 page discussion. :D
Or you could try looking at the IRIX CD contents listing that *should* be on your hard drive. Try the following url into your browser:
  file:///var/www/htdocs/WhatsNew/install/cds_frame.html
<that's 6.5.30, if you have an older version of IRIX and it doesn't open, poke around in /var/www/htdocs/ >.
