chromawaves interactive demo
Martin Steen
Unread postby Martin Steen » Thu Oct 08, 2009 3:05 pm
Hello,
here is another little interactive OpenGL demo.
http://www.sgi.faktor0.de/chromawaves.tar.gz
Hit the space bar to create colorfull waves.
Move and zoom the field with the mouse.
Sourcecode with makefile for MipsPro-Compiler:
http://www.sgi.faktor0.de/chromawaves-source.tar.gz
This demo has more error-checking code than my other
programs, but, als always, start at your own risk.
Required libraries: GLUT library
http://de.mirror.nekoware.net/current/n ... 25.tardist
EDIT: Youtube video
http://www.youtube.com/watch?v=XnOzAVC7WZg
-Martin
indyman007
Re: chromawaves interactive demo
Unread postby indyman007 » Thu Oct 08, 2009 11:25 pm
Shame my octane gfx are screwed!!!
:Indy: R4600PC 133 MHz
Mac Mini 2.5GHz 8GB RAM
Raspberry Pi
Unread postby hamei » Fri Oct 09, 2009 6:50 am
Works nicely on the Fuel, V12 6.5.30 neko_glut. I'll try it on the O2 later.
I wonder if you could reverse the action of the scroll button ? It's backwards from the way zoom works on any other apps I have ...
You know what would be useless but neat ? Pipe the output from sound to act as input. i always liked that rotating drum equalizer demo thing. This is even spiffier.
thank you.
Martin Steen
Unread postby Martin Steen » Fri Oct 09, 2009 3:07 pm
hamei wrote:Works nicely on the Fuel, V12 6.5.30 neko_glut. I'll try it on the O2 later.
thank you.
Thank you for testing, hamei!
I take your tipps and suggestions into consideration.
Best regards,
Martin
P.S. I had to look up in an dictionary if "spiffier" means good or
bad, but I learned it means good :D
tomo
Unread postby tomo » Sat Oct 10, 2009 3:12 am
Little slow on O2 but what can someone expect? With -q1 it runs in decent speed. Sound input should be great.
http://www.tomosgi.co.cc
bplaa.yai
Unread postby bplaa.yai » Sat Oct 10, 2009 11:42 am
Thanks for the nice toy Martin !
Just tested it on the Onyx2 IR2E and the Onyx IP, works great on both. Just a note : it looks a bit dark (eg. I don't see anything until I hit space), I'm not sure if it's related to my gamma settings (I use gamma 1.0 on my sgis)...
:Onyx2: :O2: :O3x0: :O3x0:
Unread postby hamei » Sat Oct 10, 2009 7:29 pm
Martin Steen wrote:here is another little interactive OpenGL demo.
Whatever you are doing, Martin, you have found a guaranteed method for discovering the 350 mhz r5k bug :) Blows my O2 right off the planet, instantly. Maybe canavan can confirm ?
Interesting that it doesn't affect the 600 mhz O2 (per tomo's post). Is the problem in the cpu itself ? Maybe SGI wants to sue MIPS for damages, your appplication can be Exhibit A :D
ShadeOfBlue
Unread postby ShadeOfBlue » Sun Oct 11, 2009 5:16 am
hamei wrote:Is the problem in the cpu itself ?
I vaguely remember reading something about floating-point bugs in the 350MHz CPU's, which made them unsuitable for e.g. Maya. Since the O2 uses the main CPU for geometry transformations, it could be triggered by an OpenGL app.
Neat :)
Unread postby nekonoko » Sun Oct 11, 2009 8:42 am
ShadeOfBlue wrote:I vaguely remember reading something about floating-point bugs in the 350MHz CPU's, which made them unsuitable for e.g. Maya. Since the O2 uses the main CPU for geometry transformations, it could be triggered by an OpenGL app.
Right, that's why SGI recalled the RM7K/350MHz CPUs. Kind of interesting to see it pop up now though, and equally interesting that the faster RM7Ks aren't affected.
Edit: A little more info here: http://groups.google.com/group/comp.sys ... fecdf3e025
Looks like it was a RM7000A problem. The 600MHz hobbyist upgrades use the RM7000C.
Martin Steen
Unread postby Martin Steen » Mon Oct 12, 2009 3:36 pm
Both apps (Die Planeten, Chromawaves) make heavy use of trigonometric functions like sin() and cos().
I have sent hamei a test version of the demo program to proof it's not a software glitch. I' m still not sure
if it's a hardware bug. 99.999% of all bugs are software related (that's my experience, at least).
Best regards,
Martin
P.S. thank you very much for reporting about my programs on the start page!
Martin Steen
Unread postby Martin Steen » Mon Oct 12, 2009 4:16 pm
bplaa.yai wrote:Thanks for the nice toy Martin !
Run "./chromawaves -auto" if you want the see waves from the beginning.
Unread postby nekonoko » Tue Oct 13, 2009 7:05 am
Martin Steen wrote:P.S. thank you very much for reporting about my programs on the start page!
Glad to do it -- it's always great to see new IRIX stuff :)
Unread postby guardian452 » Mon Oct 19, 2009 7:14 pm
maybe it's just me.
I just installed neko_glut-3.7p25.tardist
chaos 4% ./chromawaves
 1383:./chromawaves: rld: Fatal Error: Cannot Successfully map soname 'libglut.s
o' under any of the filenames /usr/lib32/libglut.so:/usr/lib32/internal/libglut.
so:/lib32/libglut.so:/opt/lib32/libglut.so:/usr/lib32/libglut.so.1:/usr/lib32/in
ternal/libglut.so.1:/lib32/libglut.so.1:/opt/lib32/libglut.so.1:
running fixpath didn't fix it
I linked /usr/lib32/libglut.so to /usr/nekoware/lib/libglut.so which was probably a terrible idea, but I'm certainly no unix expert and it worked. It works great, actually. Maybe in the new version it can look for libglut.so in /usr/nekoware/lib/? or is it supposed to do that and my system is slightly fubared?
Unread postby guardian452 » Mon Oct 19, 2009 8:24 pm
Another nekochan member helped me via PM. It's a common problem, the environment variable LD_LIBRARY_PATH, mine was empty for some reason.
You learn something new every day when the lesson is beat into your brain :D
Martin Steen
Unread postby Martin Steen » Tue Oct 20, 2009 3:12 pm
sybrfreq wrote:Another nekochan member helped me via PM. It's a common problem, the environment variable LD_LIBRARY_PATH, mine was empty for some reason.
Nice to hear that it works now!
Although the use of LD_LIBRARY_PATH is controversial.
(Google for "LD_LIBRARY_PATH bad")
Best regards,
Martin
