Ayam 1.16
rschultz
Ayam 1.16
Unread postby rschultz » Wed Sep 23, 2009 12:51 am
Greetings,
with the help of the kind people in this forum, I am able
to offer Ayam1.16 as official IRIX (MIPS3/N32) executable
again.
As the web pages are not updated yet, the only download
location is currently:
https://sourceforge.net/projects/ayam/files/
Note that this time a working Rhino 3DM import/export
plugin is included!
Unfortunately, I was not able to fully compile libsnurbs
(http://www.cl.cam.ac.uk/~tc270/subdnurbs.html)
for the sdnpatch plugin, so there are no Subdivision
NURBS on IRIX yet.
kind regards,
Randolf
Re: Ayam 1.16
Unread postby hamei » Wed Sep 23, 2009 11:20 am
Thanks very much ! I downloaded and untarred. It starts and runs on 6.5.30 on a Fuel without any issues. The interface seems slightly different - is there a way to separate the menus from the views like in the previous version ? Couldn't find anything in the preferences.
I'm anartistic so can't tell you a lot more than that.
Re: Ayam 1.16
Unread postby recondas » Wed Sep 23, 2009 3:46 pm
hamei wrote:I'm anartistic
I thought that was spelled anarchistic.
:wink:
rschultz
Re: Ayam 1.16
Unread postby rschultz » Wed Sep 23, 2009 11:42 pm
hamei wrote:Thanks very much ! I downloaded and untarred. It starts and runs on 6.5.30 on a Fuel without any issues. The interface seems slightly different - is there a way to separate the menus from the views like in the previous version ? Couldn't find anything in the preferences.
Thanks for trying!
Even the oldest versions of the source use "-tearoff 0"
in the menu code, so that you could never separate
menus into own windows.
Maybe you are looking for the "SingleWindow" preference
option?
kind regards,
Randolf
Re: Ayam 1.16
Unread postby hamei » Thu Sep 24, 2009 3:25 am
rschultz wrote:Maybe you are looking for the "SingleWindow" preference option?
Exactly. Found it, turned it off. More my style. Funny, the stuff you come across reading the fine manual :P
Thank you again.
squeen
Re: Ayam 1.16
Unread postby squeen » Thu Sep 24, 2009 3:46 am
Thank you!
GeneratriX
Re: Ayam 1.16
Unread postby GeneratriX » Tue Oct 06, 2009 6:44 pm
Very nice, I'll try it once I have my Octane working again. Nice to see recent apps for the IRIX platform. Thanks!
