Seamonkey 1.1.18
edefault
Seamonkey 1.1.18
Unread postby edefault » Fri Sep 18, 2009 6:22 am
Hello,
is anyone about to provide a binary of seamonkey_1.1.18?
With 1.1.17, ssh can eventually becom compromised:
http://www.mozilla.org/security/announce/2009/mfsa2009-42.html
Valueing life is not weakness; disregarding it is not strength. -Mirage-
Re: Seamonkey 1.1.18
Unread postby SAQ » Fri Sep 18, 2009 12:33 pm
Build started for MIPS3.
Unread postby foetz » Fri Sep 18, 2009 12:59 pm
mips3?
dc_v01
Unread postby dc_v01 » Fri Sep 18, 2009 1:30 pm
foetz wrote:mips3?
Maybe you were out too long. SAQ does MIPS3 nekoware builds.
Unread postby nekonoko » Fri Sep 18, 2009 3:03 pm
I'm working on a build too; there seems to be a minor porting snafu in this version I'm trying to overcome.
Unread postby nekonoko » Fri Sep 18, 2009 5:35 pm
Okay, I was able to work out the issue. The mips4 build in now in /beta.
Unread postby SAQ » Fri Sep 18, 2009 5:59 pm
Did you have the "I only want to build on one processor" problem with yours? ("cannot contact jobserver, using -j1" or something similar).
Makes me glad I didn't spend a bunch of time today getting the 6-way Challenge ready to blitz through the build. The O200 is taking forever.
Unread postby nekonoko » Fri Sep 18, 2009 6:43 pm
No, the problem I had was in the final link phase - they added in some new libraries and broke my old patch in the process. Here's the fix if you run into the same thing:
--- static-config.mk.orig       Fri Sep 18 16:39:37 2009
+++ static-config.mk    Fri Sep 18 17:04:07 2009
@@ -73,7 +73,7 @@
 ifdef MOZ_PSM
 STATIC_EXTRA_LIBS      += \
-               $(NSS_LIBS) \
+               -L../../dist/bin -L../../dist/lib -lcrmf -lsmime3 -lssl3 -lnss3 -lnssutil3 -lsoftokn3 -lXt \
                $(NULL)
 endif
@@ -84,7 +84,7 @@
 endif
 ifdef MOZ_STORAGE
-STATIC_EXTRA_LIBS      += $(SQLITE_LIBS)
+STATIC_EXTRA_LIBS      += -L../../dist/bin -L../../dist/lib -lsqlite3
 endif
 ifdef MOZ_SVG
Unread postby SAQ » Fri Sep 18, 2009 7:07 pm
Interesting - my box had a different static-config.mk file.
Unread postby nekonoko » Fri Sep 18, 2009 7:13 pm
That's just a patch, not the whole thing :)
Unread postby foetz » Fri Sep 18, 2009 7:35 pm
dc_v01 wrote:
foetz wrote:mips3?
ah, nice :D
however i've never been much into nekoware anyway
Unread postby SAQ » Fri Sep 18, 2009 8:09 pm
nekonoko wrote:That's just a patch, not the whole thing :)
Correction - when I went to look at the relevant lines from static-config.mk on my box to see how they would change they were different than the ones listed in the patchfile. Not a big deal, as it was easily hand-edited, but interesting that they would be different.
Yep, not doing as much as I should (no Internet at home so I have my boxes at my parents), but there are a few MIPS3 builds still current, and a few (fontforge and xfe) that I don't think have made it into the MIPS4 tree yet.
Unread postby nekonoko » Fri Sep 18, 2009 8:12 pm
SAQ wrote:Correction - when I went to look at the relevant lines from static-config.mk on my box to see how they would change they were different than the ones listed in the patchfile.
Ah, maybe because you'd already run "seamonkey-2.0_irix.patch" which modifies that file. phpBB also tends to mess up whitespace in code blocks (tabs and spaces).
The important thing is that it worked ;)
bplaa.yai
Unread postby bplaa.yai » Sat Sep 19, 2009 1:30 am
SAQ wrote:Yep, not doing as much as I should (no Internet at home so I have my boxes at my parents), but there are a few MIPS3 builds still current, and a few (fontforge and xfe) that I don't think have made it into the MIPS4 tree yet.
xfe and fox were in the mips4 tree 1 week before the mips3 version ;)
Anyway, nice to know someone keeps porting for mips3 :)
:Onyx2: :O2: :O3x0: :O3x0:
Return to “SGI: Security”
