Fractal benchmark
Martin Steen
Fractal benchmark
Unread postby Martin Steen » Tue Jun 23, 2009 3:51 pm
Hello,
here is a little program that can be used as a benchmark in a multiprocessor environment.
It calculates three beautiful (?) fractal images:
http://www.martin-steen.de/sgi/frbatch.tar.gz
It makes heavy use of posix threads, so the programs benefits a lot of systems
with more than one CPU. Actually, it is a multithreaded floating-point benchmark.
Atfer unpacking, run the script "./run1.sh" to run a fast benchmark. "./run2.sh" runs a
slower benchmark that creates bigger images. The script uses four threads,
but you can adjust the scripts to use more threads or create even larger images
(8000x8000 pixel are no problem, but it takes a while).
When the benchmark has run, another small program converts the images from Targa
format to Jpeg. The programs are compiled for 64 bit machines (-64 -mips4).
On a SGI Fuel, the first script takes about 120 seconds.
Best regards,
Martin
legalize
Re: Fractal benchmark
Unread postby legalize » Tue Jun 23, 2009 4:31 pm
The executable in there is a MIPS/IRIX executable?
Martin Steen
Unread postby Martin Steen » Tue Jun 23, 2009 10:20 pm
legalize wrote:The executable in there is a MIPS/IRIX executable?
Yes, the files "fractbatch" and "tga2jpeg" are 64-bit mips executables.
My collection so far ;)
:Fuel: :Octane:
Geoman
Unread postby Geoman » Wed Jun 24, 2009 3:56 am
@Martin Steen: Thank you very much!
I didn't dare to ask you to publish the fractal generator from the "SGI Art Gallery" thread, thought you might want to keep that closed - but you finally released it :-D
Geoman
Unread postby Geoman » Wed Jun 24, 2009 4:27 am
Here we go:
Octane2 8% ./run1.sh
Fractal benchmark / by Martin Steen
Size   =256x256
Iter   =16384
Threads=4
Render 1 of 3: fract_0088_2.tga
InitThreads OK
Render 2 of 3: fract_0088_8.tga
InitThreads OK
Render 3 of 3: fract_0088_9.tga
InitThreads OK
real    2m38.56s
user    2m37.17s
sys     0m0.18s
~159seconds on a dual R12K400 Octane.
concerning CPU-load, top gave me:
2 CPUs: 47,6% idle, 51,6% usr,  0,8% ker,  0,0% wait,  0,0% xbrk,  0,0% intr
 PID       PGRP USERNAME PRI  SIZE   RES STATE    TIME WCPU% CPU% COMMAND
1399       1398 robert   +20 5472K 2864K run/1    0:27 96,3 96,23 fractba
Martin Steen
Unread postby Martin Steen » Wed Jun 24, 2009 5:30 am
Geoman wrote:~159seconds on a dual R12K400 Octane.
Hmmm.. looks like only one CPU is working. Unfortunately, I don't own a SGI with more than
one CPU. On my Linux computer with a phenom quadcore, all four cores are 96% busy
(using the same sourcecode).
So, since you have a dual-CPU Octane2, you have to be my betatester now ;)
Thank you for testing and best regards,
Martin
Geoman
Unread postby Geoman » Wed Jun 24, 2009 5:44 am
Wait! :-)
Seems like Octane has to warmup ^_^ a little bit.
doing the 2nd script, your renderer uses both cpu's in stage 3:
Octane2 10% ./run2.sh
Size   =2048x2048
Iter   =16384
Threads=4
InitThreads OK
InitThreads OK
.............^[[B.......................................
InitThreads OK
2 CPUs:  1,3% idle, 94,8% usr,  3,3% ker,  0,1% wait,  0,0% xbrk,  0,5% intr
1402       1401 robert   +20 5696K 3088K run/0  116:09  154 160,1 fractba
Martin Steen
Unread postby Martin Steen » Wed Jun 24, 2009 7:04 am
Geoman wrote:Wait! :-)
Thank you for the report. Seems like there is still an issue about threads that I have
to spot.
Best regards, Martin
ShadeOfBlue
Unread postby ShadeOfBlue » Wed Jun 24, 2009 7:08 am
I can give it a try on my 16CPU Origin tomorrow (hope the rainy weather continues :)).
Also, on MIPS (and other properly designed architectures), 64-bit apps actually run *slower* than 32-bit ones, so compile for 64-bit only if your app uses more than 2GB of memory.
Martin Steen
Unread postby Martin Steen » Wed Jun 24, 2009 7:19 am
ShadeOfBlue wrote:I can give it a try on my 16CPU Origin tomorrow (hope the rainy weather continues :)).
That would be great! I can also give you the sourcecode so you can compile your own
version (MIPSpro compiler needed).
Best regards,
Martin
Geoman
Unread postby Geoman » Wed Jun 24, 2009 7:29 am
to spot.
Well, for me, your program works really smooth, even at 97,4% usr. I can still do work while rendering.
Seti, on the other hand, stalls the Octane while working on 2 datasets; it becomes totally unresponsive then.
joerg
Unread postby joerg » Wed Jun 24, 2009 12:23 pm
ShadeOfBlue wrote:I can give it a try on my 16CPU Origin tomorrow (hope the rainy weather continues :))...
You have a watercooled origin? :P
SCNR,
Joerg
Martin Steen
Unread postby Martin Steen » Wed Jun 24, 2009 4:32 pm
SCNR,
Joerg
Hello Joerg, hello ShadeOfBlue, hello Geoman,
if you dare to run the app on your multiprozessor machines, here is the sourcecode for the
fractal batch programm:
http://www.martin-steen.de/sgi/fractbatch-source.tar.gz
Just type "make" to build the executable.
Run ./testrun.sh to create three (simple) fractals
This test is not a real challange for a machine with 16 cpus.
To make it more interesting, you can try:
./fractbatch 8192 8192 1024 32 frects0089.txt
This creates the three images with a size of 8192x8192 pixels
and uses 32 threads.
Remarks:
- The limit for Targa pictures is 32768x32768 Pixels.
- maybe you know compiler switches for a faster executable
Best regards,
Martin
ShadeOfBlue
Unread postby ShadeOfBlue » Thu Jun 25, 2009 3:38 am
:lol:
These things are like little furnaces, the room heats up by 4°C in an hour. Excellent to have in winter, not so much when it's 35°C outside :)
Anyhow, the weather is favorable, I shall power it up and open the balcony, expect results soon :)
Geoman
Unread postby Geoman » Thu Jun 25, 2009 4:20 am
Thanks for sharing the sourcecode. It built on MIPSpro 7.4.4m without any error or warning.
Now I'm torturing the Octane with it:
I get 187,8 CPU% right at the beginning.
