Tezro, Quad-R16K/1GHz (16MB L2), 4GB, V12/DM3, RAID
mapesdhs
Unread postby mapesdhs » Sat Jun 06, 2009 8:01 am
Tezro Quad-R16K/1GHz (16MB L2), 4GB RAM, 36GB 10K system, 48 x 146GB 15K JBOD RAID, 4 x QLA12160/66 PCI64,
DM3 card (not in hinv as drivers not installed). Normally connected to a DM5/VBOB, but again not shown here. The system
originally had two QLA2342s, RAD Audio, dual-port Gbit NIC and dual-port serial card, but I've removed all these.
       IP59_4CPU Board: barcode NPD130     part 030-1989-003 rev -A
       WS_INT_53 Board: barcode NNY839     part 030-1881-007 rev -A
      ODY128B1_2 Board: barcode NNR309     part 030-1884-005 rev -B
             IO9 Board: barcode NKY494     part 030-1771-005 rev -A
4 1.0 GHZ IP35 Processors
CPU 0 at Module 001c01/Slot 0/Slice A: 1.0 Ghz MIPS R16000 Processor Chip (enabled)
  Processor revision: 3.0. Scache: Size 16 MB Speed 333 Mhz  Tap 0x15
CPU 1 at Module 001c01/Slot 0/Slice B: 1.0 Ghz MIPS R16000 Processor Chip (enabled)
CPU 2 at Module 001c01/Slot 0/Slice C: 1.0 Ghz MIPS R16000 Processor Chip (enabled)
CPU 3 at Module 001c01/Slot 0/Slice D: 1.0 Ghz MIPS R16000 Processor Chip (enabled)
Main memory size: 4096 Mbytes
Integral SCSI controller 15: Version QL12160, low voltage differential
  Disk drive: unit 8 on SCSI controller 15 (unit 8)
  Disk drive: unit 9 on SCSI controller 15 (unit 9)
  Disk drive: unit 10 on SCSI controller 15 (unit 10)
  Disk drive: unit 11 on SCSI controller 15 (unit 11)
  Disk drive: unit 12 on SCSI controller 15 (unit 12)
  Disk drive: unit 13 on SCSI controller 15 (unit 13)
Integral SCSI controller 16: Version QL12160, low voltage differential
  Disk drive: unit 8 on SCSI controller 16 (unit 8)
  Disk drive: unit 9 on SCSI controller 16 (unit 9)
  Disk drive: unit 10 on SCSI controller 16 (unit 10)
  Disk drive: unit 11 on SCSI controller 16 (unit 11)
  Disk drive: unit 12 on SCSI controller 16 (unit 12)
  Disk drive: unit 13 on SCSI controller 16 (unit 13)
Integral SCSI controller 7: Version QL12160, low voltage differential
  Disk drive: unit 8 on SCSI controller 7 (unit 8)
  Disk drive: unit 9 on SCSI controller 7 (unit 9)
  Disk drive: unit 10 on SCSI controller 7 (unit 10)
  Disk drive: unit 11 on SCSI controller 7 (unit 11)
  Disk drive: unit 12 on SCSI controller 7 (unit 12)
  Disk drive: unit 13 on SCSI controller 7 (unit 13)
Integral SCSI controller 8: Version QL12160, low voltage differential
  Disk drive: unit 8 on SCSI controller 8 (unit 8)
  Disk drive: unit 9 on SCSI controller 8 (unit 9)
  Disk drive: unit 10 on SCSI controller 8 (unit 10)
  Disk drive: unit 11 on SCSI controller 8 (unit 11)
  Disk drive: unit 12 on SCSI controller 8 (unit 12)
  Disk drive: unit 13 on SCSI controller 8 (unit 13)
Integral SCSI controller 11: Version QL12160, low voltage differential
  Disk drive: unit 8 on SCSI controller 11 (unit 8)
  Disk drive: unit 9 on SCSI controller 11 (unit 9)
  Disk drive: unit 10 on SCSI controller 11 (unit 10)
  Disk drive: unit 11 on SCSI controller 11 (unit 11)
  Disk drive: unit 12 on SCSI controller 11 (unit 12)
  Disk drive: unit 13 on SCSI controller 11 (unit 13)
Integral SCSI controller 12: Version QL12160, low voltage differential
  Disk drive: unit 8 on SCSI controller 12 (unit 8)
  Disk drive: unit 9 on SCSI controller 12 (unit 9)
  Disk drive: unit 10 on SCSI controller 12 (unit 10)
  Disk drive: unit 11 on SCSI controller 12 (unit 11)
  Disk drive: unit 12 on SCSI controller 12 (unit 12)
  Disk drive: unit 13 on SCSI controller 12 (unit 13)
Integral SCSI controller 17: Version QL12160, low voltage differential
  Disk drive: unit 8 on SCSI controller 17 (unit 8)
  Disk drive: unit 9 on SCSI controller 17 (unit 9)
  Disk drive: unit 10 on SCSI controller 17 (unit 10)
  Disk drive: unit 11 on SCSI controller 17 (unit 11)
  Disk drive: unit 12 on SCSI controller 17 (unit 12)
  Disk drive: unit 13 on SCSI controller 17 (unit 13)
Integral SCSI controller 18: Version QL12160, low voltage differential
  Disk drive: unit 8 on SCSI controller 18 (unit 8)
  Disk drive: unit 9 on SCSI controller 18 (unit 9)
  Disk drive: unit 10 on SCSI controller 18 (unit 10)
  Disk drive: unit 11 on SCSI controller 18 (unit 11)
  Disk drive: unit 12 on SCSI controller 18 (unit 12)
  Disk drive: unit 13 on SCSI controller 18 (unit 13)
IOC3/IOC4 serial port: tty3
IOC3/IOC4 serial port: tty4
Graphics board: V12
  PCI Adapter ID (vendor 0x1077, device 0x1216) PCI slot 2
  PCI Adapter ID (vendor 0x104c, device 0xac28) PCI slot 2
IOC4 firmware revision 83
        Managed (":0.0") 1600x1200
        BUZZ version B.2
        PB&J version 1
        128MB memory
                Banks: 4, CAS latency: 3
         Monitor 0 type: Unknown
         Video Output: 1600 pixels, 1200 lines, 72.01Hz (1600x1200_72)
tezro# df
Filesystem             Type  kbytes     use     avail  %use Mounted on
/dev/root               xfs 35428556 17487404 17941152  50  /
/dev/xlv/video          xfs 6881757136 10590800 6871166336   1  /video
I have a second similar system (same CPU/gfx/RAM) that still has the original other cards.
Ian.
mapesdhs@yahoo.com
+44 (0)7434 635 121
indyman007
Re: Tezro, Quad-R16K/1GHz (16MB L2), 4GB, V12/DM3, RAID
Unread postby indyman007 » Sat Jun 06, 2009 8:07 am
Do you have any particular use for it?
:Indy: R4600PC 133 MHz
Mac Mini 2.5GHz 8GB RAM
Raspberry Pi
bri3d
Unread postby bri3d » Sat Jun 06, 2009 8:13 am
This is what I hope to turn my O350/Onyx system into - all I'm missing is my NUMALink cable (on the way), a V12 (to replace my V10), and a DM3 (I probably won't end up getting one, as I don't have much use, but...) and I've got it :p
@indyman007 - would probably be used as a Discreet system in "the real world" - there's not much else that uses a DM3 and that much power.
sgtprobe
Unread postby sgtprobe » Sat Jun 06, 2009 9:51 am
Wow, Nice system Ian. :)
/Jonas
Old polygon wrangler
___________________
http://www.edgeloop.se
Unread postby hamei » Sat Jun 06, 2009 9:58 am
bri3d wrote:This is what I hope to turn my O350/Onyx system into - all I'm missing is my NUMALink cable (on the way), a V12 (to replace my V10), and a DM3
DM3 is the SDStationOEM ?
Ian, since you pulled the serial card, could you look and see what UART's it has ? Maybe 16550's ?
bri3d
Unread postby bri3d » Sat Jun 06, 2009 12:51 pm
hamei wrote:DM3 is the SDStationOEM ?
Pretty sure that was DM6 - the DM3 is XIO, not PCI. There was some speculation that DM3 might also be a DVE product but as far as I know only SGI ever sold XIO cards, so I doubt they ever directly sold any.
Unread postby foetz » Sat Jun 06, 2009 6:36 pm
that's it.
what else to say? :D
mapesdhs
Unread postby mapesdhs » Sun Jun 07, 2009 5:48 pm
indyman007 writes:
There are things I can use it for (movie conversion tasks), but neither system is for keeps. I bought them stricly as an
investment, because the ISA interest rates are now so useless. They were expensive (thousands); I couldn't justify
spending so much on something like this for personal use, not at present. My bank savings balance would have to
have at least one extra digit on the end for that to be viable. :D
A US movie company is interested in one of them, perhaps later in the summer, not sure yet.
Oh, I have a quad-700 system aswell.
bri3d writes:
> This is what I hope to turn my O350/Onyx system into - ...
Is it still a dual-1GHz V10 atm?
I got one from Harry, for the quad-700 system I have. He probably has more.
Correct, they were all Smoke systems. The unit pictured at the start of this thread still has a sticker on the front panel,
behind the front flap, that says, "SMOKE2". Naturally, the system disks were wiped though. Each system came with
either an original IR36 or IR73 Stone FC array, ie. a 15-bay FC chassis filled with either 36GB or 73GB FC drives
containing proper Discreet firmware.
sgtprobe writes:
Thanks! 8)
I've added a few benchmark results for the system, but have a few more to do.
hamei writes:
The board (PN 030-1657-003, dated 2000) has just four main ASICs:
- 2 x SIPEX SP333CT 0327
- TL16PIR552PH F-41A5RDW
- LSI LOGIC L2A0366 IOC3 REV C, SGI 1996, 099-0126-003, J 0416, WPG16008
There are two more much smaller 14-pin ASICs, but the writing on them is too small to discern as I type this.
I have a second serial card, marked SGI Imagesync, PN 030-1723-001. It has a completely different layout, the main
ASIC being a XILINX SPARTAN XCS40XL (PQ208AKP0029, D1106126A).
While I think of it...
The dual-port Gbit NIC in the systems is SGI PN 9210292, Tigon3 I think (Broadcom ASIC), marked Silicom Ltd
Connectivity Solutions, model number PXG2-SGI.
The RAD Audio card is PN 030-1649-001, LSI ASIC L2A0470 RAD1 REV B.
Hope this helps!
Btw, does anyone know if Blender 2.48 can do renders using networked systems? If so, is it easy to setup? I was
wondering how hard it would be to run my benchmark using all three Tezros, see what happens.
Ian.
Richtom1
Unread postby Richtom1 » Sun Jun 07, 2009 6:11 pm
I'll be looking to get a set up like that next..........unless I die first :( bummer
btw the DM3 I have is PN: 030-1927-003 Rev B and it's PCI not XIO
And will you stop hitting me in the back of the head already!
mapesdhs
Unread postby mapesdhs » Sun Jun 07, 2009 6:25 pm
Richtom1 writes:
In that case, take all possible measures to live longer. 8)
Ah, no, it's not a PCI card. Check a DM3 installed in a Tezro, it does not plug into a PCI slot.
The only PCI SGI video board I know of is the DM6, a card Discreet never officially supported.
Ian.
Unread postby jan-jaap » Mon Jun 08, 2009 12:40 am
hamei wrote:Ian, since you pulled the serial card, could you look and see what UART's it has ? Maybe 16550's ?
Nothing that mundane ;)
I believe there's an IOC3 on it, the IO chip from the IO6 of an O2k. The keyboard/mouse/network ports aren't wired. Is that wasteful? You betcha ... But at least they didn't need to write a new driver.
ShadeOfBlue
Unread postby ShadeOfBlue » Mon Jun 08, 2009 12:54 am
jan-jaap wrote:Nothing that mundane ;)
But it does have a 16550 UART chip as well: :?
mapesdhs wrote:
The datasheet for this one says it has dual 16550 UARTs + parallel port.
Perhaps the IOC3 chip is just a bridge.
mapesdhs
Unread postby mapesdhs » Mon Jun 08, 2009 2:44 am
Just a thought about the DM3...
It fits into the same type of double-socket that the V12 is plugged into (definitely XIO, or rather XIO2 I suppose) Thus, with a
bit of metal hacking of the rear chassis plate, could one fit two V12s into a Tezro tower unit? This would mean no DM3 though.
Wild thought: if one knew how, maybe the spare XIO port could be linked to the same port in a different Tezro, make an 8-CPU
system. Hmm, probably not.
Funny thing - before Tezro launched, some of the comments I heard from SGI people led me to infer that the system would
indeed be linkable in this way, but alas that didn't happen. Pity, would've been cool.
Ian.
Dual-Pipe Tezro Tower?
Unread postby recondas » Mon Jun 08, 2009 3:12 am
mapesdhs wrote:Funny thing - before Tezro launched, some of the comments I heard from SGI people led me to infer that the system would indeed be linkable in this way, but alas that didn't happen. Pity, would've been cool.
I believe it did happen - if you purchased a Tezro rack system you could link <at least> two.
Though interestingly enough, the rear view illustration in the Tezro Rack Mounted Workstation User's Guide doesn't label the XIO port , or specifically mention it in the accompanying text.
While the nearly identical illustration from the Onyx 350 Visualization System User's Guide does.
An implicit omission to prevent drawing sales from the more expensive Onyx 350 line?
kramlq
Unread postby kramlq » Mon Jun 08, 2009 3:51 am
...where in Edinburgh do you live ... any summer holidays planned ... do you have an alarm system on your house...
On a serious note - an amazing system, but why only 4Gb RAM in such an otherwise highly spec'ed machine?
