Before I trash 3 quad Origin 300s...
PymbleSoftware
Unread postby PymbleSoftware » Tue Jun 02, 2009 6:20 pm
I have three Origin 300s and a PCI cage as described in the hinv section:
viewtopic.php?f=14&t=17314&hilit=+300&start=15
and I have an L2 controller and a router brick, power module and all the cables, etc..
I have put it together as per the tech pubs document...
http://techpubs.sgi.com/library/tpl/cgi ... 279-PARENT
I have a router brick not an Origin 300 NUMA link brick
This is likely to cause my biggest headaches:
a) The Router Brick/NumaLink Modules are reported to be the hardest to overcome the serial security issue <not withstanding the claim of one member - for which he can't or won't provide detail>
b) SGI probably used a NumaLink Module <rather than an O3k Router brick> for a reason. I'm aware that that reason could have solely been for marketing purposes, but this snippet from the PCI Module manual might offer a hint:
TechPubs wrote: The SGI 300 compute module cannot connect to a P-brick because the P-brick requires a connection to the I/O interface (II) of a Bedrock ASIC. The I/O interface of the SGI 300 compute module's Bedrock ASIC connects to an internal Xbridge ASIC.
In order to expand the I/O capabilities of the SGI 300 compute module, the network interface (NI) of the SGI 300 compute module's Bedrock ASIC is used. This interface must connect to another NI port; therefore, it must connect to a device that has a Bedrock ASIC. The PCI expansion module has a Bedrock interface card (BIC) that contains a Bedrock ASIC. (The P-brick does not contain a Bedrock ASIC.)
This Bedrock-to-Bedrock communication is referred to as peer I/O. The PCI expansion module is a “peer” I/O device to the SGI 300 compute module. In other words, the SGI 300 compute module communicates with the PCI expansion module in the same manner that it would communicate with another SGI 300 compute module.
So does the Numalink module also use peer-to-peer topology and the O3k Router not?
None of this is well documented and anyone who has achieved this has kept it secret.
viewtopic.php?f=3&t=16718704&p=7281728&#p7281728
viewtopic.php?f=3&t=1574183&p=7275440&#p7275440
I started a wiki topic
http://www.nekochan.net/wiki/ ... Origin_300
I have sent PMs to various people and the response I have gotten back have been terse and opaque, which kind makes want to dump it all in land fill and move somewhere rural overseas.
Regan
死の神はりんごだけ食べる
開いた括弧は必ず閉じる -- あるプログラマー
Twitter @PymbleSoftware
Re: Before I trash 3 quad Origin 300s...
Unread postby hamei » Tue Jun 02, 2009 6:54 pm
PymbleSoftware wrote:I have sent PMs to various people and the response I have gotten back have been terse and opaque, which kind makes want to dump it all in land fill and move somewhere rural overseas.
You are already somewhere rural overseas :)
You also need to remember that you're trying to outsmart SGI. They never intended for users to be doing these things. They made their living by doing what your are trying to do for free. Of course they aren't going to help you. Once the genie is out of the bottle no one on earth can put it back in.
PymbleSoftware
Unread postby PymbleSoftware » Tue Jun 02, 2009 8:27 pm
Gee, thanks hamei, you've been a great help.
死の神はりんごだけ食べる
Unread postby hamei » Wed Jun 03, 2009 1:05 am
PymbleSoftware wrote:Gee, thanks hamei, you've been a great help.
We try to please :P
maxsleg
Unread postby maxsleg » Wed Jun 03, 2009 4:16 am
or just honest -
As I said in the PM I have never done this and I expect it could throw up a serial number mismatch..
:ChallengeL: :O2000: :Onyx2: :Onyx: :O2000R: :O2000R: :O2000E: :O2000E: :Onyx2R: :O3000: :0300: :0300: :0300: :Indy: :Indigo2: :Indigo2: :Indigo2IMP: :Octane: :Octane: :Octane2: :Octane2: :Fuel: :Fuel:
PymbleSoftware
Unread postby PymbleSoftware » Wed Jun 03, 2009 4:38 am
or just honest -
I wasn't actually referring to your PM.
Thanks anyway.
死の神はりんごだけ食べる
Zerolapse
Unread postby Zerolapse » Wed Jun 03, 2009 8:04 am
The fact that you have a router brick isn't the problem so much as the fact that it's serial number is already set to match the previous system it was plugged into. You're getting errors because the serial number currently set on your Origin 300 systems doesn't match the one in the R brick (note that the L2 controller also needs to match). If your L1 Controller firmware version on your O300s is low enough you can manually set (or clear)the serial number as long as security hasn't been enabled on them. This may or may not help you because I believe that the first character of the serial number in an O300 system can only be certain characters. So you may or may not be able to set them to match the router. If you can't you need to reset the serial number in the R brick. Doing this unfortunately requires a security code that is based on the serial number of the R brick and the time. Be careful when you do do this though, because the R brick will pick a serial number from an adjacent device and burn it in (which will likely be your L2 controller). So pick a valid serial number and set them all the same on your O300s and L2 controller first...then reset the R brick. There is also feature codes to do things like enable extra ports on the router...
Hope this helps,
-Jesse
The current fleet.
PymbleSoftware
Unread postby PymbleSoftware » Wed Jun 03, 2009 4:00 pm
Zerolapse wrote:The fact that you have a router brick isn't the problem so much as the fact that it's serial number is already set to match the previous system it was plugged into. You're getting errors because the serial number currently set on your Origin 300 systems doesn't match the one in the R brick (note that the L2 controller also needs to match). If your L1 Controller firmware version on your O300s is low enough you can manually set (or clear)the serial number as long as security hasn't been enabled on them. This may or may not help you because I believe that the first character of the serial number in an O300 system can only be certain characters. So you may or may not be able to set them to match the router. If you can't you need to reset the serial number in the R brick. Doing this unfortunately requires a security code that is based on the serial number of the R brick and the time. Be careful when you do do this though, because the R brick will pick a serial number from an adjacent device and burn it in (which will likely be your L2 controller). So pick a valid serial number and set them all the same on your O300s and L2 controller first...then reset the R brick. There is also feature codes to do things like enable extra ports on the router...
Hope this helps,
-Jesse
Thanks heaps..
I am going to have to reread that again and get my head around it before I get home.
Cheers,
Regan
死の神はりんごだけ食べる
Unread postby recondas » Wed Jun 03, 2009 4:20 pm
Some additional background info might be helpful:
    The output of "serial all" from the L1 controller of the R-Brick.
    The output of "serial all" from the L1 Controller of the O300 you intend to have as the linked system master.
    The output of "ver" from the L1 of each individual module <including the L2>.
PymbleSoftware
Unread postby PymbleSoftware » Thu Jun 04, 2009 5:37 am
recondas wrote:Some additional background info might be helpful:
L2:
L1001231-001-L2>ver
L2 version: 1.36.0
L1001231-001-L2>serial
L2 system serial number: L1001231.
L1001231-001-L2>
Ok, start with the router brick and check things out from there:
L1001231-001-L2>1.25 l1
entering L1 mode 001r25, <CTRL-T> to escape to L2
001r25-L1>ver
L1 1.40.4 (Image B), Built 09/29/2005 13:42:59    [Base 1MB image]
001r25-L1>serial all
Local System Serial Number      NVRAM         L1001241
Reference System Serial Number  Attached L2   L1001231
Local Brick Serial Number       EEPROM        MHR829
Reference Brick Serial Number   NVRAM         MHR829
POWER       RPWR            MHR829         030_1631_002          E    00
LOGIC       ROUTER          LGP402         030_1634_002          B    00
001r25-L1>
L1001231-001-L2>reboot_l2
will reboot in 5 seconds...
INIT: Switching to runlevel: 6
Sending processes the TERM signal
Restartinÿ
Validating L2 Controller Flash image....OK
Booting...
Ethernet address from Motorola VPD EEPROM is 08:00:69:11:B1:77
Linux/PPC load:
Uncompressing Linux...done.
Now booting the kernel
Linux version 2.4.7-sgil2 (dsd@tstorm) (gcc version 2.95.2 19991030 (2.95.3 prerelease/franzo)) #1 Mon Feb 28 14:51:03 CST 2005
On node 0 totalpages: 4096
zone(0): 4096 pages.
zone(1): 0 pages.
zone(2): 0 pages.
Kernel command line: root=/dev/ram panic=5
Decrementer Frequency = 187500000/60
Calibrating delay loop... 49.76 BogoMIPS
Memory: 11904k available (952k kernel code, 512k data, 180k init, 0k highmem)
Dentry-cache hash table entries: 2048 (order: 2, 16384 bytes)
Inode-cache hash table entries: 1024 (order: 1, 8192 bytes)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
Buffer-cache hash table entries: 1024 (order: 0, 4096 bytes)
Page-cache hash table entries: 4096 (order: 2, 16384 bytes)
POSIX conformance testing by UNIFIX
PCI: Probing PCI hardware
I/O resource not set for host bridge 0
Memory resource not set for host bridge 0
PCI: Cannot allocate resource region 0 of PCI bridge 0
PCI: resource is 80000000..7fffffff (100), parent c011c314
PCI:00:04.0: Resource 0: c0000000-c0000fff (f=200)
PCI:00:05.0: Resource 0: c0001000-c0001fff (f=200)
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Starting kswapd v1.8
i2c-core.o: i2c core module
i2c-dev.o: i2c /dev entries driver module
i2c-core.o: driver i2c-dev dummy driver registered.
i2c-algo-8xx.o: i2c mpc8xx algorithm module
i2c-rpx.o: i2c RPX Lite/MBX module
i2c-dev.o: Registered 'rpx' as minor 0
i2c-core.o: adapter rpx registered as adapter 0.
Console: switching to frame buffer device
fb0:  SGI L2 (SED137x LCD controller) frame buffer device
fb0:  Display panel [mono]: Hantronix HDM3224 (320x240, 4-bit Greyscale)
CPM UART driver version 0.03
ttyS00 at 0x0000 is a SCC
ttyS01 at 0x0100 is a SCC
ttyS02 at 0x0200 is a SCC
ttyS03 at 0x0300 is a SCC
WDT_8xx: Software Watchdog Timer version 0.3, 30 second timeout
block: queued sectors max/low 7810kB/2603kB, 64 slots per queue
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
eth0: FEC ENET Version 0.1, 08:fec: Phy @ 0x0, type 0x78100003
fec: link down
00:fec: 10 Mbps, Half-Duplex
69:11:b1:77
PowerPC realtime clock driver, version 0.1.
usb.c: registered new driver usbdevfs
usb.c: registered new driver hub
PCI: Enabling device 00:04.0 (0000 -> 0002)
usb-ohci.c: USB OHCI at membase 0xc2002000, IRQ 8
usb-ohci.c: usb-00:04.0, PCI device 11c1:5802 (Lucent Microelectronics)
usb.c: new USB bus registered, assigned bus number 1
Product: USB OHCI Root Hub
SerialNumber: c2002000
hub.c: USB hub found
hub.c: 2 ports detected
PCI: Enabling device 00:05.0 (0000 -> 0002)
usb-ohci.c: USB OHCI at membase 0xc2004000, IRQ 10
usb-ohci.c: usb-00:05.0, PCI device 11c1:5802 (Lucent Microelectronics)
usb.c: new USB bus registered, assigned bus number 2
SerialNumber: c2004000
usb-ohci.c: v5.2:USB OHCI Host Controller Driver
usb.c: registered new driver sgil1
sgil1.c: SGI L1 controller support registered
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP, IGMP
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 1024 bind 1024)
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
RAMDISK: cramfs filesystem found at block 0
RAMDISK: overriding ramdisk block size to 4096 for cramfs filesystem
RAMDISK: Loading 2012 blocks [1 disk] into ram disk... done.
Freeing initrd memory: 2012k freed
VFS: Mounted root (cramfs filesystem).
Freeing unused kernel memory: 180k init
INIT: version 2.77 booting
cp: /rhosts.allow: No such file or directory
Starting DHCP client daemon....
hub.c: USB new device connect on bus1/1, assigned device number 2
Manufacturer: Silicon Graphics, Inc.
Product: SN1 L1 System Controller
SerialNumber: 00000000
sgil1.c: SGI L1 connected, minor: 64 device: 1.2
hub.c: USB new device connect on bus1/2, assigned device number 3
hub.c: 7 ports detected
hub.c: USB new device connect on bus1/2/1, assigned device number 4
sgil1.c: SGI L1 connected, minor: 65 device: 1.4
hub.c: USB new device connect on bus1/2/2, assigned device number 5
usb.c: USB device not accepting new address=5 (error=-110)
hub.c: USB new device connect on bus1/2/2, assigned device number 6
usb.c: USB device not accepting new address=6 (error=-110)
hub.c: USB new device connect on bus1/2/4, assigned device number 7
sgil1.c: SGI L1 connected, minor: 66 device: 1.7
hub.c: USB new device connect on bus1/2/5, assigned device number 8
sgil1.c: SGI L1 connected, minor: 67 device: 1.8
dhcpcd[28]: timed out waiting for a valid DHCP server response
INFO: No DHCP server found, starting local DHCP server (to serve L3 clients).
INFO: DHCP: new IP address is 10.17.177.119
INIT: Entering runlevel: 5
SGI L2 Controller
Current L2 version: 1.36.0 (L2 emulator: 1.36.0)
Flashed L2 version: 1.36.0
INFO: opened USB control /dev/sgil1_cs
INFO: opened USB device at b1;p1;d2 (/dev/sgil1_0)
INFO: opened USB device at b1;p2/1;d4 (/dev/sgil1_1)
INFO: opened USB device at b1;p2/4;d7 (/dev/sgil1_2)
INFO: opened USB device at b1;p2/5;d8 (/dev/sgil1_3)
INFO: SMP listening on port: 8001
INFO: attempting connection to localhost:9002
INFO: auto power up appears enabled
INFO: auto power up in 30 seconds...
L1001231-001-L2>INFO: Validating connection from 'localhost' (127.0.0.1)
INFO: connection to localhost:9002 established.
INFO: Connection - sgi (sgi) @ localhost running 'l2flash'.
INFO: Connection - sgi (sgi) @ localhost running 'l2gui'.
INFO: Connection - sgi (sgi) @ localhost running 'l2part'.
INFO: auto power up in 25 seconds...
INFO: auto power up in 20 seconds...
INFO: auto power up in 15 seconds...
INFO: auto power up in 10 seconds...
INFO: auto power up in  5 seconds...
INFO: initiating auto power up.
ERROR: auto power up error.
001r25ERROR: SerNum:System Serial Number mismatch. See log for details.
001c01ERROR: SerNum:System Serial Number mismatch. See log for details.
001c02ERROR: SerNum:System Serial Number mismatch. See log for details.
001c03ERROR: SerNum:System Serial Number mismatch. See log for details.
001c01ERROR: power appears off.
001c02ERROR: power appears off.
001c03ERROR: power appears off.
001r25ERROR: power appears off.
L1001231-001-L2>serial all
001c01:
Local System Serial Number      NVRAM         M2001411
Local Brick Serial Number       EEPROM        KJD687
Reference Brick Serial Number   NVRAM         KJD687
NODE        IP45_4CPU       KJD687         030_1797_001          B    00
IO8         IO8             MHL579         030_1673_003          E    00
DIMM 0     CE0000000000000026051400 M3 46L2820BT1-CA0   0B    8.0  N/A
DIMM 2     CE000000000000000C7D8000 M3 46L2820DT2-CA0   2D   10.0  N/A
DIMM 1     7F7FFE000000000012000092 CM2201B             2     8.0  N/A
DIMM 3     7F7FFE000000000012000151 CM2201B             2     8.0  N/A
001c02:
Local Brick Serial Number       EEPROM        MLJ194
Reference Brick Serial Number   NVRAM         MLJ194
NODE        IP45_4CPU       MLJ194      030_1779_001          C    00
IO8         IO8             MLG164      030_1673_003          F    00
EEPROM      JEDEC Info                Part Number         Rev  Speed (ns)
DIMM 0      7F7FFE000000000012000145  CM2201B             2     08.0
DIMM 2      7F7FFE000000000012000141  CM2201B             2     08.0
DIMM 1      CE0000000000000026061400  M3 46L2820BT1-CA0   0B    08.0
DIMM 3      CE000000000000000C698000  M3 46L2820DT2-CA0   2D    10.0
001c03:
Local System Serial Number      NVRAM         M2100226
Local Brick Serial Number       EEPROM        MJN491
Reference Brick Serial Number   NVRAM         MJN491
NODE        IP45_4CPU       MJN491      030_1728_002          D    00
IO8         IO8             MHR530      030_1673_003          F    00
DIMM 0      10000000000000002E015A00  444BH               2
DIMM 2      100000000000000034015A00  444BH               2
DIMM 1      10000000000000006E005A00  444BH               2
DIMM 3      10000000000000000A015A00  444BH               2
001r25:
L1001231-001-L2>
L1001231-001-L2> 1.1 l1
entering L1 mode 001c01, <CTRL-T> to escape to L2
001c01-L1>serial all
001c01-L1>ver
L1 1.30.14 (Image B), Built 08/05/2004 11:09:57    [Base 1MB image]
001c01-L1>
L1001231-001-L2>1.2 l1
entering L1 mode 001c02, <CTRL-T> to escape to L2
001c02-L1>serial all
001c02-L1>ver
L1 1.12.6 (Image B), Built 04/22/2002 08:13:40    [1MB image]
001c02-L1>
L1001231-001-L2>1.3 l1
entering L1 mode 001c03, <CTRL-T> to escape to L2
001c03-L1>serial all
001c03-L1>ver
L1 1.8.4 (Image B), Built 10/30/2001 11:47:34    [P1 support]
001c03-L1>
Regan
死の神はりんごだけ食べる
Zerolapse
Unread postby Zerolapse » Thu Jun 04, 2009 5:56 am
Ah yes, that kick started my brain a bit. If memory serves, you can't set a serial number with the prefix 'L' on an O300 (but you should try it anyway just in case) so you will have to reset the router brick. First though, you'll want to get all your O300s and L2 to match, so the serial that gets copied to the router on reset is one that's compatible w/ your O300s (the router doesn't seem to have the same restriction). Someone at SGI support might be kind enough to help you with the resetting part if you ask nicely...
-Jesse
The current fleet.
Zerolapse
Unread postby Zerolapse » Thu Jun 04, 2009 6:06 am
Also, you'll want to get all of your L1s (and PROMs if they're not) at the same version after you get everything talking, it'll save you some headaches in the longrun. I'm at 1.22.4 on everything except the L2 (which is 1.32.4) and it's been working flawlessly (and no, it didn't enable security on my O300s and I'm still able to do a "serial clear" from the L1 successfully). To be safe though, get them connected together first.
Oh, btw...the easiest way to get the serials on your O300s in sync is to set the L2 to one they can set (prefix 'M') then do a 'serial clear' on each O300...if everything is wired properly it should pick up the serial from the L2 Controller automagically.
Like So:
001c01-L1>serial clear
001c01-L1>
001c01-L1>
001c01-L1>001c01 INFO: System serial number reassigned to M1000707 from attached L2.
Good Luck,
-Jesse
The current fleet.
PymbleSoftware
Unread postby PymbleSoftware » Thu Jun 04, 2009 6:11 am
The machine and L1 errors in question is looks like the image below:
My original Origin 300 came from Walt Disney Studios and the name stuck.
I think the serial number is going to change the lmhostid..
I am going to lose my MIPS Pro and Maya licenses again aren't I..?
L2 command processor engaged, <CTRL-D> for console mode.
L1001231-001-L2>1.1 l1
serial clear
001c01-L1>serial
BSN: KJD687    SSN: L0000000    Time: 06/04/2009 08:14:15 CDT
001c01-L1>
001c01-L1>
Its been a long day and time now for sleep..
Regan
Last edited by PymbleSoftware on Thu Jun 04, 2009 6:27 am, edited 1 time in total.
死の神はりんごだけ食べる
Zerolapse
Unread postby Zerolapse » Thu Jun 04, 2009 6:22 am
Looks familiar ;)
Here's mine:
PymbleSoftware wrote:I think the serial number is going to change the lmhostid..
I'd say that's likely, but I'm not sure honestly. Maybe someone else can shed some light on that?
The current fleet.
PymbleSoftware
Unread postby PymbleSoftware » Thu Jun 04, 2009 6:35 am
Cool.
Its about midnight here and they are messing with my power again tomorrow so I have to turn everything in the house off... It is a 3 day weekend here (Known as Queens Birthday) so I will have most of the weekend to work on it and play with the little Qt on IRIX app that I have been writing.. Right now I should really get to sleep.
Regan
死の神はりんごだけ食べる
