Crimson RealityEngine R4400/150MHz 256MB RAM
Unread postby nekonoko » Sun Mar 29, 2009 2:12 pm
1 150 MHZ IP17 Processor
CPU: MIPS R4400 Processor Chip Revision: 5.0
On-board serial ports: 4
Data cache size: 16 Kbytes
Main memory size: 256 Mbytes
I/O board, slot F: IO3B
RealityEngine Graphics option installed
Integral Ethernet: et0, IO3
Integral SCSI controller 1: Version WD33C93A, revision 9
  Disk drive: unit 4 on SCSI controller 1
  Disk drive: unit 2 on SCSI controller 1
Integral SCSI controller 0: Version WD33C93A, revision 9
VME bus: adapter 0
Graphics board 0 is "REC" graphics.
        Display 1280x1024 @ 72Hz
        8 GE (GE8 rev. 0x7/101)
        1 RM4 board (rev. 00112)
        Small pixel depth
        10-bit RGB pixels
        Not using Multi-Channel Option
pentium
Re: Crimson RealityEngine R4400/150MHz 256MB RAM
Unread postby pentium » Sun Mar 29, 2009 3:49 pm
Geez. Where did you find that?
Unread postby jan-jaap » Mon Mar 30, 2009 12:49 am
Nice :D
I see you have a working textport when IRIX is loading?
Mine has some issues there (it works in PROM, but then it's frozen from the time IRIX load until the X11 login shows up). Think I'll load a different IRIX on it once to force a flash.
Unread postby nekonoko » Mon Mar 30, 2009 4:39 am
Thanks - it's a cool system; really lucked into this one.
The textport works while booting IRIX; I shot a quick video of the boot sequence for you:
http://www.youtube.com/watch?v=0aQ0fsQuMZs
Probably only slightly more interesting than watching paint dry for most, but oh well ;)
sparcdr
Unread postby sparcdr » Tue Mar 31, 2009 11:46 am
Nice, a pink EZ Bake Oven! (jk)
If my 'lil Octane2 runs on 225w, what does that sucker draw?
Unread postby nekonoko » Tue Mar 31, 2009 12:16 pm
sparcdr wrote:Nice, a pink EZ Bake Oven! (jk)
Oh, I'm not sure - I think the power supply is 1050w, but it probably doesn't consume that much in use. The Crimson did come with a free blue Octane2 2x300MHz/V8 though ;)
zackwatt
Unread postby zackwatt » Tue Mar 31, 2009 6:14 pm
Very Nice. I would love to find a Crimson that is in that good of condition.
:Octane2: :Octane2: :Octane: :Indigo2IMP: :Indigo2: :O2: :O2+:
Octane2 2x600 V12 8GB
- Octane2 600 V12 2GB - Octane 2x400 V10 2GB
Indigo² 195 Max Impact 386MB - Indigo² 250 Extreme 386MB
O2 350 CRM 256MB - O2+ 400 CRM 512MB
"I'm totally unappreciated in my time. You can run this whole park from this room, with minimal staff, for up to three days. You think that kind of automation is easy? Or cheap? You know anybody who can network eight Connection Machines and de-bug two million lines of code for what I bid this job? Because if you can, I'd love to see him try."
Unread postby jan-jaap » Wed Apr 01, 2009 1:07 am
nekonoko wrote:Oh, I'm not sure - I think the power supply is 1050w, but it probably doesn't consume that much in use.
* The 1050W is power supplied to the system, it draws max 1500W from the mains. The difference is lost in the PSU itself (I guess).
* I measured the power usage of mine at 750W @ 220V. Mine has a second RM4 and a VME FDDIXPress board
Unread postby nekonoko » Wed Apr 01, 2009 1:17 am
Good info! I may add a second RM4 if I can find one sometime.
Unread postby jan-jaap » Wed Apr 01, 2009 2:22 am
nekonoko wrote:Good info!
If you dig in the comp.sys.sgi archives you can find entire threads about 1050W vs. 1500W PSUs for PowerSeries/Crimsons which were said to be RE capable or not. Unfortunately, I believe most of these people never bothered to open up a system, but instead simply kept rehashing what others said before them. Otherwise they might also have realized also that e.g. a 4D/340 or 440 VGX consumes significantly more power than a Crimson RE (I measured it). I mean, just look at the number of cards in the cardcage...
There are two PSU's for 'diehard'/'diehard2' desksides : originally, a silver PowerOne model was used, later systems have a black Cherokee. Both have the same ratings, so they are interchangeable. Unfortunately, the build quality of the Cherokee is rather inferior to the PowerOne model. If you have a black PSU you'd better remove it from the system and make sure the fan is working and not drowning in a cake layer of dirt and dust. Because if that fan dies, the PSU will overheat and self destruct. I know, it happened to me :( The PowerOne model will shut down gracefully. I know, that happened to me too ;)
1500W is the input rating for the first stage module of the PowerOne. 1050W is the sum of V*A for all output modules. But because of the modularity of the PowerOne design it's unclear whether the output modules drive the first stage to it's limits (and the difference between 1050W and 1500W is lost as heat in the PSU) or that the first stage is capable of more. There is space for a third output module in the PSU case ... Here are some photo's I took when I cleaned out a PowerOne PSU: http://vdheijden-messerli.net/sgistuff/ ... wersupply/
Unlike newer systems, Crimsons and 4D's don't have fan monitoring. There's some crude overheating protection but I would not rely on that. Just keep an eye on the fans (PSU and cardcage) to make sure they all work, and keep the system clean. They are pretty reliable beasts, considering their age.
nekonoko wrote:I may add a second RM4 if I can find one sometime.
Beware that the bridge board connecting GE and RMs must have a connector for a second RM4 too. Not all of them have it.
nekonoko wrote:The Crimson did come with a free blue Octane2 2x300MHz/V8 though ;)
Guess it wasn't a basement bargain then. I got a freebie Onyx2 and a trunk full of workstations and parts when I bought my Crimson + Predator :)
Unread postby nekonoko » Wed Apr 01, 2009 2:38 am
jan-jaap wrote:There are two PSU's for 'diehard'/'diehard2' desksides : originally, a silver PowerOne model was used, later systems have a black Cherokee. Both have the same ratings, so they are interchangeable. Unfortunately, the build quality of the Cherokee is rather inferior to the PowerOne model. If you have a black PSU you'd better remove it from the system and make sure the fan is working and not drowning in a cake layer of dirt and dust. Because if that fan dies, the PSU will overheat and self destruct. I know, it happened to me :( The PowerOne model will shut down gracefully. I know, that happened to me too ;)
All the fans are operational; the system is extremely clean - it looks brand new. No dust bunnies, grime or grit whatsoever :)
Here's a photo of the power receptacle if that helps identify it - I don't really want to take it apart again right now unless I have to:
jan-jaap wrote:Beware that the bridge board connecting GE and RMs must have a connector for a second RM4 too. Not all of them have it.
Just checked; all the RM connectors are populated.
jan-jaap wrote:Guess it wasn't a basement bargain then. I got a freebie Onyx2 and a trunk full of workstations and parts when I bought my Crimson + Predator :)
Well it did come from a basement :) $150 got me the Crimson, Octane2, extra drive sleds, external drives, large box of QIC tapes including original VFX software from the late eighties/early nineties, etc.
Both machines were used in the visual effects industry; the previous owner worked in VFX as well as at SGI itself.
Unread postby jan-jaap » Wed Apr 01, 2009 2:56 am
nekonoko wrote:Here's a photo of the power receptacle if that helps identify it
Not really, but there's another way: if you engage that breaker switch and you hear a fan humming inside before you flip the on/off switch on the front you have a PowerOne PSU. If not, you have a Cherokee PSU.
Since this is a 'late' Crimson (original configuration R4400 + RE) my guess is it has the Cherokee PSU.
nekonoko wrote:Well it did come from a basement :) $150 got me the Crimson, Octane2, extra drive sleds, external drives, large box of QIC tapes including original VFX software from the late eighties/early nineties, etc.
I call that a bargain :)
Unread postby nekonoko » Wed Apr 01, 2009 3:11 am
jan-jaap wrote:Not really, but there's another way: if you engage that breaker switch and you hear a fan humming inside before you flip the on/off switch on the front you have a PowerOne PSU. If not, you have a Cherokee PSU.
A fan does come on as soon as the breaker switch on the PSU is flipped on, so it must be a PowerOne. Once the front panel switch is flipped the others roar to life. The manufacture date on the card cage door is 12/94.
nekonoko wrote:I call that a bargain :)
Yeah, that was my thinking as well - certainly didn't haggle on the asking price ;)
jmc
Unread postby jmc » Tue Apr 07, 2009 2:35 am
Nice Crimson Neko! :)
Since you have already set up your Camera, could you film it running some demos or anyhing graphical?
There was a thread started a while ago by cybercow to post videos of SGI Big Iron, but unfortunately not much has been contributed...
:Onyx2:
Unread postby nekonoko » Tue Apr 07, 2009 6:00 am
Thanks!
Sure, I can do that; sounds like a good Sunday project :)
