Fuel 600MHz, 2GB RAM, V12, 2x73GB HDD/Now with Sound
sgtprobe
Unread postby sgtprobe » Wed Feb 25, 2009 3:17 am
Here is my new Fuel, newly arrived from Ian. (Thanks Ian, It's a beauty, and thanks for the Nice Network card)
All in all, much faster than my V10 equiped Octane2. Nice :)
Added a new picture of the whole lot.
Added a Sound Cracker Audigy 2 ZS and new Gfxinfo for my current resolution I'm running in.
fuel 50% hinv -mv
            IP34 Board: barcode NCH639     part 030-1707-004 rev -A
        IP34PIMM Board: barcode NCK659     part 030-1730-002 rev -E
          ASTODY Board: barcode NCK335     part 030-1726-005 rev -A
1 600 MHZ IP35 Processor
Main memory size: 2048 Mbytes
Integral SCSI controller 2: Version QL1280, low voltage differential
Integral SCSI controller 3: Version QL1280, low voltage differential
Graphics board: V12
Gigabit Ethernet: tg1, module 001c01, PCI bus 2 slot 1
Iris Audio Processor: version EMU revision A4, number 1
  PCI Adapter ID (vendor 0x1077, device 0x1280) PCI slot 2
  PCI Adapter ID (vendor 0x1102, device 0x0004) PCI slot 2
  PCI Adapter ID (vendor 0x1102, device 0x7003) PCI slot 2
  PCI Adapter ID (vendor 0x1102, device 0x4001) PCI slot 2
USB controller: type OHCI
fuel 111% /usr/gfx/gfxinfo
        Managed (":0.0") 1920x1200
        BUZZ version B.2
        PB&J version 1
        128MB memory
                Banks: 4, CAS latency: 3
         Monitor 0 type: DEL -4075
         Video Output: 1920 pixels, 1200 lines, 60.00Hz (1920x1200_60p)
The new picture, both the Octane and the Fuel is up and running, oh I love them so much.
/Jonas
Old polygon wrangler
___________________
http://www.edgeloop.se
mapesdhs
Re: Fuel 600MHz, 2GB RAM, V12, 2x73GB HDD
Unread postby mapesdhs » Wed Feb 25, 2009 6:05 am
Glad to see you received it ok! Packaging alright? Everything intact after its encounter with Schenkers post? :D
For the curious, this unit is the very one shown on my new Fuel page, alongside the section, "Build Style and
Appearance", image snapped just before I began wrapping it for posting.
Ian.
sgtprobe
Unread postby sgtprobe » Wed Feb 25, 2009 6:11 am
Oh yes, Even though Schenkers did their best with my Octane2 you sent me, this one was in extremely good condition. But as with the box my Octane2 came in, they didn't stand a chance against your "nukeproof" packaging. hehe
Oh, yeah. I forgot to thank you for the 400Mhz CPU for my Octane2.. THANKS.!! 8-)
/Jonas
___________________
mapesdhs
Unread postby mapesdhs » Wed Feb 25, 2009 6:14 am
sgtprobe wrote:Oh, yeah. I forgot to thank you for the 400Mhz CPU for my Octane2.. THANKS.!! 8-)
Most welcome! How are you finding it over the dual-195? For Maya rendering a simple scene, a dual-195 is almost the
same speed as a single-400, but for a complex scene with Alias the single-400 is 20% faster. Either way, hopefully it's
a decent boost for interactive use.
Looks like my CPU mod stuff will have to wait until April now though.
Ian.
sgtprobe
Unread postby sgtprobe » Sat Feb 28, 2009 7:15 am
Hello all.
I haven't had that much time with my Fuel yet, but since I have now installed the 400MHz CPU in my Octane2, the Octane2 definitely got a boost in Maya for interactive speed, big difference. But from what I know from my new Fuel, the Fuel is faster still. With the Fuel you don't even think of the fact that you are sitting in front of an old "slow" 3D workstation, That's how snappy it feels. So while the Octane2 now can push a lot more polygons than before it still feels "laggy" compared to the Fuel, or my PC workstation for that matter.
I just wished that I could get that "Fuel feeling" in my Octane2 too, because the Octane2 looks so much more SGI than the Fuel does. :lol: If anyone understand what I'm out after here. :) Maybe a Dual 600MHz CPU module is the answer to this. What do you think Ian?
But overall, I'm really happy with both my Fuel and Octane2 now. I just love them both to bits.
/Jonas
___________________
indyman007
Unread postby indyman007 » Sat Feb 28, 2009 12:27 pm
sgtprobe wrote:fuel 46
Those are a lot of feuls.
lol joking
:Indy: R4600PC 133 MHz
Mac Mini 2.5GHz 8GB RAM
Raspberry Pi
Dr. Dave
Unread postby Dr. Dave » Sat Feb 28, 2009 9:25 pm
Fuel uses DDR memory, so it has much better memory bandwidth than Octane. That's probably the biggest difference - being able to move stuff around faster.
mapesdhs
Unread postby mapesdhs » Mon Mar 02, 2009 1:08 am
That latency is also better, and don't forget the cache is 2X more.
I'm not sure about the dual-600. From all the tests I've done, I suspect the Fuel would still feel snappier. The dual-600 would beat
it for rendering, but then if one was willing to spend that sort of money, it would make more sense to get an O300 instead, have
that for rendering and use the Fuel for modelling.
Ian.
sgtprobe
Unread postby sgtprobe » Mon Mar 02, 2009 3:36 am
Hello :)
Ah, yeah, I guess that the extra bandwidth DDR memory gives, do a lot for the Fuel. Latency does a lot too of course. To bad that you really can't do anything about that on the Octane.
Oh well, at least the Octane can be really fast, just not Fuel fast. So while I can't get the Fuel "feeling" in the Octane, I would suspect that a 600MHz CPU would give me some additional boost, considering how much the 400MHz did for it.
But maybe instead of going for a expensive Dual 600MHz CPU, I might be better of trying to acquire an Onyx2 or something similar, as the "next step" for performance in SGI computing. :lol:
Btw Ian, I took your "Jonas3" Maya scene, and converted it to polygons and combined them. With "Backface culling" on I get about 12-13 Fps compared to 5-6 Fps with the nurbs objects. Quite a difference. :)
/Jonas
___________________
sgtprobe
Re: Fuel 600MHz, 2GB RAM, V12, 2x73GB HDD/new picture
Unread postby sgtprobe » Mon Mar 16, 2009 3:33 pm
Added a new picture to the top subject. The mobilephone photo was just horrible of my Fuel. This one shows all my Sgi's too.. The more the merrier, right :lol:
/Jonas
___________________
geezer
Unread postby geezer » Mon Mar 16, 2009 4:16 pm
Nice pic. When you boil it all down, SGI sure makes a beautiful box. :)
I hope they can hang on this year, its going to be a tough one for them.
:O3000: :O2000R: :Onyx: :O2000: :Indigo: :O2: :Indigo2IMP: :Fuel: :1600SW: :1600SW:
Shoot the wall, leave the birds alone.
sgtprobe
Unread postby sgtprobe » Mon Mar 16, 2009 4:32 pm
geezer wrote:Nice pic. When you boil it all down, SGI sure makes a beautiful box. :)
Thanks geezer. :) Yeah, sometimes I can just stare at them for ages, just for their beauty and remember the days when a collection like this was only a boy's dream. I really hope that Sgi is going to survive, would hate to see them going down the drain and taking a great era with 'em.
Hmmm, looking at the picture, doesn't it look like the Cube logo on the O2 and the VW320 is at the same height? Wonder if the cube logo on the Octane 1 is at the same height aswell?
/Jonas
___________________
japes
Unread postby japes » Mon Mar 16, 2009 4:50 pm
sgtprobe wrote:Hmmm, looking at the picture, doesn't it look like the Cube logo on the O2 and the VW320 is at the same height? Wonder if the cube logo on the Octane 1 is at the same height aswell?
Octane logo is at the bottom of the front cover. Quick google comes up with: http://hardware.majix.org/computers/sgi ... tane.shtml
sgtprobe
Unread postby sgtprobe » Mon Mar 16, 2009 4:59 pm
Yeah, damn.. Thought that there was some smart design element into this. :) Ah well..
But then I looked at the Octane2 and the Fuel's big SGI logo, and it seems they too are at the same height. hehe
I'm not at home this week, otherwise it would be simple to check it out, but it sure does looks like it from the photo. :D
/Jonas
___________________
mapesdhs
Unread postby mapesdhs » Mon Mar 16, 2009 5:04 pm
That's such a nice picture! Very cool! 8)
Ian.
