Fuel prototype (BLUE!)
Unread postby jan-jaap » Mon Dec 08, 2008 6:05 am
Received a Fuel from SGI for development work. I didn't expect to find a *blue* system in the box with 'Asterix prototype' stickers on it.
The power LED is blue -- nice touch :)
hinv -mv
            IP34 Board: barcode MED907     part 030-1707-002 rev -D
        IP34PIMM Board: barcode MDG739     part 030-1708-002 rev -G
         ASTODYB Board: barcode MDG840     part 030-1725-001 rev -D
1 500 MHZ IP35 Processor
CPU: MIPS R14000 Processor Chip Revision: 2.3
FPU: MIPS R14010 Floating Point Chip Revision: 2.3
CPU 0 at Module 001c01/Slot 0/Slice A: 500 Mhz MIPS R14000 Processor Chip (enabled)
  Processor revision: 2.3. Scache: Size 2 MB Speed 250 Mhz  Tap 0xa
Main memory size: 512 Mbytes
Memory at Module 001c01/Slot 0: 512 MB (enabled)
  Bank 0 contains 256 MB (Standard) DIMMS (enabled)
  Bank 1 contains 256 MB (Standard) DIMMS (enabled)
  Bank 2 contains 256 MB (Standard) DIMMS (disabled)
  Bank 3 contains 256 MB (Standard) DIMMS (disabled)
IOC3/IOC4 serial port: tty3
IOC3/IOC4 serial port: tty4
Graphics board: V10
USB controller: type OHCI
Yes, it arrived with half the memory and the environmental monitoring disabled. Thanks guys ;)
/usr/gfx/gfxinfo -v
        Managed (":0.0") 1920x1200
        BUZZ version B.1
        PB&J version 1
        32MB memory
                Banks: 2, CAS latency: 3
         Monitor 0 type: DEL -24553
         Video Output: 1920 pixels, 1200 lines, 60.02Hz (1920x1200_60)
         Video Format Flags:  (none)
         Sync Disabled
         Using Gamma Map 0
/usr/sbin/l1cmd version
L1 1.9.15 (Image B), Built 12/04/2001 16:21:34    [P1 support]
It must use this ancient version because newer PROM images expect something from the PSU that it doesn't provide -- and then the whole system doesn't start!
/usr/sbin/l1cmd env
           12V    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   11.94
        12V IO    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.19
            5V    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.07
          3.3V    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.30
          2.5V    Enabled  10%   2.25/  2.75  20%   2.00/  3.00    2.44
          1.5V    Enabled  10%   1.35/  1.65  20%   1.20/  1.80    1.47
        5V aux    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.04
      3.3V aux    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.29
PIMM0 12V bias    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.25
    PIMM0 SRAM   Disabled  10%   0.00/  0.00  20%   0.00/  0.00    0.00
   Asterix CPU    Enabled  10%   1.44/  1.76  20%   1.28/  1.92    1.61
    PIMM0 1.5V    Enabled  10%   1.35/  1.65  20%   1.20/  1.80    1.49
PIMM0 3.3V aux    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.30
  PIMM0 5V aux    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.10
  XIO 12V bias    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   11.94
        XIO 5V    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.07
      XIO 2.5V    Enabled  10%   2.25/  2.75  20%   2.00/  3.00    2.47
  XIO 3.3V aux    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.30
FAN 0  EXHAUST    Enabled          920         1145
FAN 1       HD    Enabled         1560         2144
FAN 2      PCI    Enabled         1120         1335
FAN 3    XIO 1    Enabled         1600         2171
FAN 4    XIO 2    Enabled         1600         2144
FAN 5       PS    Enabled         1600         1901
                           Advisory  Critical  Fault     Current
Description    State       Temp      Temp      Temp      Temp
NODE 0            Enabled  30C/ 86F  35C/ 95F  40C/104F  28c/ 82F
NODE 1            Enabled  30C/ 86F  35C/ 95F  40C/104F  26c/ 78F
NODE 2            Enabled  30C/ 86F  35C/ 95F  40C/104F  21c/ 69F
PIMM              Enabled  30C/ 86F  35C/ 95F  40C/104F  32c/ 89F
ODYSSEY           Enabled  30C/ 86F  35C/ 95F  40C/104F  22c/ 71F
BEDROCK           Enabled  30C/ 86F  35C/ 95F  40C/104F  28c/ 82F
/usr/sbin/l1cmd serial all
Local System Serial Number      EEPROM        08:00:69:0B:C3:C2
Local Brick Serial Number       EEPROM        MED907
Reference Brick Serial Number   NVRAM         MED907
EEPROM      Product Name    Serial      Part Number           Rev  T/W
NODE        IP34            MED907      030_1707_002          D    00
MAC         MAC ADDRESS     ABC123      030_9999_001          A    00
PIMM        IP34PIMM        MDG739      030_1708_002          G    00
XIO         ASTODYB         MDG840      030_1725_001          D    00
EEPROM      JEDEC Info                Part Number         Rev
DIMM 0      CE0000000000000026BAAE00  M3 46L3313BT1-CA0   0B
DIMM 2      CE0000000000000026C3AE00  M3 46L3313BT1-CA0   0B
DIMM 1      CE0000000000000028C12601  M3 46L3313BT1-CA0   0B
DIMM 3      CE00000000000000269CF500  M3 46L3313BT1-CA0   0B
/usr/sbin/l1cmd pci
INFO: command not support on this brick type
Re: Fuel prototype (BLUE!)
Unread postby hamei » Mon Dec 08, 2008 7:59 am
jan-jaap wrote:Received a Fuel from SGI for development work.
Oh god. Oh god. Please say you're going to fix the firewire problems !!!! ?? Okay, sorry. You don't have to say it. Just paw the ground three times for yes, once for no.
P.S. Them's some big shoes on your neighbor, by the way.
Unread postby jan-jaap » Mon Dec 08, 2008 8:31 am
hamei wrote:Just paw the ground three times for yes, once for no.
Did you feel one? Sorry to disappoint you, this one is for a different project.
Thomas W.
Unread postby Thomas W. » Mon Dec 08, 2008 8:32 am
Nice one... blue :D
:1600SW: :Onyx: :Onyx2: :Indigo: :Indigo: :Indigo: :Indy: :Indy: :Indy: :Indigo2: :Indigo2: :Indigo2IMP: :Indigo2IMP: :Indigo2IMP: :Indigo2IMP: :O2: :O2: :O2: :Octane: :Octane: :Octane2: :Octane2: :Fuel: :Fuel:
bri3d
Unread postby bri3d » Mon Dec 08, 2008 8:51 am
Pretty... shame it doesn't have any logos on it. The debadged look isn't so good for the Fuel (or SGIs in general), imo.
anotherlin
Unread postby anotherlin » Mon Dec 08, 2008 9:27 am
Can you tell us what's all about, unless it's top secret ?
Unread postby jan-jaap » Mon Dec 08, 2008 11:21 am
anotherlin wrote:Can you tell us what's all about, unless it's top secret ?
I don't think my employer (or SGI) would appreciate. But I'll see if I can take some more pictures with my new Nikon D90 and a tripod.
Those skins are solid blue plastic, not a paint job or something ugly like that. I guess it's the Fuel equivalent of the transparent O2, that's why I mentioned it in this forum.
Unread postby guardian452 » Mon Dec 08, 2008 5:56 pm
500mhz with a v10... whats so + about it? Besides, it would be x86 nowadays.
Unread postby hamei » Mon Dec 08, 2008 6:17 pm
jan-jaap wrote:Did you feel one? Sorry to disappoint you, this one is for a different project.
Oh well. At least it's a project, and unless you're gonna get schminux running on that thing it's an Irix project :)
un_
Unread postby un_ » Mon Dec 08, 2008 7:09 pm
I wonder why they sent you that one? Either it was "he'll think this is cool" or they're running out of MIPS h/w and that was what they had to hand.
:540: :Octane: :Octane2: :O2: NeXTStation x 2, A4, A7000, RISC PC
Unread postby josehill » Mon Dec 08, 2008 7:13 pm
sybrfreq wrote:500mhz with a v10... whats so + about it?
...but, it's shiny!
Unread postby hamei » Mon Dec 08, 2008 7:21 pm
un_ wrote: Either it was "he'll think this is cool" ...
Cool guys get cool stuff !
I would expect that they have loaners which they send out so they don't have to dip into the retail stock. That's just a guess tho.
Dr. Dave
Unread postby Dr. Dave » Mon Dec 08, 2008 7:38 pm
Looks like the same colour blue as the Visual Workstations, the ones which are basically in the same case as the Fuel, but ATX-ified. The chassis skins look the same minus the SGI logo.
mmendez
Unread postby mmendez » Tue Dec 09, 2008 12:07 am
That's a nice Fuel :D
SGI: :Indigo2IMP: :Fuel: :O2: :Octane2:
Sun: Ultra2, Ultra60, Sun Fire 4800
Apple: G3, Powermac G4 MDD, PowerMac G5, Mac Mini, iBook G4 12", MBP
Dec 3000
IBM RS/6000
AMD64 FreeBSD box
Unread postby jan-jaap » Tue Dec 09, 2008 7:32 am
sybrfreq wrote:500mhz with a v10... whats so + about it? Besides, it would be x86 nowadays.
This is not a prototype of an upcoming MIPS workstation, it's a Fuel prototype so it's from 2001 or so.
What makes it special are the looks of course. It also has a couple of connectors on the mainboard you won't find in a regular Fuel.
