DNS doozy, is there a 6.5.22m fix for this?
porter
Unread postby porter » Tue Jul 08, 2008 7:17 pm
Bigger than Ben Hur, bigger than Debian's ssh keys,
http://securosis.com/2008/07/08/dan-kaminsky-discovers-fundamental-issue-in-dns-massive-multivendor-patch-released/
Is there a 6.5.22m fix for this?
Re: DNS doozy, is there a 6.5.22m fix for this?
Unread postby nekonoko » Tue Jul 08, 2008 7:38 pm
I updated BIND9 in Nekoware with the fix.
porter
Unread postby porter » Tue Jul 08, 2008 8:21 pm
Does that replace standard the client resolver library? Or is it a server only fix?
Unread postby nekonoko » Tue Jul 08, 2008 8:35 pm
It's the standard BIND server package with the required patch.
porter
Unread postby porter » Tue Jul 08, 2008 9:44 pm
nekonoko wrote:It's the standard BIND server package with the required patch.
Sorry to be pedantic, but is this a "neko_bind" or does this actually replace the resolver used by SGI compiled programs?
Unread postby nekonoko » Tue Jul 08, 2008 9:53 pm
It's neko_bind of course, but my understanding is that by running a local caching nameserver, the local resolver won't need to reach out to a malicious source. At least that was my interpretation of:
Run a local DNS cache
In lieu of strong port randomization characteristics in a stub resolver, administrators can protect their systems by using local caching full-service resolvers, both on the client systems and on servers that are topologically close on the network to the client systems, in conjunction with the network segmentation and filtering strategies mentioned above.
http://www.kb.cert.org/vuls/id/800113
This is, of course, what I do here.
mgtremaine
Unread postby mgtremaine » Thu Jul 10, 2008 9:20 am
I saw this test floating around another list it is worth having.
https://www.dns-oarc.net/
dig +short porttest.dns-oarc.net TXT
In windows you can use nslookup
> nslookup
> set type=txt
All the linux boxes I patched are fine [yeah!] but the Solaris 10 box I did yesterday is still poor [it did ask for reboot so as soon as I do that I hope it fixes up.] You can try the nslookup under IRIX to see if your server/workstation is ok.
-Mike
Unread postby nekonoko » Thu Jul 10, 2008 9:29 am
Cool, my IRIX systems came back with GOOD on that test :)
Unread postby SAQ » Mon Aug 04, 2008 10:18 pm
It's coming up on a month - any news of a SGI patch for any IRIX version?
mgtremaine
Unread postby mgtremaine » Tue Aug 05, 2008 7:37 am
"IRIX? Never heard of it." Says the SGI salesman. :)
-Mike
Unread postby SAQ » Tue Aug 05, 2008 7:56 am
I suppose that technically you're unlikely to run into any future issues if you install the Nekoware BIND and run links to the IRIX BIND - after all the future upgrades potential of IRIX is limited, but there's a part of me that wants to keep it as original as possible.
porter
Unread postby porter » Tue Aug 05, 2008 11:18 am
I was under the impression this also required a client fix (so that the magic number in the DNS packet sent was randomized rather than incremented) so that would need a change to libc.so and/or libnsl.so.
Unread postby josehill » Tue Aug 05, 2008 5:27 pm
Might be worth it if a Nekochanner with a service contract opens a case just to get the scoop on when/whether there will be an official fix or a workaround. Unfortunately, I let my contract lapse a little while ago...
Unread postby josehill » Wed Aug 06, 2008 1:07 pm
porter wrote:I was under the impression this also required a client fix (so that the magic number in the DNS packet sent was randomized rather than incremented) so that would need a change to libc.so and/or libnsl.so.
Brief discussion of this in the OS X Leopard context at http://db.tidbits.com/article/9721 , presumably IRIX could be similar.
Unread postby hamei » Mon Sep 29, 2008 2:42 am
nekonoko wrote:Cool, my IRIX systems came back with GOOD on that test :)
Heh heh
text = "208.67.219.13 is GREAT: 26 queries in 0.1 seconds from 26 ports with std dev 18595"
Return to “SGI: Security”
