OpenSSH 3.8p1 -- where is sshd?
franklynb
Unread postby franklynb » Mon Jun 23, 2008 6:31 am
I installed <SW Mgr> openssh 3.8p1 from binaries on Octane, 6.5.21, 2x270-R10.
SWMgr reports that 'sshd was removed' apparently <from timestamp> at installation time.
Anyone have an idea why this would happen?
thanks, and best regards.
--frankb
Re: OpenSSH 3.8p1 -- where is sshd?
Unread postby jan-jaap » Mon Jun 23, 2008 7:22 am
The openssh.sw.server subsystem is not installed by default.
franklynb
Unread postby franklynb » Mon Jun 23, 2008 8:17 am
thanks. There appears to be no way of telling SW Mgr to "Add this subsystem" to my installation ... so do I need to uninstall it compeletely, and re-install it? Where is the configuration parameter set to instruct SWMgr to "do what i want"?
--f
jan-jaap wrote:The openssh.sw.server subsystem is not installed by default.
joerg
Unread postby joerg » Mon Jun 23, 2008 9:19 am
franklynb wrote:thanks. There appears to be no way of telling SW Mgr to "Add this subsystem" to my installation ... so do I need to uninstall it compeletely, and re-install it? Where is the configuration parameter set to instruct SWMgr to "do what i want"?
Under "PANES" there is a "commandline" switch which gives similar power like the inst tool.
inst -f /path/to/all/of/my stuff
keep *
install openssh.sw.server
install prereq
go
14
You may consider to upgrade to 6.5.22 and start with nekoware rather than SGIs freeware. Most of the packages a much newer.
regards
Joerg
--f
Return to “SGI: Security”
