Realsoft 3D Demo for IRIX
nvukovlj
Unread postby nvukovlj » Mon Jul 26, 2004 2:45 am
unixmuseum wrote:Octane2 V10, 6.5.24... Dodwnloaded and installed, had to put /usr/local/realsoft3d/lib in LD_LIBRARY_PATH to get the "rld: Fatal Error: Cannot Successfully map soname 'libr3wid2.so'" taken care of
Interesting... the LD_LIBRARY_PATH should be set by realsoft3d script...
unixmuseum wrote:
nvukovlj wrote:When you start the program, does the main view window look normal, or is it in multiple colours ?
Multiple colors...
nvukovlj wrote:Likewise, the leftmost window should be white colour - is it white on your machine ?
Pure yellow...
nvukovlj wrote:What happens on switching to OpenGL - button on the right side that looks like a grey boulder
The graphics window shows up as it should be, no more patchwork...
Thanks for this. Pretty much confirms there is a bug in the routines there...
Nik.
Bluefan
Unread postby Bluefan » Tue Jan 17, 2006 11:02 am
I gave realsoft 3d a try, but got this:
x bin/Realsoft3D, 91092 bytes, 178 blocks
gzip: stdin: invalid compressed data--format violated
./setup[84]: /usr/local/realsoft3d/resources/Realsoft3D: cannot create: No such file or directory
./setup[86]: /usr/local/realsoft3d/resources/R3RendD: cannot create: No such file or directory
Can't open /usr/local/realsoft3d/realsoft3d
./setup[146]: /usr/local/realsoft3d/resources/Realsoft3D: cannot create: No such file or directory
Cannot access windows: No such file or directory
Cannot access resources/startup.r3d: No such file or directory
while executing
"close $pipe"
invoked from within
"if { [eof $pipe] } {
close $pipe
} else {
after 500 "insert_text $w $pipe"
(procedure "insert_text" line 8)
invoked from within
"insert_text .rightframe.workframe.options.fin.st.text file5"
("after" script)
I think it's something stupid I forgot/haven't got.
:O2:Toika :O2:Myra :O2:Fiona :Octane:Lisa :Octane:Sandra :Indigo2:Danica :Indy:Giana :O200:Lara :O200: :O200:Iona :O2000:Aida
Unread postby foetz » Tue Jan 17, 2006 12:24 pm
Bluefan wrote:I gave realsoft 3d a try, but got this:
while executing
"close $pipe"
invoked from within
close $pipe
} else {
invoked from within
("after" script)
mkdir -p /usr/local/realsoft3d/resources/Realsoft3D
Bluefan
Unread postby Bluefan » Wed Jan 18, 2006 6:28 am
after that, it gives me:
./setup[84]: /usr/local/realsoft3d/resources/Realsoft3D: cannot create: Is a directory
Can't open /usr/local/realsoft3d/resources/R3RendD.ad
./setup[146]: /usr/local/realsoft3d/resources/Realsoft3D: cannot create: Is a directory
while executing
"close $pipe"
invoked from within
close $pipe
} else {
invoked from within
"insert_text .rightframe.workframe.options.fin.st.text file6"
("after" script)
strange...
Unread postby foetz » Wed Jan 18, 2006 8:02 am
Bluefan wrote:after that, it gives me:
while executing
"close $pipe"
invoked from within
close $pipe
} else {
invoked from within
("after" script)
strange...
ah okay then just strip the last dir.
silicium
Re: Realsoft 3D Demo for IRIX
Unread postby silicium » Sun Jun 21, 2009 7:23 am
Oops... old thread !
The 5.1.26 SP1 demo seems to run on Octane2 V6 6.5.30, and IRIX licensing seems to be still available on Realsoft Web Shop. Is it worth buying for a 3D beginner (and SGI lover) ?
:Indigo2IMP:extreme :Octane2:V8 :O200: :Onyx2:IR2e
