Octane segfault on boot
holgrrr
Unread postby holgrrr » Thu May 10, 2007 2:20 am
Hi everybody!
I'm currently running into some weird problems with an Octane (hardware specs attached) which I recently added to my "hardware zoo" ;-)
I installed Irix 6.5.29f on it, which worked fine from CD - but after the initial reboot after the installation it crashes with a segfault:
PANIC: KERNEL FAULT
PC: 0xa800000020369d4 EP:0xffffffffffffbc48
EXC: Code: 128, 'Software detected SEGV'
Bad addr: 0x3e8, cause: 0x8<CE=0
Any guesses anyone?
I'm currently a bit "desperate", as the systems tests complete and show no errors and my search didn't point me the right direction...
Any help appreciated - thanks a lot in advance!
Best wishes,
Holger
Hardware:
Octane
300Mhz R12000SC
1,5 GB RAM
SI Graphics
9 GB SCSI harddisk
regan_russell
Re: Octane segfault on boot
Unread postby regan_russell » Thu May 10, 2007 2:37 am
Hi Holger,
Have you tried different options on install?
If you have another SGI... can you mount the drive in it and read the syslog file..??
Good luck.
Regan
holgrrr wrote:Hi everybody!
PANIC: KERNEL FAULT
Any guesses anyone?
Best wishes,
Holger
Hardware:
Octane
300Mhz R12000SC
1,5 GB RAM
SI Graphics
9 GB SCSI harddisk
:Onyx2R: :Onyx2R: :0300: :0300: :0300: :O200: :Octane: :Octane: :O2: :O2: :Indigo2IMP: :Indy: :Indy: :Indy: :Indy: :Indy: :Indy: :Indy: :Indy:
:hpserv: J5600, 2 x SUN, 2 x Mac, 3 x Alpha, 2 x RS/6000
Unread postby foetz » Thu May 10, 2007 5:42 pm
do you have any 3rd party hardware connected?
holgrrr
Topic closed
Unread postby holgrrr » Fri May 11, 2007 1:14 am
Problem "solved":
The SI was broken.
This came rather unexpected as it "survived" the self-test...
Replaced it with an ESI I could "borrow" from another Octane, now everything is working again!
But thanks a lot for your help!
Best whishes,
Holger
