DJV Imaging 0.6.0 Beta
dj
Unread postby dj » Sat Apr 07, 2007 4:51 pm
Hi everyone,
Just released a new beta version of my imaging software; if anyone is interested in giving it a try I would very much welcome feedback. The software comes with a number of applications:
* djv_view - Image and movie viewer.
* djv_vlut - Video lookup table control.
* djv_convert - Image conversion utility.
* djv_info - Image infomation utility.
* djv_ls - Directory listing utility.
Features include support for extended range images and industry file formats like DPX, OpenEXR, and experimental support for QuickTime.
There's a tardist on my sourceforge page for easy installation on IRIX; the only dependencies you need are libiconv from nekoware if you want to use the QuickTime stuff. Otherwise, just run inst, maybe type rehash, and that's it.
Sorry there's not much documentation yet :). If you have any questions, please feel free to ask...
Homepage: http://djv.sourceforge.net
Some screenshots: http://djv.sourceforge.net/screenshots.html
Downloads: http://sourceforge.net/project/showfile ... _id=118244
Unread postby nekonoko » Sat Apr 07, 2007 9:37 pm
I added this to the blog page. Thanks!
GIJoe
Unread postby GIJoe » Mon Apr 09, 2007 7:29 am
cool to see that you are still developing this! will try the new version soon.
Unread postby foetz » Mon Apr 09, 2007 10:40 am
getting it right now. thanks :D
GIJoe
Unread postby GIJoe » Mon Apr 09, 2007 2:48 pm
ok, i had a quick look at the image viewer - notes below
- i was missing the '..' entry in the filebrowser window. i know you have an icon for going up in the tree but it's something very common in other apps, might make sense to add it to speed up navigation.
- seems extremely unresponsive when i open a sequence in rgba/u8 format, regardless of filetype, everything slows down to a crawl
- bombs with segfault when a certain .mov file is in the directory (mplayer shows it as 'mjpa' format) and is quite slow or hangs (with codecs warning in the shell) as soon as you open up a directory full of video files (all kinds of formats). i'll install that libiconv and see if it makes a difference.
not sure which direction you intend to go with this app but if it's a sequence viewer, shouldn't it just ignore the video files? i'd suggest to put in a functionality where the user can specify the path to his preferred video player - and invoke that when a movie is opened.
otherwise i quite like it! adjustable gui colors, unobtrusive interface. seems very zippy (tested on dual600) as well. however, i only tested with SD/8bit files so far.
dj
Unread postby dj » Mon Apr 09, 2007 3:33 pm
Thanks for trying it out...
GIJoe wrote:- i was missing the '..' entry in the filebrowser window. i know you have an icon for going up in the tree but it's something very common in other apps, might make sense to add it to speed up navigation.
Good point; I'll add that back in.
GIJoe wrote:- seems extremely unresponsive when i open a sequence in rgba/u8 format, regardless of filetype, everything slows down to a crawl
That surprises me; I've spent some time optimizing the I/O so it should be quite fast. Can you give me some more details about the images, like file type and resolution? Also, did you have any of the tool windows open, like the histogram?
GIJoe wrote:- bombs with segfault when a certain .mov file is in the directory (mplayer shows it as 'mjpa' format) and is quite slow or hangs (with codecs warning in the shell) as soon as you open up a directory full of video files (all kinds of formats). i'll install that libiconv and see if it makes a difference.
If you don't have libiconv installed it shouldn't try and do anything with the movie files. Do you happen to have a library called "libquicktime" installed somewhere?
GIJoe wrote:not sure which direction you intend to go with this app but if it's a sequence viewer, shouldn't it just ignore the video files? i'd suggest to put in a functionality where the user can specify the path to his preferred video player - and invoke that when a movie is opened.
It is primarily meant for viewing image sequences, but I thought some movie support would be nice; it's definitely not meant as a general purpose media player though.
GIJoe wrote:otherwise i quite like it! adjustable gui colors, unobtrusive interface. seems very zippy (tested on dual600) as well. however, i only tested with SD/8bit files so far.
Do you work with any DPX images?
matt510au
Unread postby matt510au » Tue Apr 24, 2007 9:22 am
installed under Fedora Core 6 no problems
djv_view - works no problem quite fast DPX files of a san
djv_convert - havent used yet
djv_info - no problem
all other seem OK as well
The only thing im not sure on is djv_vlut. How is this supposed to be used?
dj
Re: DJV Imaging 0.6.0 Beta
Unread postby dj » Tue Apr 24, 2007 1:49 pm
matt510au wrote:installed under Fedora Core 6 no problems
Good to hear, thanks. I'm currently compiling the linux version on CentOS 4.
matt510au wrote:djv_view - works no problem quite fast DPX files of a san
Great! If you don't mind me asking, what resolution images were you using and how fast did it playback?
matt510au wrote:djv_convert - havent used yet
It's handy for making tv-res quicktime movies of your DPX files:
> djv_convert 00001-10000.dpx output.mov -scale 640 480
matt510au wrote:The only thing im not sure on is djv_vlut. How is this supposed to be used?
It allows you to interactively change the lookup table on your video card. This can help with calibrating monitors or just used as a quick way to adjust the color when looking at images. The interface is still a bit wonky, I'm open to suggestions on how to make it more intuitive.
Thanks for the feedback; I'll have a minor update hopefully later this week that's got even faster DPX I/O and also support for Cineons.
matt510au
Unread postby matt510au » Fri Apr 27, 2007 7:48 am
hi dj,
Looking at 2k and 4k images. (dpx)
djv_view doesnt like .cin files, .mov
playback off a san 10gig connection ,around 5.3 frames per sec.
Not to bad considering the files sizes. will try some small dpx locally and see if I can get 24 fps.
djv_convert sounds interesting. might have to have play around with that
djv_vlut, thoughts thats what it did, need to be able to reset back to default if you change it.
I thought it may have been used for displaying a lut in a graph/curve field etc..
Nice work man will see what i can do with djv_convert, currently use CleanerXL for this type of thing but you never know
Matt
dj
Unread postby dj » Fri Apr 27, 2007 8:38 am
matt510au wrote:djv_view doesnt like .cin files, .mov
Cineon support will be in the next release. Quicktime support on UNIX is fairly limited right now; mostly just uncompressed movies and motion-jpeg. It's not meant so much for general purpose playback but as a way to rip image sequences into movies for other systems.
matt510au wrote:playback off a san 10gig connection ,around 5.3 frames per sec.
Hopefully the next version will be about 2x faster. Can you play back real-time 2k with your other software?
matt510au wrote:djv_vlut, thoughts thats what it did, need to be able to reset back to default if you change it.
Couple of ways to do that: "Reset" from the "VLUT" menu, hit the backspace key, or those little "x" buttons on the right side of the interface.
matt510au wrote:I will see what i can do with djv_convert currently use CleanerXL for this type of thing but you never know
Let me know if you have any suggestions for the converter; for instance right now I'm adding a "film scanner" mode for someone else so it waits for each frame before processing. Haven't heard of cleaner, I'll check it out. Thanks!
ka0s
Unread postby ka0s » Mon Apr 30, 2007 5:43 am
I love it !!!!
Like the file browser and the standard scale option for 16:9 an 2.35 !!!
Just can't get the full framerate of 25 frames when trying to play a .tga sequence on my Octane2
R12k 400 MHz with V10.
Cheers and keep up the good work for the Unix community ( specially Irix )
I can feel it, my mind is going ....
squeen
Unread postby squeen » Mon Apr 30, 2007 6:13 am
One comment on the IRIX download. The tardist format is already compressed, so I imagine the size difference by making a tardist.gz in minimal.
dj
Unread postby dj » Mon Apr 30, 2007 10:14 am
ka0s wrote:I love it !!!!
Thanks!
ka0s wrote:Just can't get the full framerate of 25 frames when trying to play a .tga sequence on my Octane2
I'm currently doing all the image transformations in C++, which I thought would be good for portability, but is maybe not so good for speed. I'm thinking of converting it all to OpenGL which should really fly.
But in the meantime, I'll have a minor update in a day or two which should be slighly faster (forgot to enable memory mapping on the current version, doh).
squeen wrote:One comment on the IRIX download. The tardist format is already compressed, so I imagine the size difference by making a tardist.gz in minimal.
Good point :). Force of habit I guess.
dj
Unread postby dj » Thu May 03, 2007 7:22 pm
Hi,
Just a small bump to let everyone know I have a new release out; this one includes support for Cineon images and faster DPX image I/O.
Thanks for all the feedback!
ka0s
Unread postby ka0s » Sun May 06, 2007 3:55 am
It's faster then version 0.6.0 for sure.
I now get more then 32 frames when playing a standard tga sequence.
But it can only do 5 frames a second when I try the scale to 16x9 option on a 720x576 anamorph tga sequence.
Nice work !!!!
I hope the OpenGL will take advantage of the V10 Hardware cause that should be fast enough for sure !)
