Octane2 with V8 and ESI
Zerolapse
Unread postby Zerolapse » Sat Nov 18, 2006 12:41 pm
Hello all,
I didn't see much info on this while searching through the forums, so if this is a repeat I apologize in advance, but in case it isn't here we go....
I am running an Octane2 with both a V8 and an ESI board. I am told this is an unsupported configuration but it seems to work nicely!! It took a little bit to get it working, namely I only had OpenGL and thus MPlayer, Quake3, etc on the ESI driven monitor (worked intermittently and not much fun). So....I got it to switch over to the V8 by re-symlinking libGL.so and libGLcore.so in:
/var/arch/lib
/var/arch/lib32
/var/arch/lib64
To the ones present in:
/usr/gfx/arch/IP30ODSY
/usr/gfx/arch/IP30ODSY32
/usr/gfx/arch/IP30ODSY64
respectively. After that I didn't even need a reboot and everything just worked. It would seem that the only drawback is that I can't have OpenGL on both screens, but that's fine with me, I'm using the other one for gaim, firefox, etc. You CAN also run at different refresh rates across the two monitors too, so don't worry about that.
To get it running from scratch install the XiO card load IRIX from or boot into the miniroot and do:
keep *
install fresh
This will add the additional drivers you need for the extra card. After it reboots do the fix described above and if your machine works as well as mine did you should be all set! Additionally, you can do:
chkconfig -f xinerama on
to enable xinerama (desktop spanned across both monitors) which also seems to work great.
Let me know if this works for anyone else.
Here's the info on my machine:
# uname -R
6.5 6.5.30f
# hinv -mv
      PM10600MHZ Board: barcode MCY566     part 030-1774-002 rev  A
            IP30 Board: barcode JPE588     part 030-1467-001 rev  C
             FP1 Board: barcode LZF537     part 030-0891-003 rev  H
    PWR.SPPLY.ER Board: barcode AAE1020875 part 060-0035-002 rev  A
          ODY128 Board: barcode KWM926     part 030-1404-003 rev  A
           MOT10 Board: barcode JHV680     part 030-1241-002 rev  H
1 600 MHZ IP30 Processor
Heart ASIC: Revision F
Main memory size: 2048 Mbytes
Xbow ASIC: Revision 1.4
  CDROM: unit 2 on SCSI controller 1
Graphics board: V8
Graphics board: ESI
# /usr/gfx/gfxinfo
        BUZZ version A.1
        PB&J version 1
        128MB memory
                Banks: 4, CAS latency: 3
         Monitor 0 type: Unknown
         Video Output: 1280 pixels, 1024 lines, 100.00Hz (1280x1024_100s)
        Managed (":0.1") 1280x1024
        VC3 rev A, CMAP rev F, Heart rev F
         Video Output: 1280 pixels, 1024 lines, 75.92Hz (1280x1024_76_32db)
Zerolapse
Re: Octane2 with V8 and ESI
Unread postby Zerolapse » Mon May 11, 2015 12:20 pm
That was quite the post dredge.
The current fleet.
