a few tardists
schleusel
a few tardists
Unread postby schleusel » Sat Nov 01, 2003 2:04 pm
Hi,
i've packaged some of of the things i built lately and thought i'd share them:
1. MLDonkey 2.5-4
MLDonkey (http://www.nongnu.org/mldonkey/) is a popular client for several p2p networks. (eDonkey, Fasttrack, BitTorrent, Open Napster, Soulseek, Direct-Connect are activated in this build). Took me quite a while to get it running properly instead of just throwing bus errors all the time but it seems to be quite stable now. You should create some workdir for it inside your home directory and start it from within there to prevent it from dumping all its ini-files directly into your home dir..
http://www.kanera.de/irix/MLDonkey-2.5-4_mips3.tardist (mips3)
needs: fw_gtk+, fw_glib, fw_gettext
2. ObjectiveCaml 3.07 + lablgtk
as MLDonkey is written in ObjectiveCaml (http://caml.inria.fr/), I had to build that one too. Not sure if its of interest to many people but here we go:
http://www.kanera.de/irix/OCaml-3.07_mips3.tardist (mips3, built with gcc 3.3)
3. Sylpheed-Claws 0.9.6
Sylpheed-Claws is the "cutting edge" branch of sylpheed and adds quite a few features the original sylpheed doesn't have yet: http://sylpheed-claws.sourceforge.net/features.php
http://www.kanera.de/irix/Sylpheed-Claws-0.9.6_mips3.tardist (mips3, built with MipsPro 7.4.1m)
compiled with openssl and gnupg support. needs: fw_gettext, fw_glib, fw_gtk+, fw_openssl
I didn't include fw_gnupg as prereq as it still runs without that one (just with disabled gpg support)
4. Lame 3.93.1
Lame (http://lame.sourceforge.net/) is a very powerfull mp3 encoder. I know that there already is a package of that version on nekochan but it still might be of interest to some as its built with MipsPro 7.4.1m and turned out to be a bit faster than the gcc 3.x compiled one:
the gcc build:
Encoding as 44.1 kHz 320 kbps stereo MPEG-1 Layer III (4.4x) qval=2
Frame | CPU time/estim | REAL time/estim | play/CPU | ETA
10062/10064 (100%)| 1:17/ 1:17| 1:27/ 1:27| 3.4065x| 0:00
this one:
10062/10064 (100%)| 1:07/ 1:07| 1:16/ 1:16| 3.9207x| 0:00
so it encodes 320kbit/s mp3 at about 4x realtime on r12k-300, not bad :-)
http://www.kanera.de/irix/Lame-3.93.1_mips4.tardist (mips4, built with MipsPro 7.4.1m)
so long,
Timo
Unread postby dexter1 » Sun Nov 02, 2003 2:46 am
Thanks for the nice tardists! I've put a blog entry on the main page
Hakimoto
Unread postby Hakimoto » Sun Nov 02, 2003 3:40 am
Cool... little question though: Did you get sylpheed claws to compile with iconv support? If so, what variables did you set for the build process?
Thanks.
grace, elegance and style.
schleusel
Unread postby schleusel » Sun Nov 02, 2003 4:34 am
dexter1 wrote:Thanks for the nice tardists! I've put a blog entry on the main page
Thanks! Could you add a link to this forum thread for further information?
Hakimoto wrote:Cool... little question though: Did you get sylpheed claws to compile with iconv support? If so, what variables did you set for the build process?
hmm, it compiled right out of the box with iconv support. What problem are you seeing?
so long,
Timo
squeen
Unread postby squeen » Mon Nov 03, 2003 3:48 am
I for one am happy to see a faster lame. I wouldn't have thought the compiler differenece would be so pronounced. Thanks!
schleusel
Unread postby schleusel » Mon Nov 03, 2003 5:32 am
Hi,
as squeen pointed out, the version reflected by lame tardist was wrong (dumb typo). The packaged version is of course 3.93.1 and not 3.91.1. I renamed the tardist and edited above announcement. Could someone please change the blog entry accordingly?
so long,
Timo
Hakimoto
Unread postby Hakimoto » Mon Nov 03, 2003 6:17 am
I always tried over and over again to compile sylpheed (not claws) with iconv support, recompiling iconv and gettext from scratch etc. and never got it to work. Strange. Maybe it´s claws.
Unread postby dexter1 » Tue Nov 04, 2003 12:17 am
schleusel wrote:HI renamed the tardist and edited above announcement. Could someone please change the blog entry accordingly?
Just did that.
squeen
Unread postby squeen » Tue Nov 04, 2003 3:49 am
Getting all your ducks in a row with these tardists can be a real bitch -- I have alot of respect for the SGI freeware voluenteers.
LoWeN
Unread postby LoWeN » Mon Nov 17, 2003 5:26 am
Hello,
I have tried to install the lame tardist.
I have the doc , the include, the man...
But where is the binary???
I try to install this on my R4400 indigo2...
LoWeN
UX powered
vegac
Unread postby vegac » Mon Nov 17, 2003 7:24 am
That build of LAME he posted is a MIPS4 binary (r5k, r10k, r12k, etc.). your r4400 is only mips3, and therefore won't be able to run it.
Best option would be find out what he did to compile it and reproduce that work but with -mips3 set instead of -mips4
