firewall: irix or openbsd
gcb
Unread postby gcb » Sat Oct 07, 2006 7:05 pm
I have one dying Pentium133. it have been my trust firewall and lame web server (http, mysql, ssh) for years.
I have two boxes available: another pentium133 with openBSD and a Indy R4k with irix6.5 (just the plain foundations discs instaled yet, but i have the 6.5.22 discs somewhere)
I confess i've only used irix to run visualization programs, i don't even know how to start seting it up as a firewall. Is it a good idea?
Unread postby josehill » Sat Oct 07, 2006 7:55 pm
While there are some docs on the net about securing IRIX and configuring ipfilters, I'd go with OpenBSD for a firewall -- clear track record, excellent documentation, secure "by default", and so on. I'm not saying that it's impossible to use IRIX as a firewall system, just that it will take a lot more effort and knowledge to secure it and to keep it secure.
firewall
Unread postby SAQ » Sat Oct 07, 2006 8:17 pm
Especially considering that with IP24 you're limited to IRIX 6.5.22 and down, and no new security patches are being built for those releases (patches are only verified on current release c, c-1, c-2, c-3).
Another good reason is that you are experienced building firewalls in xBSD. You could have some problems if you're learning on something that security-critical :shock:. Not will, just could, and there's no reason to risk it. Have some fun with the Indy instead.
gcb
Unread postby gcb » Thu Oct 12, 2006 4:37 pm
Thanks for the tips! i've just realised also that i only have one network interface in the indy :) so it's not really an option. Well, back to try to make it display full screen mpeg video then... eventualy... damn procrastination!
maverickbna
Re: firewall: irix or openbsd
Unread postby maverickbna » Thu Sep 18, 2008 11:18 am
You may be interested in the m0n0wall and pfsense projects. They're both embedded distributions based on FreeBSD.
http://www.m0n0.ch/
http://www.pfsense.org/
They should work on a P133, but I haven't tried it on that old of a system. I have a converted thin client running m0n0wall based on a Geode 300MHz processor.
It may be worth a try. Good luck in whatever you choose.
End of line.
:Octane: (SGI Octane, 175MHz R10000, 512MB RAM, hard disk pulled, will be working on further)
:O2: (SGI O2, 195MHz R10000, 384MB RAM, 4GB SCSI disk with IRIX 6.5)
:Indy: (SGI Indy, 150MHz R5000SC, 16MB RAM, two 4GB disks running IRIX 5.3)
:Indigo2IMP: (SGI Indigo2 Extreme, 200MHz R4400SC, 128MB RAM, 9GB disk with IRIX 6.5, will upgrade RAM, processor and graphics to MaximumIMPACT)
HP ProLiant DL360 G3 - dual Intel Xeon 2.8GHz, 2.5GB RAM, Ultra320 SCSI
Looking at obtaining more SGI hardware again!
noisetonepause
Unread postby noisetonepause » Thu Sep 18, 2008 10:18 pm
The only thing secure about IRIX is that it's so old nobody remembers how to break it...
No, seriously. Go for OpenBSD. You'll love it.
mmendez
Unread postby mmendez » Sat Sep 27, 2008 12:21 am
$DEITY knows I love IRIX but its security features are a joke. Go OpenBSD, you won't regret it.
SGI: :Indigo2IMP: :Fuel: :O2: :Octane2:
Sun: Ultra2, Ultra60, Sun Fire 4800
Apple: G3, Powermac G4 MDD, PowerMac G5, Mac Mini, iBook G4 12", MBP
Dec 3000
IBM RS/6000
AMD64 FreeBSD box
toxygen
Unread postby toxygen » Wed Dec 03, 2008 8:44 am
out of curiosity, how much electricity does indy r4k draw?
:Indigo2IMP: :Octane: This post was typed using dvorak keyboard layout - http://www.dvzine.org
Oko
Unread postby Oko » Wed Dec 03, 2008 10:22 am
Security by obscurity ;) OpenBSD + SGI hardware for firewall is kick ass combination
but SUN hardware is also a good choice as Risk architecture are less prone to buffer overflows(not that any is know for OpenBSD but still).
I would try to avoid i386 hardware for firewall just because every idiot now is playing with it hardware.
On the another hand if you want to save money on your electric bill fanless MiniITX mother boards are great way to go. They run i386 however.
Unread postby SAQ » Wed Dec 03, 2008 1:56 pm
The new x86s have execute disable, and with a well-built firewall there won't be many holes to get into anyway. Indeed, a case could be made favoring a big arch (x86, SPARC, probably AXP), as more people will be looking for the little issues and fixing them, and while very few issues will be platform-dependant, you know the x86 ones will be found and fixed. Just keep on top of things and you'll be fine.
The big downside with many workstations as firewalls (especially old workstations) is finding the second network interface. Indigo/Indy really looses out there. Sbus is pretty common, but it's hard to argue with a well-built PCI PC (emphasis on well-built, junk H/W will make your life miserable with problems).
noisetonepause
Unread postby noisetonepause » Wed Dec 03, 2008 5:09 pm
toxygen wrote:out of curiosity, how much electricity does indy r4k draw?
I think I measured mine to be in the 50-60W range with a newish 15k RPM disk.
Nihilus
Unread postby Nihilus » Sun Dec 21, 2008 6:49 am
Scrap the pentium and use NetBSD on the Indy ;)
SGI Systems: R4K :Indigo:/256MB/XS-24, R5K 150MHz :Indy:/160MB/XL-24, R10K 175MHz :O2:/640MB, R12K 400MHz :Octane2:/Vpro6/1GB & R4K 250 MHz :Indigo2IMP:/128 MB/XZ Extreme/GIO64 FDDI
"It's a UNIX system! I know this! "
porter
Unread postby porter » Mon Dec 22, 2008 5:52 pm
Oko wrote:Risk architecture
do you mean RISC?
Oko wrote:... are less prone to buffer overflows
Do they not use return addresses on the stack?
Unread postby guardian452 » Mon Dec 22, 2008 6:33 pm
Why not go with a small and cheap linksys or netgear (or similar) router?
jade_angel
Unread postby jade_angel » Fri Dec 26, 2008 5:39 am
do you mean RISC?
Mostly, it's that most buffer-overflow-based shellcode exploits use x86 opcodes in their trickery, this will just explosively segfault on a MIPS or other non-x86. I once built a webserver using a SPARC machine in part because of this. (The customer in question wanted Apache+Solaris+Postgresql+Python regardless of arch, though.)
Return to “SGI: Security”
