[How-To] Add pictures to the visual login screen
fu
Unread postby fu » Fri Sep 22, 2006 1:03 pm
...i bet i'm stuck to something very basic, but i'm quite dizzy right now and i'd appreciate some help...
following Gerhard Lenerz's tips:
Use chkconfig to make sure that visuallogin is set to on and noiconlogin to off. The icons (SGI RGB format, at least 100x100 pixels) can be placed in the following locations:
/$HOME/.icons/login.icon
/usr/lib/faces/$USER
/usr/local/lib/faces/$USER
$USER is the loginname of the user, $HOME the home directory.
there was no "faces" directory under /usr/lib/ nor /usr/local/lib so i created 'em and copyied the image file over there:
o2 1# ls /usr/lib/faces/fu
mad_127_100.rgb
o2 2# ls /usr/local/lib/faces/fu
mad_127_100.rgb
o2 3#
my chkconfig looks like:
o2 3% chk
        Flag                 State
        acct                 off
        appletalk            off
        array                off
        audit                off
        autoconfig_ipaddress off
        autofs               on
        automount            off
        cesag                off
        cluster              off
        desktop              on
        esp                  off
        fcagent              off
        fontserver           off
        gated                off
        grio                 off
        grio2                off
        ipaliases            off
        isdnd                off
        ldap                 off
        lockd                on
        lp                   on
        mediad               on
        mrouted              off
        named                off
        nds                  off
        neko_sshd            on
        network              on
        nfs                  on
        nfsd                 on
        noiconlogin          off
        nostickytmp          off
        ns_admin             off
        ns_fasttrack         off
        nsd                  on
        pam                  off
        pmcd                 off
        pmie                 off
        privileges           off
        proclaim_relayagent  off
        proclaim_server      off
        proxymngr            off
        quickpage            off
        rarpd                off
        routed               off
        rsvpd                off
        rtmond               on
        rwhod                off
        sar                  off
        savecore             on
        sdpd                 off
        sendmail             off
        sendmail_cf          off
        sesdaemon            off
        sgi_apache           on
        snetd                off
        soundscheme          on
        sshd                 off
        tfxd                 off
        timed                off
        timeslave            off
        ts                   off
        verbose              on
        visuallogin          on
        vswap                off
        webface              off
        webface_apache       off
        windowsystem         on
        xdm                  on
        xlv                  off
        yp                   off
        ypmaster             off
        ypserv               off
o2 4% uname -aR
IRIX o2 6.5 6.5.26m 10060437 IP32
o2 5%
..any tips..?
Re: Adding pictures to the visual login screen
Unread postby nekonoko » Fri Sep 22, 2006 1:09 pm
fu wrote:there was no "faces" directory under /usr/lib/ nor /usr/local/lib so i created 'em and copyied the image file over there:
mad_127_100.rgb
mad_127_100.rgb
o2 3#
You need to rename the image file so it matches your login name, i.e. mv mad_127_100.rgb fu
So it should look like: /usr/local/lib/faces/fu (with fu being the image file itself, not a subdirectory)
Here's an example from my Fuel (I use /usr/lib/faces instead of /usr/local/lib/faces but either location works):
[Mai:~] neko 7# ls -la /usr/lib/faces
total 80
drwxr-xr-x    2 root     sys            28 Oct  3  2005 ./
drwxr-xr-x   69 root     sys         12288 Sep 19 04:42 ../
-rw-r--r--    1 neko     user        30512 Sep 28  2005 neko
-rw-r--r--    1 neko     user        30512 Oct  3  2005 root
[Mai:~] neko 9# file /usr/lib/faces/neko
/usr/lib/faces/neko:    SGI imagelib image (100 x 100)
[Mai:~] neko 10# file /usr/lib/faces/root
/usr/lib/faces/root:    SGI imagelib image (100 x 100)
'man clogin' for more details.
fu
Unread postby fu » Fri Sep 22, 2006 1:40 pm
nekonoko wrote:You need to rename the image file so it matches your login name, i.e. mv mad_127_100.rgb fu
total 80
yay!
that did the trick
thnx neko :D
Unread postby josehill » Fri Sep 22, 2006 1:54 pm
fu wrote:yay!
that did the trick
So, are you going to show us the image? :wink:
fu
Unread postby fu » Fri Sep 22, 2006 2:03 pm
josehill wrote:
fu wrote:yay!
that did the trick
hex!
i'm gonna take some screengrabs later...
i 've been messing with irix's vizual customization (X11 forwarding + VNC too) 2day and it's been (relatively) easy 2 do some funky stuff... 8)
Unread postby nekonoko » Fri Sep 22, 2006 2:08 pm
Will probably look better than my digital camera snapshot - capturing the login screen is (normally) tough (though it sounds like X11 forwarding may be one way to do it) ;)
unixmuseum
Unread postby unixmuseum » Fri Sep 22, 2006 2:12 pm
We used to have the Simpson's mugshots as visual logins for all of our users, this was a cool display...
Unread postby nekonoko » Fri Sep 22, 2006 2:16 pm
unixmuseum wrote:We used to have the Simpson's mugshots as visual logins for all of our users, this was a cool display...
I bought an Indigo2 on eBay a while back that had the entire clogin window filled with a spoof "Episode I" poster (Bart/Homer) :)
cicero
Unread postby cicero » Fri Sep 22, 2006 3:47 pm
Interesting addition to Tips & Tricks. Thanks for this hint neko! I'll try it.
