Rhapsody DR2 can't get network working
LarBob
Unread postby LarBob » Thu Mar 22, 2018 8:05 pm
I'm using a 3C589D card as described here: http://www.rhapsodyos.org/hardware/etherlink/etherlink_1.html and have it configured in Rhapsody. I've entered all of the correct TCP/IP information and using ifconfig -a it shows the settings I put in, but when I try to ping my router I get "Host is down" (it is not). If I try to ping 8.8.8.8 (Google DNS server) I get sendto: no route to host. Thanks all!
Re: Rhapsody DR2 can't get network working
Unread postby ClassicHasClass » Thu Mar 22, 2018 8:10 pm
What type of system are you trying to install it in?
LarBob
Unread postby LarBob » Fri Mar 23, 2018 11:00 am
ClassicHasClass wrote:What type of system are you trying to install it in?
Installed on a ThinkPad 365X.
edit: Also should mention that I get this same result whether the card is inserted or not.
Return to “Apple”
