That's what the title said. It was indeed an Apple Silver Power Mac type base system for £10.
A few stickers on the top hand written read:
2.3 GHZ
Power Mac
3GB Ram
Lisa
Store (or Stone)
FI
Aircon
2.3GB
with 3GB Ram
The back picture shows it has Dual DVI-D
2 Ethernet
Firewire 800
Firewire 400
Optical Audio Out (or in)
Optical Audio In (or out)
Audio In & Out
3USB
In that order (top down)
It's located not far, so for £10.. I bought it! Collection tomorrow night.
I suspect it's G5. It's not like I don't have enough stuff.. but I suppose that what you get when you visit your parents and all the talk is weddings and you have your phone.
Apple CPU £10
Apple CPU £10
- ClassicHasClass
- Donor
- Contact:
Re: Apple CPU £10
Yeah, that's a G5. You either have a DP 2.3 (most reliable) or DC 2.3 (a bit faster but poorer track record). The good news is, the 2.3 is aircooled, so no need to worry about overhauling the liquid cooling like on a Quad. Decent machine, that. Will run 10.4 or 10.5 very nicely.
bigred, 900MHz R16K, 4GB RAM, V12 DCD, 6.5.30
indy, 150MHz R4400SC, 256MB RAM, XL24, 6.5.10
purplehaze, 175MHz R10000, Solid IMPACT
probably posted from
bruce, Quad 2.5GHz PowerPC 970MP, 16GB RAM, Mac OS X 10.4.11
Re: Apple CPU £10
And now I have 2..
On collection, the guys asks if I want another for a fiver.. I say, I only have a tenner on me.. off he goes to get it anyway, and says, just take it..
Well, first one in excellent condition, but missing HDDs & Caddies & more importantly the power lead!!!! I'm hoping I have one in the loft from my old iMac that packed in some years ago.
The second has a damaged base, memory missing and all sorts of things that make it look like its been a bit cannibalized. Still not complaining for free.
I have now officially run out of space in my house!
- guardian452
- Donor
Re: Apple CPU £10
Isn't the power lead on a g5 a standard c19 like an onyx? I know you can get the fancy white apple one with a shroud but... It'll cost as much as the machine!
- ClassicHasClass
- Donor
- Contact:
Re: Apple CPU £10
Right. It's just a C19.
Re: Apple CPU £10
It is indeed a IEC 60320.C19 plug. The OEM cords have a flat gasket that might be gas tight (appears to be based on 60320-2-3), but that isn't normally needed.
Re: Apple CPU £10
uunix wrote:I have now officially run out of space in my house!
Build a shed to go with the loft. Then you can start a company, "Shed & Loft"
2 + 2 = 5
Re: Apple CPU £10
Oh, if I would have gotten an £10 Apple CPU for every time I've said that... I'd pretty much be in the situation I'm in nowuunix wrote:I have now officially run out of space in my house!
Re: Apple CPU £10
I don't have a cable, the iMac one a normal kettle lead with a seal on it..
Apple are like IBM and the MCA.. trying to take over the world with fscking kettle leads!!
WHYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYY!!!!!!!
