ANS RAID config floppy
pentium
Unread postby pentium » Tue May 12, 2015 11:16 am
I finally decided to get around to imaging my disk in the event that something happened to it.
Too late. When I fed it through RAWread I can get up to track 77 (ffff-, close too!), then it throws a CRC error and fails. :(
I do actually have the RAID controller card so the floppy is useful to me. I'm hoping someone else has already imaged this floppy. Anyone? Anyone?? Kjaer?
Failing that, think there is a practical way to fully image the disk, regardless of errors? According to my hex editor the incomplete file rawread leaves me indicates that the last couple or so tracks on the disk are empty anyways, so the data is intact, it's just not a properly formed image file rawread can write back out.
Re: ANS RAID config floppy
Unread postby jan-jaap » Tue May 12, 2015 12:24 pm
pentium wrote:Failing that, think there is a practical way to fully image the disk, regardless of errors?
ddrescue
Good luck!
Unread postby robespierre » Tue May 12, 2015 12:59 pm
If your image file is correct for all the tracks that contain data, isn't fixing it up to the proper length just a small matter of programming?
Unread postby ClassicHasClass » Tue May 12, 2015 1:39 pm
Let me verify: ANS = Apple Network Server?
I may have this floppy. I don't know in what condition, but I do have a boxed RAID card set.
pentium
Unread postby pentium » Tue May 12, 2015 10:00 pm
Yep. ANS = Apple Network Server.
If my knowledge on the subject is correct, yes.
Unfortunately I no longer rock a nice linux box, so ddrescue isn't going to help me here. :(
ScutBoy
Unread postby ScutBoy » Wed May 13, 2015 6:03 am
I have this floppy at home. I can make you an image if you wish. However, I believe it's just a normally formatted Mac floppy, with the executables copied onto it. IIRC, the "backup" instructions for this and the config floppy was to format a floppy in a Mac, and then copy the contents of the old disk onto the new disk.
In any event, ping me in a PM and I should be able to help you out. I used mine to set up a new RAID on one of my ANS' this spring, so I know it works :-)
:O2: :Indigo: :Cube: Image
Unread postby ClassicHasClass » Wed May 13, 2015 2:26 pm
What ScutBoy said. It's just an HFS floppy.
Unread postby hamei » Wed May 13, 2015 7:04 pm
pentium wrote:Yep. ANS = Apple Network Server ... I no longer rock a nice linux box, so ddrescue isn't going to help me here. :(
Pretty sure there's a ddrescue in nekoware, and I see your sig ....
Unread postby ClassicHasClass » Thu May 14, 2015 9:54 am
If you have a Mac, we can get you Disk Copy format (I'm sure ScutBoy can too, since his disk is tested).
pentium
Unread postby pentium » Thu May 14, 2015 4:01 pm
I lack a SCSI based floppy/floptical drive.
(Okay, I used to have one in my Indigo that VP gave me....but I kinda blew up the bridge controller....sorry VP..........)
Anyways, I think I got an image on hand now. I'll try to poke at it while I'm out of the house for the weekend and see if's useable in some way.
kjaer
Unread postby kjaer » Fri May 15, 2015 3:01 pm
I'll give you a copy of mine if you ping me sometime this weekend while you're in town?
pentium
Unread postby pentium » Wed May 20, 2015 9:07 am
Too late.... >_>
pentium
Unread postby pentium » Thu Jun 04, 2015 9:29 pm
Because I had the NeXT mono slab out last night I thought why the hell not and tried to DD the bad disk form there. It mounted as an HFS volume.
Curiously I threw it into a spare powerbook and tried tackling the disk with Disk Image. It worked. Now I have two good copies of the disk.
So today I've learned that the configuration disk was in fact an HFS volume which I know from past experience is not really compatible with rawread.
Unread postby robespierre » Thu Jun 04, 2015 9:40 pm
Is it an 800K floppy? I'd be interested to know whether the NeXTStation can read that.
Are there any raw-floppy-tools specifically for the NeXT slab?
Unread postby ClassicHasClass » Fri Jun 05, 2015 9:05 am
pentium wrote:Because I had the NeXT mono slab out last night I thought why the hell not and tried to DD the bad disk form there. It mounted as an HFS volume.
Eh? Why would it not be compatible with rawread? It's just MFM sectors ...
I could understand a Mac 400K/800K disk not being compatible, but the ANS RAID floppy is a "regular" HD floppy.
Return to “Apple”
