putting macbook to sleep at pre-defined time?
GIJoe
Unread postby GIJoe » Tue May 13, 2014 5:36 pm
hi,
google didn't come up with anything - i'm looking for a method to put my MBP to sleep at some pre-defined time a la 'go to sleep at <this time> on <that date>, no questions asked'.
ideally to be run from terminal and as a normal user, not root.
the background is that i had to disable most of the power management on mine since the automatic GPU-switching when connected to an external monitor on wakeup can lead to a kernel panic (one of the gazillion of documented yet eternally unresolved problems on the apple forums, sadly).
just looking for a way to prevent the machine from running for hours idling where it would normally go to sleep automatically after finishing a job.
Re: putting macbook to sleep at pre-defined time?
Unread postby ClassicHasClass » Tue May 13, 2014 8:50 pm
cron job that does osascript -e 'tell application "Finder" to sleep'. T,FTFY. :)
bigD
Unread postby bigD » Tue May 13, 2014 8:57 pm
Have you tried the 'Schedule' option in the Energy Saver module of System Preferences?
:Onyx2: :Indigo2: :O3x0:
Unread postby vishnu » Tue May 13, 2014 11:23 pm
GIJoe wrote:...since the automatic GPU-switching when connected to an external monitor on wakeup can lead to a kernel panic (one of the gazillion of documented yet eternally unresolved problems on the apple forums, sadly).
Yet another of the innumerable reasons why my MBP hasn't been turned on in two and a half years. Which isn't to say all you macaholics aren't good people! Wrong, but good... ;)
yetanother**ixuser
Unread postby yetanother**ixuser » Wed May 14, 2014 3:10 am
just in case...
http://gfx.io/
you can also force which graphic card you want to use, so no more switching will occur.
no plan
GIJoe
Unread postby GIJoe » Wed May 14, 2014 3:52 am
ClassicHasClass wrote:cron job that does osascript -e 'tell application "Finder" to sleep'. T,FTFY. :)
thanks - that would be the ticket - but how to put in a cron job that only runs once? they also use some unreadable format to set up. not good if you have to google everytime for the syntax beforehand. ;) alternatively, there may be a way to embed it into a shell-script that is fed a variable for date and time and keeps waiting until that condition is met.
or any hack that would enable a normal user to execute 'pmset schedule sleep', really. that one has all the functionality already...
yes, but it's graphical frontend only. i'm not familiar with automator however... perhaps time to brush up on that?
just in case...
http://gfx.io/
i use that but power-source-based switching has been removed from it - and seems to be the cause.
i just wish there was a way to disable the integrated stuff completely and force the use of the discrete GPU at all times. battery life be damned.
thanks guys, time to have a look at scripting and automator, i think. :)
duck
Unread postby duck » Wed May 14, 2014 4:22 am
Running things once at a specific time is the job of 'at'. It might be too oldeyworldey to be fit to exist on such a modern thing as a mac though.
___(o)=
\____)
Unread postby guardian452 » Wed May 14, 2014 4:29 am
It exists in 10.9... and it works just fine.
AT(1)                     BSD General Commands Manual                    AT(1)
NAME
     at, batch, atq, atrm -- queue, examine, or delete jobs for later execu-
     tion
SYNOPSIS
     at [-q queue] [-f file] [-mldbv] time
     at [-q queue] [-f file] [-mldbv] -t [[CC]YY]MMDDhhmm[.SS]
     at -c job [job ...]
     at -l [job ...]
     at -l -q queue
     at -r job [job ...]
     atq [-q queue] [-v]
     atrm job [job ...]
     batch [-q queue] [-f file] [-mv] [time]
DESCRIPTION
     The at and batch utilities read commands from standard input or a speci-
     fied file.  The commands are executed at a later time, using sh(1).
Messi:~ mjw$ at
usage: at [-q x] [-f file] [-m] time
       at -c job [job ...]
       at [-f file] -t [[CC]YY]MMDDhhmm[.SS]
       at -r job [job ...]
       at -l -q queuename
       at -l [job ...]
       atq [-q x] [-v]
       atrm job [job ...]
       batch [-f file] [-m]
Unread postby hamei » Wed May 14, 2014 8:12 am
duck wrote:Running things once at a specific time is the job of 'at'.
Ooh. Useful. Thank you !
Unread postby robespierre » Wed May 14, 2014 8:13 am
You can write a shell script that calls pmset(1) and then "chmod 4755" the script.
something like
#!/bin/sh
pmset schedule sleep "$1 $2"
then "chown root" the script.
duck
Unread postby duck » Thu May 15, 2014 12:59 am
robespierre wrote:You can write a shell script that calls pmset(1) and then "chmod 4755" the script.
something like
#!/bin/sh
chown before chmod, or the suid bit will be stripped*
*) this possibly does not happen on some platforms
___(o)=
\____)
Return to “Apple”
