System disk keeps filling up...
mnorton
Unread postby mnorton » Fri Apr 22, 2011 9:14 am
OK - so I previously thought this was a virus. It still could be.
My system disk space keeps filling up! I can clear up several gigs and then in a few hours POOF!!!! ZERO KB!
I backed up the HD with time machine and a disk image from disk utils.
Verify disk revealed no disk issues. As did the other disk util verifications.
I have nearly zero KB of disk space and I can't locate the culprit.
Any ideas on what I need to look at?
Mac OS X 10.5.6
thanks
Image x1 Image x2
Re: System disk keeps filling up...
Unread postby SAQ » Fri Apr 22, 2011 12:08 pm
Check where the space is going (look for one of the UNIX-based FS analyzers, or else run a "du -h" at the command prompt, provided your system has du, can't recall if it was default).
My first guess is that something's sending out absurd numbers of log entries.
mnorton
Unread postby mnorton » Fri Apr 22, 2011 5:10 pm
Well I rebooted with theD-key down to run diagnostics. @x I saw this error reported.
4M0T/1/40000003:HDD-1334
I presume the HDD is the Hard Disk Drive.
So what is the skinny? Is my drive terminally ill?
thanks.
Image x1 Image x2
Unread postby nekonoko » Fri Apr 22, 2011 7:01 pm
No, Google seems to suggest that is an issue with the hard drive fan, not the drive itself. It's still more likely you have a runaway process chewing up a log file or some such.
duck
Unread postby duck » Sat Apr 23, 2011 1:08 am
My brother had a similar issue on his powerbook, it would continually fill the disk with swap files (in /var/private/ somesuch). I don't have a cure, but it might be worth looking at, perhaps seeing if you could clear them out somehow.
___(o)=
\____)
mnorton
Unread postby mnorton » Sat Apr 23, 2011 11:30 am
Yes. It does appear to be some sort of a file being written. It is happening now. I am watching my disk capacity slowly get munched away.
Is there a UNIX command I can use to home in and watch what is being written?
I used du -x -h -d 1 /
And it didn't really give any deeper revelation to the problem.
I have omnidisksweeper running too...
thanks.
Image x1 Image x2
Unread postby josehill » Sat Apr 23, 2011 5:07 pm
You can use the "find" command with the -mmin option to show files modified within a certain window of time. For example,
find . -mmin -60
will list all files in the current directory that have been modified in the last sixty minutes. Use sudo to run
find / -mmin -60
(or run it as root) to see every file on the computer that was modified in the last hour.
You can then use the "lsof" command to see which process is actually keeping the file open.
Unread postby SAQ » Sat Apr 23, 2011 9:26 pm
Fire up the log viewer and see if there's anything obvious there.
Note that if you have a 25GB log file the Apple GUI viewer will be very slow (seen it...).
You can also try using the find command with a size flag to find all files bigger than a gig or so - sometimes this works.
shyouko
Unread postby shyouko » Sun Apr 24, 2011 7:59 am
Just scan to see which folders took up all those spaces:
http://www.omnigroup.com/products/omnidisksweeper/
mnorton
Unread postby mnorton » Mon May 02, 2011 8:39 pm
OK - I found the nasty log file via OmniDiskSweeper.
asl mnorton$ ls -l
total 13080184
-rw-r--r-- 1 root wheel 3402528023 May 2 00:17 2011.05.01.asl
-rw-r--r-- 1 root wheel 3290533888 May 2 04:17 2011.05.02.asl
-rw-r--r-- 1 root wheel 3896084 May 2 20:35 LongTTL.U0.asl
-rw-r--r-- 1 root wheel 85147 Apr 9 11:39 LongTTL.asl
-rw-r--r-- 1 root wheel 8 May 2 04:17 StoreData
-rw-r--r-- 1 root wheel 0 Apr 10 00:00 SweepStore
asl mnorton$ pwd
/private/var/log/asl
asl mnorton$
It is Adobe CS3 Photoshop styles file log mutantly growing on me. WHat is causing this?
Any ideas?
Image x1 Image x2
Unread postby nekonoko » Mon May 02, 2011 9:58 pm
I found a thread on the Apple Discussion forums that looks similar; you might try deleting the files suggested in the last post:
https://discussions.apple.com/thread/28 ... 0&tstart=0
Return to “Apple”
