Changing OSX interface
karahana
Unread postby karahana » Tue Apr 12, 2011 5:58 am
Hi guys
Does any of u know if there is a way to change finder's interface or use another window manager? I tried this installing packages thru darwin ports but looks like it encountered (bug) in one of the packages an error and never finished.
Thanks!
Image R12K Dual 300, 1gb RAM, EMXI, DIVO, MSCSI. Old logos!
Image R12K Dual 300, 640mb RAM, SE, DIVO(to be installed). New logos!
Image No processor, no HDDs, unknown state of ram... but hey! looks brand new :D
ChristTrekker
Re: Changing OSX interface
Unread postby ChristTrekker » Tue Apr 12, 2011 8:51 am
I use ShapeShifter from Unsanity for awhile, but I believe it's not compatible with 10.5 and up. Apple doesn't like you customizing the UI at all. :( :x :cry: :evil:
Principle Over Politics : http://www.ConstitutionParty.org
fu
Unread postby fu » Tue Apr 12, 2011 11:40 am
never used it myself but some of the kids i work with, use some app from unsanity (probably the one chris mentioned)
i hear that when they funk to much with it, they just return to the default ui
Unread postby josehill » Tue Apr 12, 2011 2:22 pm
@karahana - Exactly what are you seeking to do? Do you want to replace the entire Finder experience (i.e. everything in the normal GUI), tweak the appearance (i.e. use a new "theme" or "skin"), or just have an alternative file manager / program launcher? These are very different categories, and the answers will be different for each.
Some MacOS X file managers:
XFile - http://rixstep.com/4/0/td.shtml
Path Finder - http://www.cocoatech.com/
MuCommander - http://www.mucommander.com/
Disk Order - http://www.likemac.ru/english/
XFolders - http://www.kai-heitkamp.com/
File Browse - http://www.filebrowse.com/
There are also a number of Dock alternatives, application launchers, etc. that might be worth a look...or a quick search of the net.
karahana
Unread postby karahana » Tue Apr 12, 2011 10:23 pm
Thanks all, I would like to use a different window manager, like i don't know, something like CDE for instance. I don't think it's actually possible right?
PymbleSoftware
Unread postby PymbleSoftware » Tue Apr 12, 2011 10:29 pm
CDE is/was owned by a consortium. The code for it also.
I do run a CDE session on my Mac... Like this... "Xnest :1 -query tru64_box" (*) This gives me a login session with a CDE screen within a Apple Aqua window. Other than that I don't think there are any real options.
I addition to Josehill's suggestions above ...
What about KDE ...?
R
* or a HP-UX/AIX/OpenVMS box.
Last edited by PymbleSoftware on Tue Apr 12, 2011 11:27 pm, edited 1 time in total.
死の神はりんごだけ食べる
開いた括弧は必ず閉じる -- あるプログラマー
Twitter @PymbleSoftware
duck
Unread postby duck » Tue Apr 12, 2011 11:21 pm
That's right, the osx desktop isn't an X environment (you can get one with X11.app; at least in previous versions of osx, I heard some rumors it's no longer available, I only got to 10.4 before my mac fried). One thing that's fixable is click-to-focus though, you can through a default (that's the command name) setting change it to focus follows mouse which is a little more tolerabe...
___(o)=
\____)
Unread postby josehill » Wed Apr 13, 2011 12:06 am
duck wrote:(you can get one with X11.app; at least in previous versions of osx, I heard some rumors it's no longer available
X11.app is still available on the Leopard and Snow Leopard installation DVDs as an optional package.
Return to “Apple”
Users browsing this forum: Baidu [Spider] and 1 guest
