where to find powersupply for iMac G5
theinonen
Re: where to find powersupply for iMac G5
Unread postby theinonen » Fri Sep 24, 2010 1:48 pm
sybrfreq wrote:IMO flux is unnecessary unless you are soldering plumbing. :shock:
It is usually done with gas welding equipment anyway.
Or you could get one of these, and get the same work done with only a press of a button.
Soldering is so yesterday...
Unread postby guardian452 » Fri Sep 24, 2010 2:59 pm
I don't do much plumbing work anymore, but I've never used anything other than solder and a good old propane torch. and flux :D That's the way my dad taught me, that's what I do in my own house and it's standard for north america.
Unread postby SAQ » Sat Sep 25, 2010 5:21 pm
sybrfreq wrote:I don't do much plumbing work anymore, but I've never used anything other than solder and a good old propane torch. and flux :D That's the way my dad taught me, that's what I do in my own house and it's standard for north america.
But whatever you do don't use plumbing flux on circuit boards.
mnorton
Unread postby mnorton » Thu Oct 07, 2010 9:29 am
OK - I ordered this stuff. The CAP removal SAGA continues...
http://www.jwestsales.com/products/Chip ... l-Kit.html
I'll keep you posted.
Image x1 Image x2
Ryan Fox
Unread postby Ryan Fox » Thu Oct 07, 2010 11:15 pm
Replacing capacitors is usually a simple and straightforward task. Personally, I've done it many times on retro hardware. Its usually the first components to fail on any power supply.
Regards
Ryan
MAYA, nut-
mnorton
Unread postby mnorton » Thu Oct 14, 2010 11:43 am
Replacing capacitors USED to be straight forward. With the newer PCB designs and copper cores. It's a bit more than the ol 45 WATT soldering can handle. So we're learning some new things now.
Go search youtube for iMac G5 capacitor repairs. Then you'll see what we're referring to. We all got snagged with what should be a simple upgrade. I am going to take a crack at the project again this weekend.
I'll post here how the chemical works with the desoldering.
Image x1 Image x2
Unread postby guardian452 » Thu Oct 14, 2010 4:18 pm
I did about two dozen MSI and gigabyte boards a few years ago (EVERY MSI board had failed caps and ALL BUT ONE gigabyte board-one was fried by the power supply). After the first one or two it is childs play, but big supplies are quite a bit different than off-brand PC boards. MSI and gigabyte boards are probably junk when new... I certainly learned to stay away from them.
MisterDNA
Unread postby MisterDNA » Thu Oct 14, 2010 7:53 pm
A heat gun to preheat the evil ground and power planes in these boards is pretty much crucial. You're usually good below 700F for as long as it takes to bring the source side of the board up to temp since most through-hole parts like caps are wave-soldered. If there are hand-soldered through-hole parts in place, those were hand-soldered because they will melt in the wave tunnel. Yeah, stay away from those with the heat.
With the preheat, you should have no trouble cleaning the hole. If you do, just do like me and use a wide tip on your iron to melt the solder in both holes at the same time and feed the new cap through to push the solder out of the way.
I use a Hakko iron, personally, but there are a lot of choices. Metcal for the dead-serious, for one.
-- I'm a PeeCee and I can kick your ass. --
Slow PeeCee - i7 940 OC 4.1GHz, 20GB DDR3 OC 1.8GHz, 2x1TB WD RAID0, ATI 5870 1GB, 3008WFP
Dev PeeCee - IBM Intellistation A Pro - Dual Opteron 290 2.8GHz, 8GB ECC DDR, 500GB SATA, 8400GS, 2x1800FP
Slow PeeCee Cluster - 30x Opteron 275, 60.5GB RAM, 2.2TB, 2x1.5TB
Octane 2xR12K-300, 1.5GB, 36GB 10K, 73GB 10K, V8
Indigo2 195MHz, 1GB, 36GB, SI
There are 10 kinds of people in the world:
Those who understand Ternary. Those who don't. Those who could give a shit less.
Return to “Apple”
