Need to replace Mac, need advice
Frapazoid
Unread postby Frapazoid » Tue Jan 26, 2010 3:30 pm
I managed to leave my Mac Mini on a train.
It was not turned into lost and found.
I want to scrounge up the cheapest thing I can get that will let me compile things for that iPhone gadget.
I learned I can use the SDK on OS X 10.5, and that 10.5 will run on a G4 872mhz+, and that there are dual G4 872mhz on Allegro.pl for like 500 złoty.
Is there any reason this is a horrible idea?
Maverick 3: Athlon X2 7750, 2gb, Windows Vista
Frank Dux: SGI Octane2 R12k 400mhz 1.5gb
"Chief, look! I learned to make fire! Who knows what we could do with this... We should learn to control it!"
"Ridiculous. How can you justify wasting time and effort on this so-called 'fire' when our children are freezing to death at night?"
Re: Need to replace Mac, need advice
Unread postby josehill » Tue Jan 26, 2010 4:21 pm
Frapazoid wrote:I learned I can use the SDK on OS X 10.5, and that 10.5 will run on a G4 872mhz+, and that there are dual G4 872mhz on Allegro.pl for like 500 złoty.
Hey, Frapazoid, welcome back! Long time, no see!
I guess that some of the older versions of the SDK could partially work on a G4, but the iPhone SDK is officially supported only on Intel cpus, and the Simulator won't run at all on PPC.
Save your złotys for an Intel Mac. :D
Frapazoid
Unread postby Frapazoid » Tue Jan 26, 2010 4:31 pm
Thanks! I had no idea it wouldn't go on PPC. Good thing I asked!
Unread postby SAQ » Tue Jan 26, 2010 9:57 pm
josehill wrote:Save your złotys for an Intel Mac. :D
Or Hacintosh yourself.
Frapazoid
Unread postby Frapazoid » Wed Jan 27, 2010 12:29 am
Will that work on AMD64?
QuicksilverG4
Unread postby QuicksilverG4 » Wed Jan 27, 2010 5:06 pm
There seem to be AMD64 compatible install images floating around.
Unread postby foetz » Wed Jan 27, 2010 5:16 pm
yes but i would highly recommend intel cpu and nvidia gfx
Unread postby SAQ » Wed Jan 27, 2010 6:49 pm
foetz wrote:yes but i would highly recommend intel cpu and nvidia gfx
Get it as close to an Apple model as you can - makes things much easier.
porter
Unread postby porter » Wed Jan 27, 2010 10:44 pm
Frapazoid wrote:I want to scrounge up the cheapest thing I can get that will let me compile things for that iPhone gadget.
Can you compile on an iPad?
ShadeOfBlue
Unread postby ShadeOfBlue » Thu Jan 28, 2010 2:00 am
Frapazoid wrote:Will that work on AMD64?
A friend runs 10.5 on a quad-core AMD64 PC. It works fairly well (minor instability problems here and there), but some OS upgrades break, since I imagine not much testing is done on AMD CPUs.
As foetz and SAQ mentioned, get a configuration that's as close to stock Apple specs as possible.
Return to “Apple”
