4Dwm remote session on MacBook Pro
mnorton
Unread postby mnorton » Sat May 03, 2008 2:22 pm
hi,
Is it possible to run a 4Dwm remote session on my Mac Book Pro?
I have exhausted my resources in trying to get VNC to do this through xstartup.
Is there a xdcmp or remote session trick to get the 4DWM session to my Indigo2 on my Mac?
What are the steps to accomplish this? -if it is possible.
thanks.
Image x1 Image x2
porter
Re: 4Dwm remote session on MacBook Pro
Unread postby porter » Sat May 03, 2008 2:32 pm
Fire up "X" on your Mac Book.
When the xterm appears type "Xnest -query irxi-box-ip-address".
You can then play with the -geometry argument using xwininfo as a hint.
noisetonepause
Unread postby noisetonepause » Sat May 03, 2008 2:33 pm
mnorton
Unread postby mnorton » Sun May 04, 2008 3:02 pm
YES!!!
Thanks porter and noisetonepause. This worked.
http://www.nekochan.net/wiki/index.php/Headless_desktop
I have 4Dwm running under X11 on my MBP!!! :D
Can I run maya off my Indigo2 using this?
I ran into this.
tardis mnorton-70% maya
Xlib:  extension "XInputExtension" missing on display "192.168.1.100:2.0".
tardis mnorton-71%
thanks.
Image x1 Image x2
GIJoe
Unread postby GIJoe » Sat May 10, 2008 4:18 am
can't help with the question at hand but:
you do realise that there are much more recent maya versions out there running natively on your macbook, right?
mnorton
Unread postby mnorton » Sun May 18, 2008 1:11 pm
Yes.
There are more recent Maya versions for the MBP.
But....
for $50 and e-bay I have a version of Maya up and running on my Indigo 2. Granted. an old copy.
But it is suitable for learning Maya.
When I see a decent bargain for a more recent Maya for the Mac I will definitely secure that.
Besides. Having the Mac and SGI running are the best of both worlds. The 4dwm looks great on the MBP.
later,,,
Image x1 Image x2
toxygen
Unread postby toxygen » Sun May 18, 2008 1:29 pm
What is the quality and speed over remote session?
suitable for working?
:Indigo2IMP: :Octane: This post was typed using dvorak keyboard layout - http://www.dvzine.org
mnorton
Unread postby mnorton » Mon May 19, 2008 1:42 pm
The quality is good. But then again I have the MBP and the Indigo2 on the same subnet.
Maya won't work because the Apple X11 doesn't have the opengl extensions.
later,,,
Image x1 Image x2
GIJoe
Unread postby GIJoe » Sun May 25, 2008 7:08 am
50$ for an indigo2 with a maya license locked to it i assume?
everything else would most likely not be a valid license, more an illegal/unauthorized one that you even had to pay for (in the eyes of autodesk)
mnorton
Unread postby mnorton » Thu May 29, 2008 3:20 pm
Yep. The software came with the hardware.
Image x1 Image x2
Dr. Dave
Unread postby Dr. Dave » Thu May 29, 2008 8:13 pm
just an unrelated note, I run Exceed here with the GL extensions, and even some of the Performer demo's work (such as "Hong Kong") work fine over X on the remote box. Run pretty well too... so it is possible.
barutanseijin
Unread postby barutanseijin » Tue Jul 22, 2008 9:41 am
When i try opening up an 4dwm session with "Xnest :1 -query <octane ip>" i get a grey box on my macbook. I'm running 10.5.4 with xorg 2.3.0
Perhaps it's related, but when i boot over to linux, everything works if i log in as root, but logging in as joe user does nothing more than make the screen flicker and refresh the login screen.
porter
Unread postby porter » Tue Jul 22, 2008 11:28 am
The login as root over xdm sounds wrong. Normally root login on X is blocked unless you are on the system console.
On the IRIX box do you have the font server turned on? This should be listening on port 7100.
I then add the following args to the Xnest...
-fp=tcp/hostname:7100
barutanseijin
Unread postby barutanseijin » Tue Jul 22, 2008 1:21 pm
porter wrote:The login as root over xdm sounds wrong. Normally root login on X is blocked unless you are on the system console.
Now that you mention it, yeah, it doesn't sound right to log in as root, but it was most definitely root.
fp doesn't seem to be a supported option with the Xnest here.
Fatal server error:
Unrecognized option: -fp=tcp/192.168.x.x:7100
porter
Unread postby porter » Tue Jul 22, 2008 1:52 pm
barutanseijin wrote:
Fatal server error:
Appologies. Try without the equals.
On IRIX server...
$ chkconfig | grep font
        fontserver           on
$ chkconfig | grep xdm
        xdm                  on
confirm using netstat that it is listening for XDMCP datagrams
udp4       0      0  *.xdmcp                *.*
Return to “Apple”
