Fink vs. Darwin Ports
Unread postby yuckymucky » Sun Jun 17, 2007 10:17 pm
Who is using either of the two? I was using Fink on my PowerBook up till I sold it and now with a fresh 10.4 install on my G5 I think that it is time for one of them.
I was just wondering if anybody is using Darwin Ports and what they like about it?
Re: Fink vs. Darwin Ports
Unread postby noisetonepause » Mon Jun 18, 2007 3:44 am
I tried Fink first and I couldn't get anything to work in it. I was new to things at the time, so I was probably doing something wrong.
DarwinPorts is great, I think. Very simple and very reliable.
Unread postby zizban » Mon Jun 18, 2007 7:28 am
I've used fink since the early days and its come a long way. Get FinkCommander if you are new to it. It makes life much easier.
I'm a fink contributor so I wont suggest one over the other.
Unread postby SupremeCmdr » Mon Jun 18, 2007 7:55 pm
MacPorts/Darwin Ports all the way baby.
I used Fink originally but found that some of the packages I needed were very out of date so I tried MacPorts.
It apppears to be more up to date and you get the added satisfaction that it compiles everything.
Which is good if you're a Gentoo fanboi or bad if you have a slow machine/internet connection.
I've had no reason to try fink recently so it may be better than when I last tried it a year or so ago.
Apple Unibody MBP 2.66Ghz, 8Gb OSX 10.6
Apple MacMini 1.83Ghz, 1Gb OSX 10.5
Apple Power Mac Cube 450Mhz, 256Mb, OSX 10.3 Sweet!
Sun Ultra10 440Mhz 1Gb, SunOS 5.10
Unread postby m03 » Mon Jun 18, 2007 11:16 pm
I use pkgsrc. I like to keep it so that I can use the same method for more than one platform. Works for probably 80% of the packages I've needed.
Unread postby ipaddict » Tue Jun 19, 2007 12:42 pm
Fink has let me down a few times, so I'm a full-time MacPorts user, now.
Unread postby Frapazoid » Wed Jun 20, 2007 12:51 am
I use the ports, but it drives me nuts.
The one problem I have consistently is that it uses FTP to grab the files, and FTP usually locks up. It'll download the file all the way then never close the connection - FTP just hangs.
I've had that problem with FTP on all of my computers at every physical location I've ever lived in for as long as I can remember. I think FTP just sucks or something.
Maverick 3: Athlon X2 7750, 2gb, Windows Vista
Frank Dux: SGI Octane2 R12k 400mhz 1.5gb
"Chief, look! I learned to make fire! Who knows what we could do with this... We should learn to control it!"
"Ridiculous. How can you justify wasting time and effort on this so-called 'fire' when our children are freezing to death at night?"
Unread postby jade_angel » Wed Jun 20, 2007 5:39 am
FTP is just plain wonky. Control connections, with a separate data connection, argh. Makes a firewall administrator's life unnecessarily difficult.
Unread postby milatchi » Fri Jun 22, 2007 9:28 am
I'm a Fink man, tried DarwinPorts and had some snags then went back to Fink or FinkCommander.
"EV-ERY-ONE!" --Stansfield
Unread postby nekonoko » Tue Jul 03, 2007 9:12 am
I've been using Fink for years without issue, but I'll probably give DarwinPorts a try to see how it compares.
Unread postby PymbleSoftware » Thu Jun 16, 2011 6:53 pm
I just started installing GIMP on my 27 inch iMac at work using "sudo port install gimp" and the dependancies it required included Orbit-2 (A CORBA Object Request Broker) and libusb (a USB package for poking about in the USB bus). :shock: :shock:
Go MacPorts !!! Kill my internet bandwidth!
Latest model iMac with 16Gb RAM and an hour and a half later and its still going...
Looks like other people have weird issues trying to install gimp from MacPorts as well.. ... #a31536168
開いた括弧は必ず閉じる -- あるプログラマー
Twitter @PymbleSoftware
Current Apps (iOS) -> ... d553990081
(Android) ... +Ltd&hl=en
(Onyx2) Cortex ---> ... 11?sk=info
(0300s) Minnie ---> ... 02?sk=info
Github --->
Unread postby zmttoxics » Fri Jun 17, 2011 8:10 am
Gimp on OSX using the X11 server was very problematic for me. I ended up purchasing Pixelmator for my quick photo work. Don't regret that part.
Mac ports is great, but your right, the initial port install of anything comes with building a ton of dependencies and it makes even the big macs cry a little.
Lord John Whorfin
Unread postby Lord John Whorfin » Fri Jun 17, 2011 2:13 pm
A growing number of developers in my office are starting to use Homebrew instead of Mac Ports.
Unread postby MDBenson » Sat Jun 18, 2011 7:11 am
Homebrew looks very inviting. I was gonna go back to DarwinPorts since I dumped it when I did a fresh install for 10.6 but I dunno it was great and all but didn't seem to be it.
Unread postby guardian452 » Sat Jun 18, 2011 6:38 pm
zmttoxics wrote:Gimp on OSX using the X11 server was very problematic for me. I ended up purchasing Pixelmator for my quick photo work. Don't regret that part.
I use Aperture for all of my photos but if there is a file I just want to quickly crop/resize/etc without adding it to my library, gimp is great for this. I find gimp much easier to use if you turn on the Click-through Inactive Windows option in the X server.
Return to “Apple”
