IRIX unable to mount share from FreeBSD w/ ZFS
praetor242
Unread postby praetor242 » Sun Aug 27, 2017 8:13 pm
I'm wondering if anybody has seen this.
I have a server (server1) with FreeBSD and ZFS. I have /exports/SGI in my /etc/exports and also did:
zfs set sharenfs="-alldirs -network=192.168.2.0/24" tank/exports/SGI
But when I try and mount it from my O2, it says:
trajan 3# mount server1:/exports/SGI /mnt/software
mount: NFS version 3 mount failed, trying NFS version 2.
mount: server1:/exports/SGI on /mnt/software: Resource busy
mount: giving up on:
   /mnt/software
I'm not sure what is going on :(
Image - trajan - R5000 180Mhz - 256 MB RAM - 300GB HDD
Image - hadrian - R5000 180Mhz - 128 MB RAM - 147 GB HDD
Re: IRIX unable to mount share from FreeBSD w/ ZFS
Unread postby Raion-Fox » Sun Aug 27, 2017 11:05 pm
I had issues trying to get IRIX to connect to the NFS mount as well.
Doing a google search I read that you should make sure that you try a TCP mount first, and then the following:
mount -t nfs 192.168.1.3:/exports/SGI /mnt/software
Replace the placeholder ip obviously.
nfs3 on IRIX is very buggy, unfortunately.
praetor242
Unread postby praetor242 » Mon Aug 28, 2017 8:00 am
Hmm...tried that. No love :(
My Macs, and all my other FreeBSD machines can connect to it just fine. Just not the SGIs :( Which is kinda important cuz that's where nekoware lives on my network :\
Unread postby jan-jaap » Mon Aug 28, 2017 8:23 am
praetor242 wrote:My Macs, and all my other FreeBSD machines can connect to it just fine.
Those might be using NFSv4
My (Linux) NFS server exports with the 'no_subtree_check' option, but it works just fine otherwise.
praetor242
Unread postby praetor242 » Mon Aug 28, 2017 8:34 am
I kinda figured that. I don't know how to make it expose itself as an NFS3 share. So IDK :(
praetor242
Unread postby praetor242 » Mon Aug 28, 2017 9:38 am
I'm a moron. I figured it out. There was a stale NFS handle on /mnt/software from a previous mount. Soon as a umount /mnt/software and then mounted it again, it worked.
