7 BeBoxen on eBay
sgifanatic
7 BeBoxen on eBay
Unread postby sgifanatic » Sat Apr 15, 2017 11:45 am
Probably the largest collection of these systems anywhere?
http://www.ebay.com/itm/322483980652
Dodoid
Re: 7 BeBoxen on eBay
Unread postby Dodoid » Sat Apr 15, 2017 2:06 pm
Aaaaaand they're gone!
:Fuel: :Octane: :Octane: :Octane: :O2: :Indigo2: :Indigo2: :Indy: :Indy:
Unread postby Raion-Fox » Sat Apr 15, 2017 2:12 pm
Yep that was quite the shock
:O2: R10000 225MHz 256MB RAM 15k 147GB HDD suzuha
Thinkpad W530 i7 3940XM 3GHz, 32GB, K1000M FreeBSD 11/Windows 7 rin
Acer Aspire 5157 (headless) 4GB, FreeBSD 11 kuran
Dodoid
Unread postby Dodoid » Sat Apr 15, 2017 2:39 pm
Shock indeed! I didn't even get my eBay alert message for "BeBox" or "Be Box"!
Unread postby ClassicHasClass » Sun Apr 16, 2017 3:10 am
Doesn't look like all of the systems were complete. If they were, $3000 would be quite a steal. As it is, you might be able to get a couple systems out of what was there.
Y888099
Unread postby Y888099 » Sun Apr 16, 2017 4:30 am
Something is only worth what someone is willing to pay for it.
Different question: what can you do with BeBox(BeOS @ PPC)?
Unread postby ClassicHasClass » Sun Apr 16, 2017 2:59 pm
There aren't many things built for PowerPC BeOS. There's a fair bit for x86, but PowerPC got unloved even though BeOS could run on many contemporary Power Macs.
I've tried porting a few things, and some work (I have a 133MHz BeBox). Mine came with the Metrowerks compiler and I was able to build some command line tools, but I haven't tried to build a full-blown BeOS app with it yet.
Obviously the situation is even worse if you have a grey Hobbit-based prototype.
kokoboi
Unread postby kokoboi » Mon Apr 17, 2017 12:11 am
What's the difference between BeOS for bebox and powermac?
"Look on wife/girlfriends/parents face when you drag all this stuff(IRIS CRIMSON, ONYX, ONYX2, ORIGIN 2000 ,etc.) home.... Priceless! ;)"
:Tezro: :O3x02L: :Indy: :Indigo2IMP: :O2: :O2: :Octane: Motorla Series 900(MVME197LE) , Atari TT030, Motorola Powerstack
Unread postby robespierre » Mon Apr 17, 2017 9:38 am
The OS was basically the same, but the BeBox had some special peripherals ("GeekPort") and always booted directly from OpenFirmware. On The PowerMac, you could boot from a launcher application on the Mac side, like you could for MkLinux.
miod
Unread postby miod » Mon Apr 17, 2017 4:37 pm
robespierre wrote:The OS was basically the same, but the BeBox had some special peripherals ("GeekPort") and always booted directly from OpenFirmware.
From ROM, rather. There was no OpenFirmware on BeBoxens.
:Indigo:R4000 :Indigo:R4000 :Indigo:R4000 :Indigo2:R4400 :Indigo2IMP:R4400 :Indigo2:R8000 :Indigo2IMP:R10000 :Indy:R4000PC :Indy:R4000SC :Indy:R4600 :Indy:R5000SC :O2:R5000 :O2:RM7000 :Octane:2xR10000 :Octane:R12000 :O200:2xR12000 :O200: - :O200:2x2xR10000 :Fuel:R16000 :O3x0:4xR16000 :A350:
Unread postby Raion-Fox » Mon Apr 17, 2017 5:10 pm
I wanted one for a while but I no longer want one. I do want to know, how many of the Hobbits survived.
Unread postby robespierre » Mon Apr 17, 2017 6:25 pm
miod wrote:From ROM, rather. There was no OpenFirmware on BeBoxens.
Hmm, weird. I always thought they were PReP/CHRP machines.
miod
Unread postby miod » Mon Apr 17, 2017 10:51 pm
The BeBox hardware is PReP, but the firmware in ROM, not being OpenFirmware, is obviously not PReP-compliant.
Y888099
Unread postby Y888099 » Tue Apr 18, 2017 3:08 am
ClassicHasClass wrote:Mine came with the Metrowerks compiler
Exactly that makes the point.
The C/C++ compiler (BeOS is mainly written in C++) is a MUST have!
Lucky you are :)
