DOS environment variable expansion defective?
Voralyan
Unread postby Voralyan » Mon Nov 18, 2013 8:03 am
Maybe I'm defective myself, but the following strange thing happens
(tried with OpenDOS 7.01, DR-DOS 7.03 and MSDOS 6.22 command.com)
C:\>set foo=bar
C:\>set
FOO=bar
C:\>echo %foo%
%foo%
C:\>
What the :evil:
Shouldn't I get "bar" on echo %foo% ?
Tried that on two different machines, even with plain DOS boot disk.
[edit: corrected typo]
:A3502L: :O2000: :O200: = :O200: - :O200: :O200: :Octane: :Octane: :320: :O2: :Indigo2IMP: :Indy:
+ | d | i | g | i | t | a | l | +apple +[...] ;)
kjaer
Re: DOS environment variable expansion defective?
Unread postby kjaer » Mon Nov 18, 2013 10:10 am
Voralyan wrote:
C:\>set foo=bar
C:\>set
FOO=bar
C:\>echo %foo%
%foo%
C:\>
um. what is the question here? that access to environment variables in DOS is case sensitive? I don't understand the problem.
Voralyan
Unread postby Voralyan » Mon Nov 18, 2013 12:45 pm
On "echo %foo%" the value should be printed in the
next line and not the variable designator...
I tried the aforementioned example on WinNT's cmd.exe
and I get correctly "bar" as the output on "echo %foo%"...
But not on any DOS system running on two absolutely
different machines!
Maybe I'm overlooking something astonishing simple or
it's just the wrong pressure in the water pipes today... who knows?!
[edit: DOS is not case sensitive]
Black Cardinal
Unread postby Black Cardinal » Mon Nov 18, 2013 2:09 pm
I have a vague recollection that the %foo% dereferencing only worked inside BAT files or in the environment passed to applications. I don't think it worked directly on the command line. I don't have a DOS system to try it out on nearby, though.
Black Cardinal
tingo
Unread postby tingo » Mon Nov 18, 2013 3:03 pm
Try
echo %%foo%%
Exercise for the reader: why is this required?
Torfinn
porter
Unread postby porter » Mon Nov 18, 2013 3:58 pm
tingo wrote:Try
echo %%foo%%
Escapes me.
Unread postby hamei » Mon Nov 18, 2013 5:47 pm
porter wrote:Escapes me.
Shouldn't that be "Escapes me." ?
porter
Unread postby porter » Tue Nov 19, 2013 12:07 pm
Are you quoting me out of context?
Voralyan
Unread postby Voralyan » Sun Nov 24, 2013 3:31 am
It's right, works only in batch files.
Have been working with WinNT's too long I think...
