Tux that overload IRIX...
sum][one
Unread postby sum][one » Thu Mar 16, 2006 12:17 pm
It just happened here something strange which hanged connections to my O2...
trying to delete few files via samba share from the O2 ... I know this might not be the best way .. but i did for long time with Windows XP to "organize" my O2 stuffs... using samba shares.
anyway to make story short I'm now experimenting Suse10 on my laptop since I want to get rid of Windows and I was browsing such O2 samba shares as I did before on Win, then i tried to delete a number of directories, let's say around 50, containing 60 files each ... it started to delete the files/directory but few seconds after i had an error and after that i wasnt able to connect on the O2 via telnet,ssh,samba for few minutes...
and here's an output error when trying to telnet the O2:
jclaude@hellboy:~> telnet alien
Trying 192.168.1.3...
Connected to alien.
Escape character is '^]'.
IRIX (alien.mim)
PANIC pt_bootstrap() Couldn't create pt_table - {0x0, 0x0}
Connection closed by foreign host.
jclaude@hellboy:~>
anyone ever experienced this?
maybe ther's something to trick about network config which allows more "bandwidth" or dunno... to avoid the overload above.
cheers
:: jean-claude
:: mimgfx dot com
sum][one
Unread postby sum][one » Fri Mar 17, 2006 12:03 pm
.... nobody ever had that problem?... hm...
:: jean-claude
:: mimgfx dot com
Bluefan
Re: Tux that overload IRIX...
Unread postby Bluefan » Mon Dec 22, 2008 1:05 pm
I'm currently in the same thing, ftp, ssh and telnet seem to refuse connections, but once I got the same error message before I got disconnected:
johan@bluefan:~> telnet bluefan.nl
Trying 192.168.1.203...
Connected to bluefan.nl.
IRIX (Toika)
johan@bluefan:~>
NFS and apache are still running, although apache isn't going fine. I'm trying to figure this one out...
The bootstrap() error comes each time I try a telnet connection. Apache gives errors like this:
Warning: exec() [function.exec]: Unable to fork [uname -a] in /usr/......(long path)
:O2:Toika :O2:Myra :O2:Fiona :Octane:Lisa :Octane:Sandra :Indigo2:Danica :Indy:Giana :O200:Lara :O200: :O200:Iona :O2000:Aida
porter
Unread postby porter » Mon Dec 22, 2008 1:13 pm
I think this is an application/pthreads issue.
http://www.mail-archive.com/php-bugs@lists.php.net/msg41528.html
