Freebirth
Shtoink
Freebirth
Unread postby Shtoink » Sat Feb 08, 2003 10:55 pm
Anyone else gotten that tardist of Freebirth to work yet?
Ii installed just fine, but when I try to start it up it thows up errors about raw/kick.wave not being found. Maybe it's got to do with how the guy that compiled it had his settings, but it shouldn't matter should it?
Re: Freebirth
Unread postby nekonoko » Sat Feb 08, 2003 11:06 pm
I hadn't tried it before you said something but yeah, same message here. My guess is that he left out a few files when building the tardist ... looks like the only file in the thing is the binary (/usr/local/bin/freebirth).
Shtoink
Unread postby Shtoink » Sat Feb 08, 2003 11:25 pm
Yup.
There are 5 wave files missing. I got it to start in a roud about ghetto way, I found one wav file, renamed it, and kept copying the file and renaming it as I ran in to the errors. I did get it to start up and make a bunch of crappy noise, but that was related to the random wave file. Now i just need to find a way to edit the files that it's gonna be using and such.
Off to find som einfo on that... or some sounds similar to what it should actually be using.
Unread postby nekonoko » Sat Feb 08, 2003 11:39 pm
http://ftp.mayn.de/pub/irix/sound/FreeBirth-0.3.1_IRIX_N32_mips3.tar.gz
I dropped Tom a note as well, but the archive above works too.
Shtoink
Unread postby Shtoink » Sun Feb 09, 2003 1:25 pm
I did find a way to get arround that particualr problem I was having...
I went to a site that had some TB808 drum sounds and grabbed a few wav's and renamed the ones that I wanted to use. It fired up and worked great! I was getting into in it mixin some fatty beats and then it up and died on me. I think that I fiddled with a few too many knobs and dials so it crapped out.
