GQmpeg-0.20.0 Tardist Available
Unread postby nekonoko » Sat Feb 08, 2003 10:17 pm
Figured I'd throw it out here ... I made a new tardist for GQmpeg-0.20.0 this evening.
You can get it here: http://www.nekochan.net/downloads/gqmpeg-0.20.0.tardist
If you have my old gqmpeg-0.19.0 tardist installed this will upgrade it.
Enjoy!
ph0enix
Unread postby ph0enix » Sun Feb 09, 2003 1:52 am
Installed and works fine for me... Even the pathetic error messages are gone... :)
Shtoink
Unread postby Shtoink » Sun Feb 09, 2003 1:27 pm
I'll have to give it a shot...
*UPDATE*
I am glad this you put this at the time you did... XMMS just started ore dumping on me for no appearent reason. I tried doing a few things to get it going but all I ever got was a message from the console telling me A segmentation fault happened and that it looks like I found a bug.
YAY me! I found a bug! :D
So I just removed it an instaled Gqmpeg. I dig the skinning of it and such and it uses about 4 to 5 MB less memory than XMMS. I still miss XMMS though, no idea why it just stopped working all of the sudden. I hadn't done anything new to my machine ebsides edit a few things in my custom toolchest menu...
*UPDATE*
I found out why xmms up and died on me all of the sudden...
It turns out that the process had been running for over a week and I was messing around with some configs for other stuff a while back and had unstalled new crap. When I killed the process, it found that it's environment had been atered and it didten't like it. To fix the problem I just removed the .xmms folder from my home directory and started over. I felt like a duffus.
rama
Unread postby rama » Wed Mar 12, 2003 11:27 am
I can't seem to get the gqmpeg application to work?
I installed using the Software Manager, but then when I double click on the gqmpeg file under /usr/local/bin/gqmpeg nothing seems to happen.
I do have mpeg123 installed. Any ideas?
System:
O2
Irix 6.5.10f
rama
Unread postby nekonoko » Wed Mar 12, 2003 11:53 am
rama wrote:I can't seem to get the gqmpeg application to work?
System:
O2
Irix 6.5.10f
rama
As it is a Gnome app, GQmpeg requires:
gtk
gdk-pixbuf
libpng
mpg123
ogg-vorbis
all of which are available from the SGI Freeware site.
You can see which libraries are failing by running it from the command line and then note the error message(s).
More info here: http://www.nekochan.net/wiki/weblog/archives/000043.html
lisp
Unread postby lisp » Thu Mar 13, 2003 7:03 am
The general route to fixing an xmms that segfaults on startup is to delete the .xmms directory in your home directory.
lisa
