BitchX envirnmnt variables!!
FoSi
Unread postby FoSi » Fri Feb 07, 2003 6:35 am
Hi all...
ive installed BX under my O2 box... but now i want to add some env var. but i dont know how to set they!
variables such as:
SETNICK="**"
SETNAME="**"
i did @shell: set variable=value
is this the right way? i dont think so... couse im getting no result at all...
could some1 please helpme?
im new with this..
thanks
:D
vegac
Unread postby vegac » Fri Feb 07, 2003 7:20 am
that totally depends on your shell...
if it's csh or tcsh or something of that like, you do
setenv variable value
if it's bash or something of that like, you do
export variable="value"
if you just do set variable=value
it sets the variable locally in the shell, but DOESN'T make it an environment variable (except in bash you can then "export variable" and have it become an environment variable)
FoSi
Unread postby FoSi » Fri Feb 07, 2003 7:27 am
thank u very much...
i will setup it right away...
FoSi
Unread postby FoSi » Fri Feb 07, 2003 7:48 am
damn...
i did the "setenv var=value" thru telnet with root previleges, but when i restarted the system, the variables wernt there anymore!
so i opened a winterm on sgi... then i did it, and it was there when i make env command.. but when i restart.. theres nothing there!
btw... it appears like that:
SETNICK=some NICK=
SETUSER=some USER=
why = appears at the end?
thanks
Unread postby nekonoko » Fri Feb 07, 2003 1:17 pm
FoSi wrote:damn...
Environment variables are not preserved between system restarts (or even different shell instances). You would need to add these environment variables to your shell's initialization file (for example .cshrc for tcsh/csh or .profile for bash).
FoSi wrote:btw... it appears like that:
SETNICK=some NICK=
SETUSER=some USER=
It's there because you specified it. The correct syntax is:
setenv var value
not
setenv var=value
FoSi
Unread postby FoSi » Fri Feb 07, 2003 1:41 pm
8)
ok...
maybe is that! i really dont know if this will work w/ BitchX! i would love to compile it on my machine... but i dont have the mips assembler "as"
:x :? :(
thanks for the support...
vegac
Unread postby vegac » Fri Feb 07, 2003 1:57 pm
If you just want those set for when you run bitchx, I'd recommend either a shell script, or for your nick, just specify it in the command line:
BitchX mynick my.fav.irc.server
or "SETUSER=myuser SETNICK=mynick BitchX"
should also work
Shtoink
Unread postby Shtoink » Fri Feb 07, 2003 11:08 pm
You wouldn't happen to be THE FOSI would you?
If you are, it's an honor to meet you... :wink:
Unread postby nekonoko » Sat Feb 08, 2003 3:57 am
FoSi wrote:maybe is that! i really dont know if this will work w/ BitchX! i would love to compile it on my machine...
Here you go: http://www.nekochan.net/downloads/BitchX-1.0c19.tardist
Have fun!
