OpenSSH on an Indigo
Nihilus
Unread postby Nihilus » Sun Dec 19, 2004 8:27 pm
Installed Irix 6.5.22m and I wanted it to run along with ssh but the ssh-keygen takes hours for generating the RSA1-key, what's wrong? Any suggestions or work-arounds?
TeeTylerToe
Unread postby TeeTylerToe » Sun Dec 19, 2004 11:14 pm
the problem, is that you're running crypto on a slow RISC processor, in other words, everything's working fine, but these are the things you get with trying 128 bit encryption on a computer from 1991.
Unread postby dexter1 » Sun Dec 19, 2004 11:25 pm
Wrong
The R4000 rev 2.2 CPU on the Indigo has some serious bugs, which OpenSSH/OpenSSL stumbles on when creating the various RSA/DSA keys.
Did you try to compile OpenSSH/OpenSSL yourself? If so recompile without asm support. That should solve it.
Nihilus
Unread postby Nihilus » Sun Dec 19, 2004 11:52 pm
I discovered that fw_openssh (3.7) worked like a charm but openssh in Irix overlays (3.6) was the buggy one.
And yeah... The RSA/DSA-algorithms aren't that difficult to generate keypairs for :P
Unread postby dexter1 » Mon Dec 20, 2004 1:21 am
Nihilus wrote:I discovered that fw_openssh (3.7) worked like a charm but openssh in Irix overlays (3.6) was the buggy one.
That is some serious bug from the SGI folks. I believe you can download patches for openssh for that version, but it's extremely sloppy for SGI to forget that flag when building it into IRIX 6.5.22m
Nihilus
Unread postby Nihilus » Mon Dec 20, 2004 9:31 am
Hmmm, nothing in the supportportfolio :-/ But I guess I'll do fine with the freeware version alas it's not the way it ought to be :-/
Re: OpenSSH on an Indigo
Unread postby dexter1 » Fri Aug 12, 2016 10:34 am
12 years later and i have come across this exact same bug when i revived my ol'e dirty R4000 Indigo today. Guess i'm getting old since i knew this a looong time ago :)
In the closet for 13 years, fixed clock battery, unstuck both drives by shaking them a bit and we are off. Or that is what i hoped for when it hung itself while generating ssh-keys. Back to miniroot and removed openssh.sw subsystem.
So, did anyone find a patch for this 6.5.22m openssh 3.6 ? Nothing in my 6.5.22 patch directory which hints at a solution.
Because this being the last version with mips3 support, i will no get my hopes up and start refreshing openssh/openssl on nekoware with both mips3 and mips4 binaries, and get the freeware version in the meantime
Users browsing this forum: Ahrefs [Bot] and 4 guests
