Nekoware aterm error
Dean
Unread postby Dean » Fri Dec 10, 2004 2:19 am
1160:/usr/nekoware/bin/aterm: rld: Error: unresolvable symbol in /usr/nekoware/bin/aterm: __libc_attr
1160:/usr/nekoware/bin/aterm: rld: Fatal Error: this executable has unresolvable symbols
this is what i get when i try to execute aterm.
any clues?
anyone?
i want my transparent terminal dammit!!
Brombear
Unread postby Brombear » Fri Dec 10, 2004 2:33 am
Hi,
if you use the search and type in the missing symbol from the error message you will be guided to the explanation what goes wrong and how it could be resolved.
Good luck
Matthias
Re: Nekoware aterm error
Unread postby foetz » Fri Dec 10, 2004 2:47 am
Dean wrote:1160:/usr/nekoware/bin/aterm: rld: Error: unresolvable symbol in /usr/nekoware/bin/aterm: __libc_attr
any clues?
anyone?
you're running something below 6.5.22? right?
upgrade! :P
Dean
Unread postby Dean » Fri Dec 10, 2004 3:55 am
so the question now becomes: how do you get the same result, in irix 6.3 :roll:
Unread postby dexter1 » Fri Dec 10, 2004 4:03 am
May i ask what IRIX version you are running? (hint: 'uname -aR') Is it 6.3?
Nekoware only runs from 6.5.21 onwards or 6.5.20 with workarounds. Period. If you are running an IRIX less than 6.5.20, nekoware will not work. Upgrade!
Hakimoto
Unread postby Hakimoto » Fri Dec 10, 2004 9:37 am
I run 6.5.25, 24bit visuals and I still can't get my aterm to do transparency properly. :P
grace, elegance and style.
squeen
Unread postby squeen » Fri Dec 10, 2004 9:54 am
Hakimoto:
1) use neko_aterm
2) .Xdefaults:
Aterm*transparent: True
Aterm*font: -*-screen-medium-r-normal--11-*-*-*-m-70-iso8859-1
Aterm*boldFont: -*-screen-medium-r-normal--11-*-*-*-m-70-iso8859-1
Aterm*saveLines: 1500
!Aterm*termName: aterm
Aterm*cursorColor: green
Aterm*cursorColor2: green
Aterm*geometry: 80x40
Aterm*fading: 82
Aterm*colorBD: green
Aterm*colorUL: green
Aterm*tintingType: true
Aterm*pointerColor: lightblue
! *** winterm colors***
Aterm*shading: 250
Aterm*tinting: #00003f
Aterm*foreground: #d6d6d6
Aterm*background: #00003f
Dean
Unread postby Dean » Fri Dec 10, 2004 11:14 am
I guess i have to look into upgrading.
got it.
Hakimoto
Unread postby Hakimoto » Fri Dec 10, 2004 12:16 pm
squeen, thanks for the xdefaults. I am using neko_aterm. These days I'm pretty much using only neko_stuff.
Users browsing this forum: Semrush [Bot] and 4 guests
