gAIM defeats me
themacosxflies
gAIM defeats me
Unread postby themacosxflies » Tue Nov 23, 2004 7:00 am
Hi all,
I had downloaded a couple of gAIM version to let me keep in contact with my buddies since my PowerBook is on repair, but I was not able to get it working.
I got this message:
1870:gaim: rld: Fatal Error: Cannot Successfully map soname 'libgtk-x11-2.0.so.1' under any of the filenames
/usr/freeware/lib32/libgtk-x11-2.0.so.1:/usr/freeware/gaim-0.75/lib/libgtk-x11-2.0.so.1
:/usr/lib32/libgtk-x11-2.0.so.1:/usr/lib32/internal/libgtk-x11-2.0.so.1
:/usr/Softimage/Soft3D_3.9.2/3D/dso/libgtk-x11-2.0.so.1
:/usr/Softimage/Soft3D_3.9.2/3D/custom/bin/libgtk-x11-2.0.so.1
:/usr/Softimage/Soft3D_3.9.2/3D/custom/dso/libgtk-x11-2.0.so.1
:/usr/Softimage/Soft3D_3.9.2/Particle/dso/libgtk-x11-2.0.so.1
:/usr/Softimage/Soft3D_3.9.2/3D/dso/softGraphicOGL/libgtk-x11-2.0.so.1
:/usr/lib/libgtk-x11-2.0.so.1:/usr/lib/internal/libgtk-x11-2.0.so.1:/lib/libgtk-x11-2.0.so.1
:/usr/java/lib/libgtk-x11-2.0.so.1:/usr/local/lib/libgtk-x11-2.0.so.1
:/usr/freeware/lib/libgtk-x11-2.0.so.1:/lib32/libgtk-x11-2.0.so.1:/opt/lib32/libgtk-x11-2.0.so.1
:/usr/freeware/lib32/libgtk-x11-2.0.so.1.1:/usr/freeware/gaim-0.75/lib/libgtk-x11-2.0.so.1.1
:/usr/lib32/libgtk-x11-2.0.so.1.1:/usr/lib32/internal/libgtk-x11-2.0.so.1.1
:/usr/Softimage/Soft3D_3.9.2/3D/dso/libgtk-x11-2.0.so.1.1
:/usr/Softimage/Soft3D_3.9.2/3D/custom/bin/libgtk-x11-2.0.so.1.1
:/usr/Softimage/Soft3D_3.9.2/3D/custom/dso/libgtk-x11-2.0.so.1.1
:/usr/Softimage/Soft3D_3.9.2/Particle/dso/libgtk-x11-2.0.so.1.1
:/usr/Softimage/Soft3D_3.9.2/3D/dso/softGraphicOGL/libgtk-x11-2.0.so.1.1
:/usr/lib/libgtk-x11-2.0.so.1.1:/usr/lib/internal/libgtk-x11-2.0.so.1.1:/lib/libgtk-x11-2.0.so.1.1
:/usr/java/lib/libgtk-x11-2.0.so.1.1:/usr/local/lib/libgtk-x11-2.0.so.1.1
:/usr/freeware/lib/libgtk-x11-2.0.so.1.1:/lib32/libgtk-x11-2.0.so.1.1:/opt/lib32/libgtk-x11-2.0.so.1.1:
since it was a tardist file, what could be wrong?
thanks.
We are here on Earth to do good to others. What the others are here for, I don't know.
_SmUrf_
Unread postby _SmUrf_ » Tue Nov 23, 2004 7:38 am
check if you have GTK 2.0 installed :D
Revlef
Unread postby Revlef » Tue Nov 23, 2004 8:03 am
Hi,
and did you use the fixed version of wilhelm ?
this version works for me but i had to install the freeware dependancies
http://www.nekochan.net/wiki/downloads/index ... 2Fwilhelm/
good luck.
regards, revlef
themacosxflies
Unread postby themacosxflies » Tue Nov 23, 2004 9:43 am
_SmUrf_ wrote:check if you have GTK 2.0 installed :D
that smile denotes GTK is mandatory and I must have know about it, right? :D
where could I get it?
thanks :wink:
themacosxflies
Unread postby themacosxflies » Tue Nov 23, 2004 9:45 am
Revlef wrote:Hi,
good luck.
regards, revlef
Yes, I did it, but I can not remember it asking me about those dependancies...
Thank you very much.
_SmUrf_
Unread postby _SmUrf_ » Tue Nov 23, 2004 3:40 pm
thanks :wink:
I saw it in foetz directory on neko's downloads
http://www.nekochan.net/wiki/downloads/contr ... 40.tardist
and GTK 2 is also available on sgi freewares:
http://freeware.sgi.com/Dist/fw_gtk2+-2.4.0.tardist
I dunno what kind of hardware you're using but I would highly recommend
the gtk 1.2 version of Gaim since GTk 2.0 is incredibly slow and has a lot of deps
here's GTk1.2
http://freeware.sgi.com/Dist/fw_gtk+-1. ... l1.tardist
and the version of gaim for gtk1.2:
http://www.nekochan.net/wiki/downloads/contr ... 74.tardist
I used that smiley because I was happy when I posted the message :D,
GTK is not mandatory but lot's of linux stuff like sylpheed(mail), ethereal (network), mozilla,... uses GTK 1.2
check here
to have a more complete list
Unread postby nekonoko » Tue Nov 23, 2004 5:02 pm
themacosxflies wrote:Yes, I did it, but I can not remember it asking me about those dependancies...
That's one of the risks you take when using packages from the "contrib" directory and the main reason I don't lump everything in one big download directory. Just because it's a tardist doesn't mean the packager put the prereq checking in - the only tardists that will have that *guaranteed* are those in Nekoware and SGI Freeware.
Now I'm not saying don't use the contrib packages - they can be useful - just setting some expectations in regards to tardist features :)
That said, any reason you're not using Nekoware Gaim?
GeneratriX
GeneratrixWare
Unread postby GeneratriX » Tue Nov 23, 2004 6:51 pm
nekonoko wrote:Just because it's a tardist doesn't mean the packager put the prereq checking in - the only tardists that will have that *guaranteed* are those in Nekoware and SGI Freeware.
Add "GeneratrixWare" Neko! :lol:
My tardist releases are all having full prereq cheking!
Cheers! ;)
themacosxflies
Unread postby themacosxflies » Wed Nov 24, 2004 3:25 am
here's GTk1.2
OK, I donwloaded and installed both but the console message remains here annoying me :?
_SmUrf_ wrote:I used that smiley because I was happy when I posted the message :D,
Cool :)
themacosxflies
Unread postby themacosxflies » Wed Nov 24, 2004 3:26 am
Oh, but then, those I have downloaded are not Nekoware ? :oops:
Hakimoto
Unread postby Hakimoto » Wed Nov 24, 2004 7:50 am
Angel, uninstall all the gaim stuff you've installed so far. Then grab this:
http://www.nekochan.net/downloads/Nekoware/beta/neko_gaim-1.0.0.tardist
That will do the trick. Make sure you fulfil its dependecies and you're set to go.
If problems still persist, let us know what your LD_LIBRARY_PATH is.
grace, elegance and style.
themacosxflies
Unread postby themacosxflies » Wed Nov 24, 2004 9:16 am
Hakimoto wrote:Angel, uninstall all the gaim stuff you've installed so far. Then grab this:
Thanks Hakimoto,
Software Manager found 2 conflicts, seems that I lack:
neko_gaim.sw.lib
and
neko_gaim.sw.eoe
so far I choose to 'also install neko...' but I would like to know where get them.
Thanks again.
Hakimoto
Unread postby Hakimoto » Wed Nov 24, 2004 10:02 am
Angel, that is odd. Those subsystems are part of the tardist. Make sure that all subsystems have ticks in the boxes for them... this shouldn't happen...
joerg
Unread postby joerg » Fri Nov 26, 2004 7:48 am
Thanks Hakimoto,
neko_gaim.sw.lib
and
neko_gaim.sw.eoe
Thanks again.
The gaim tardist for the nekoware distribution is packaged by me. I can say its compiling with the rpath and using all libs coming from neko.
# cd /usr/nekoware/bin/
# ldd gaim
        libgtk-x11-2.0.so.1  =>  /usr/nekoware/lib/libgtk-x11-2.0.so.1
        libgdk-x11-2.0.so.1  =>  /usr/nekoware/lib/libgdk-x11-2.0.so.1
        libatk-1.0.so.1  =>      /usr/nekoware/lib/libatk-1.0.so.1
        libgdk_pixbuf-2.0.so.1  =>       /usr/nekoware/lib/libgdk_pixbuf-2.0.so.1
        libpangoxft-1.0.so.1  =>         /usr/nekoware/lib/libpangoxft-1.0.so.1
        libpangox-1.0.so.1  =>   /usr/nekoware/lib/libpangox-1.0.so.1
        libpango-1.0.so.1  =>    /usr/nekoware/lib/libpango-1.0.so.1
        libgobject-2.0.so.1  =>  /usr/nekoware/lib/libgobject-2.0.so.1
        libgmodule-2.0.so.1  =>  /usr/nekoware/lib/libgmodule-2.0.so.1
        libglib-2.0.so.1  =>     /usr/nekoware/lib/libglib-2.0.so.1
        libao.so.3  =>   /usr/nekoware/lib/libao.so.3
        libdl.so  =>     /usr/lib32/libdl.so
        libaudiofile.so.1  =>    /usr/nekoware/lib/libaudiofile.so.1
        libintl.so.4  =>         /usr/nekoware/lib/libintl.so.4
        libiconv.so.3  =>        /usr/nekoware/lib/libiconv.so.3
        libnsl.so  =>    /usr/lib32/libnsl.so
        libXft.so.2  =>  /usr/nekoware/lib/libXft.so.2
        libfreetype.so.7  =>     /usr/nekoware/lib/libfreetype.so.7
        libz.so  =>      /usr/nekoware/lib/libz.so
        libXrender.so.1  =>      /usr/nekoware/lib/libXrender.so.1
        libfontconfig.so.2  =>   /usr/nekoware/lib/libfontconfig.so.2
        libpangoft2-1.0.so.1  =>         /usr/nekoware/lib/libpangoft2-1.0.so.1
        libexpat.so.1  =>        /usr/nekoware/lib/libexpat.so.1
# versions -n | grep gaim
I  neko_gaim                     1  gaim-0.82.1 multi-protocol instant messaging
I  neko_gaim.man                 1  Man Pages
I  neko_gaim.man.manpages           1  Man Pages
I  neko_gaim.sw                  1  Software
I  neko_gaim.sw.eoe              1  execution only env
I  neko_gaim.sw.hdr              1  header files
I  neko_gaim.sw.lib              1  shared libraries
I  neko_gaim                     2  gaim-1.0.0 multi-protocol instant messaging
I  neko_gaim.man                 2  Man Pages
I  neko_gaim.man.manpages           2  man Pages
I  neko_gaim.opt                 2  optional software
I  neko_gaim.opt.dist            2  distribution files
I  neko_gaim.opt.relnotes           2  release notes
I  neko_gaim.opt.src             2  original source code
I  neko_gaim.sw                  2  Software
I  neko_gaim.sw.eoe              2  execution only env
I  neko_gaim.sw.hdr              2  header files
I  neko_gaim.sw.lib              2  shared libraries
# cat /usr/nekoware/dist/neko_gaim.spec
product neko_gaim
    id "gaim-1.0.0 multi-protocol instant messaging"
    image sw
        id "Software"
        version 2
        order 9999
        subsys eoe default
            id "execution only env"
            replaces self
            prereq (
                neko_gaim.sw.lib 2 maxint
                neko_gtk.sw.lib 2 maxint
                neko_atk.sw.lib 2 maxint
                neko_pango.sw.lib 2 maxint
                neko_glib.sw.lib 2 maxint
                neko_libao.sw.lib 1 maxint
                neko_libaudiofile.sw.lib 1 maxint
                neko_gettext.sw.lib 2 maxint
                neko_libiconv.sw.lib 2 maxint
                neko_libxft.sw.lib 1 maxint
                neko_freetype2.sw.lib 2 maxint
                neko_zlib.sw.lib 2 maxint
                neko_libxrender.sw.lib 2 maxint
                neko_fontconfig.sw.lib 2 maxint
                neko_expat.sw.lib 2 maxint
            exp neko_gaim.sw.eoe
You cant install Gaim eoe without the neko_gaim.sw.lib. I have installed it 5min. ago without any kind of problem.
regards
Joerg
themacosxflies
Unread postby themacosxflies » Thu Dec 02, 2004 11:27 am
OK, gaim is running, was a matter of get new IRIX overlays, thanks all
