JRE1.3
Spidy
JRE1.3
Unread postby Spidy » Mon Mar 24, 2003 3:15 pm
Does anyone know if JRE 1.3 with JAVA 2 support is available for IRIX?
Re: JRE1.3
Unread postby nekonoko » Mon Mar 24, 2003 3:19 pm
Do you need JRE 1.3 is or is 1.3.1 okay?
Download links for 1.4.1 beta and 1.3.1 release:
http://www.sgi.com/developers/devtools/ ... /java.html
Spidy
Unread postby Spidy » Mon Mar 24, 2003 3:28 pm
Wow, that was quick, thanks. :D
Downloading 1.4 now......
Spidy
Unread postby Spidy » Mon Mar 24, 2003 6:12 pm
Bummer!
Just installed Java2 (JRE1.4) but still get the "INSTALL PLUGIN" message with Mozilla 1.3b.
So I take it there is no java2 plugin for Mozilla?
Spidy
Unread postby Spidy » Tue Mar 25, 2003 12:20 am
Disregard my last post. I jumped the gun.
I needed to upgrade to JRE 1.4.1 and also download the actual plugin version 1.4.1.
All is well now.:D
Unread postby nekonoko » Tue Mar 25, 2003 12:38 am
Ah cool ... I was just going to suggest grabbing 1.4.1 and the SGI-Java2v141-BETA-plugin.tardist :)
Spidy
Unread postby Spidy » Tue Mar 25, 2003 4:03 am
Let me thank you again mate and tell you just how much I appreciate your site.
Great IRIX advice.
Just set up a custom background as well!
Keep the tips flowing.
