Problem installing IRIX on my Tezro
Irinikus
Unread postby Irinikus » Tue Mar 20, 2018 7:26 pm
Today I decided to go ahead and do a fresh install of IRIX on my Tezro, and this is proving to be impossible to do!
What version of IRIX 6.5 is necessary, as the disk set that I have is from 2001 and I think this might be the problem?
Here are some screen shots of the process I followed:
When I get to this point, the prom reboots
Once the prom has rebooted, I get this screen:
Any help concerning this matter would be much appreciated
Image ... Image
Re: Problem installing IRIX on my Tezro
Unread postby robespierre » Tue Mar 20, 2018 7:54 pm
It may be nothing, but I am a little surprised to see "boot file dksc(0,1,8)/sash" with a slash. The volhdr has no directories and I just don't expect a slash there. Additionally, the location of the sash file during installation is supposed to be the CDROM, not the hard disk, so it should be looking in "dksc(0,4,8)sash64" or something like that.
Irinikus
Unread postby Irinikus » Tue Mar 20, 2018 10:18 pm
How do I change where the machine tries to boot from, bearing in mind that it copies the installation files to disk?
Image ... Image
Unread postby Trippynet » Wed Mar 21, 2018 1:06 am
Tezro support was added in IRIX 6.5.21 I believe, this was released in 2003. Hence if you're using an older 2001 CD set, this may be why it isn't working. You can get later IRIX CD images from the Internet Archive if you search for them (updated, don't think 6.5.30 is there).
Irinikus
Unread postby Irinikus » Wed Mar 21, 2018 1:42 am
Trippynet wrote:Tezro support was added in IRIX 6.5.21 I believe, this was released in 2003. Hence if you're using an older 2001 CD set, this may be why it isn't working. You can get IRIX 6.5.30 CD images from the Internet Archive if you search for them...
Thanks very much for the info. (Yet another problem to solve)
My copy of IRIX is 6.5.11 from 2001
Here's a shot of the system's environment variables, and from what I can tell, they seem to be correct.
This is an excuse for me to buy a properly pre-built 15K, IRIX 6.5.3 disk for the machine!
Reason: merged
Image ... Image
gocram
Unread postby gocram » Wed Mar 21, 2018 6:43 am
Why don't you try installing IRIX 6.5.22? A popular release, very stable and bloat-free (relatively speaking, of course), which also works on many older systems, and it was made freely available for download at SGI Supportfolio at some point. You should be able to find it archived across the internet.
LOOKING FOR:
ITEMS FOR SALE/TRADE
Unread postby Trippynet » Wed Mar 21, 2018 7:06 am
6.5.22 is available online if you search for it. I can't directly link to it here for obvious reasons, but seeing as it was made available on SupportFolio for free anyway, shouldn't be a problem to download it.
Irinikus
Unread postby Irinikus » Wed Mar 21, 2018 7:15 am
I'm after the extras that come with a pre-built disk! (it will make the machine far more interesting to play with)
Image ... Image
Unread postby foetz » Wed Mar 21, 2018 8:13 am
exactly. installing anything older will not work.
Irinikus
Unread postby Irinikus » Wed Mar 21, 2018 8:17 am
I suppose I should have done my research before trying to carry out a fresh install, but the flame installation which was on the disk was useless to me anyway!
I had carried out fresh installs on my other machines with the disk set, so I assumed it would work on the Tezro! (so you learn)
Image ... Image
Unread postby Trippynet » Wed Mar 21, 2018 8:29 am
Irinikus wrote:I'm after the extras that come with a pre-built disk! (it will make the machine far more interesting to play with)
Might want to speak to Ian for that. His IRIX HDDs are absolutely stuffed to the gills with bits and pieces. I use the pre-built disks for both my Indigo2 and Fuel, with a raw install of IRIX on my O2 for general experimenting.
Unread postby uunix » Wed Mar 21, 2018 8:30 am
Irinikus wrote:I suppose I should have done my research before trying to carry out a fresh install, but the flame installation which was on the disk was useless to me anyway!
Do you have the ability to do a network install chap?
Irinikus
Unread postby Irinikus » Wed Mar 21, 2018 9:07 am
I have already contacted him.
I don’t at the moment, the files are currently being downloaded.
Reason: merged
Image ... Image
JacquesT
Unread postby JacquesT » Wed Mar 21, 2018 12:13 pm
If you have a machine that can run Debian you can set up a linux install server.
:Octane: - 1xR12k 400Mhz, 1GB RAM, V8 GFX, 18Gb 10K & 36Gb 15K HDD, 6.5.30
:Octane: - 1xR12k 300Mhz, 384Mb RAM, SSE GFX, 18Gb 10K HDD, 6.5.30
:O2: - 300Mhz R5200, 384Mb RAM, 36Gb 15K RPM HDD, A/V Module, 4x CD-ROM, 6.5.30
Unread postby Trippynet » Thu Mar 22, 2018 1:50 am
I use Dina these days for IRIX installation. Runs nicely as a VM from my main PC, and as it already has the necessary shares etc. set up, it's a doddle to use.
