VFC compilation error
JacquesT
Unread postby JacquesT » Thu Dec 14, 2017 11:45 am
Whenever I try and and compile a VFO file from a VFS input file I always get a "Could not open <filename>.vfs for reading" where <filename> is my VFS file e.g. 1920x1080_60.vfs
This happens with a known 'good' VFS file as even the standard template files generate this error. The files have no specific permissions and are located in the directory the command is called from. Even direct referencing the file causes the same issue. Any ideas?
Re: VFC compilation error
Unread postby vishnu » Sun Dec 17, 2017 9:26 pm
recondas is our resident vfs/vfo guru, might want to PM him and ask if he could kindly take a look at this topic...
JacquesT
Unread postby JacquesT » Mon Dec 18, 2017 2:37 am
Hi, yeah sent him a pm few days ago. Not sure if he's seen it yet.
JacquesT
Unread postby JacquesT » Mon Dec 18, 2017 5:21 am
Ok, for some reason I can compile VPro board files but nothing else?
Unread postby vishnu » Mon Dec 18, 2017 1:57 pm
Presumably you've already seen the Michael Pastras pdf regarding this topic? viewtopic.php?f=3&t=16732152
JacquesT
Unread postby JacquesT » Mon Dec 18, 2017 2:16 pm
Yep, followed that religiously. I've also tried the mgras-vfc.sh scripts, while these compile they throw up more errors, but the are ignore errors and I do get a .vfo file. Xsetmon won't have anything to do with it though.
Even just trying to build a vfs specific 1280x1024_60 for my panel doesn't work. I'm going to move onto something else for a bit (setting up remote access for fresh install) as I'm at my whits end with vfc atm. Think I need a break and to come back with a fresh pair of eyes.
