Problems with network install of O2 using a Linux server
pettersson
Unread postby pettersson » Sun Jul 23, 2017 12:15 am
Hi,
long time since I got my O2 and since my last post. I finally got a HD for the machine and tried installing IRIX 6.5. Turns out, CD drive is broken, so I went with a network install but didn't get far. Managed to setup a tftp server on the Linux box (Ubuntu 16.04) using atftp. Connecting locally works, CDs are mounted. When trying to start the installation with
boot -f bootp()192.168.5.15:inst/stand/fx.ARCS --x
I can see tftp serving the data, but running into timeouts. After a while O2 gives me this message:
Unable to execute bootp()192.168.5.15:inst/stand/fx.ARCS: invalid argument
Unable to load bootp()192.168.5.15:inst/stand/fx.ARCS: ''bootp()192.168.5.15:inst/stand/fx.ARCS'' is not a valid file to boot
Anyone has an idea what is going wrong? Read about DINA, but could not find it anywhere
Regards and thans for any tips
pettersson
Re: Problems with network install of O2 using a Linux server
Unread postby dexter1 » Sun Jul 23, 2017 6:39 am
Dina is among other places over here
As for the tftpd problem, there can be a number of problems preventing you from booting programs for SGI machines.
I have a Ubuntu 16.04 install server myself, what packages are you using for
- rsh
- tftpd
also, what bootptab are you using?
I'm going to send you my IRIX install cookbook. It's a bit long, not well commented and you need to replace some paths because there are better guides out there, but this was enough to get me going:
frank@link:/IRIX/frank/irixinstall$ more proc.scr
echo 1 > /proc/sys/net/ipv4/ip_no_pmtu_disc
echo "2048 32767" > /proc/sys/net/ipv4/ip_local_port_range
frank@link:/IRIX/frank/irixinstall$ more cookbook.txt
install tftpd bootpd and rsh-redone-server
 .rhosts in guest and root with
iris root
/etc/hosts entries for iris
/etc/passwd replace shell with /bin/mksh
check /etc/pam.d/rsh
add rsh rshd to /etc/securetty
frank@link:/IRIX/frank/irixinstall$ more tftp
# default: off
# description: The tftp server serves files using the Trivial File Transfer \
#    Protocol.  The tftp protocol is often used to boot diskless \
#    workstations, download configuration files to network-aware printers, \
#    and to start the installation process for some operating systems.
service tftp
    socket_type     = dgram
    protocol        = udp
    wait            = yes
    user            = root
    server          = /usr/sbin/in.tftpd
    server_args     = -s /IRIX/DIST
    disable         = yes
frank@link:/IRIX/frank/irixinstall$ more ethers
080069xxxxxx iris
frank@link:/IRIX/frank/irixinstall$ more bootps
service bootps
    socket_type         = dgram
    protocol            = udp
    wait                = yes
    user                = root
    server              = /usr/sbin/bootpd
    server_args         = -i -t0 -d4 /etc/bootptab
    disable             = yes
frank@link:/IRIX/frank/irixinstall$ more rsh
service shell
    socket_type     = stream
    wait            = no
    user            = root
    log_on_success  += USERID
    log_on_failure  += USERID
    server          = /usr/sbin/in.rshd
    disable         = yes
frank@link:/IRIX/frank/irixinstall$ more bootptab
iris:ha=080069xxxxxx:sa=192.168.178.54:ds=192.168.178.54:rp=/IRIX/DIST
Note that i do not use the dhcpd service on Ubuntu, because i've experienced problems especially in bootp service.
Also check your stuff and try to 'tail -f' logs everywhere, you might see something popping up...
BTW, instead of DINA, this smells like an excellent service for a docker/LXC project!
pettersson
Unread postby pettersson » Sun Jul 23, 2017 8:11 am
Hi,
I think I am on step closer to get it working, now I get an bootp request, but it gets ignored. Request comes from correct IP
My bootptab looks like this:
sgio2:ha=08006905****:sa=192.168.5.18:ds=192.168.5.18:bf=/home/****/IRIX/6.5inst/dist/miniroot/unix.IP32
Regards
pettersson
Unread postby dexter1 » Sun Jul 23, 2017 8:37 am
You are using ip addresses for the install/bootp server in your bootp() command. I believe you should change that to the actual name of the server.
