New netboot utility - irixboot
halfmanhalftaco
Unread postby halfmanhalftaco » Tue Jun 06, 2017 7:40 am
Hey guys, thought I'd drop this here as some folks here may find it useful as an alternative to DINA - my IRIX netbooter called 'irixboot':
https://github.com/halfmanhalftaco/irixboot
It uses Virtualbox and Vagrant to launch a disposable VM for netbooting IRIX installs - including extracting EFS disc images according to a directory structure convention. I've used it to install IRIX versions 5.3 through 6.5.22 on my Indy and Indigo2, and other folks have reported it working on Indigos and Octanes. Probably any other machine that uses the same netboot process will also work.
It's not meant to be long-lived like a DINA VM, but it is quick and gets the job done for one-off OS installs.
It does pretty much everything I need it to do, but I'd welcome any suggestions/pull requests.
:Indy: :Indigo2: :Octane: :Octane: :Octane:
Indy XL24 R4600SC 133MHz | Indigo2 Extreme R4400 250MHz | Octane MXI 2xR12000 300MHz
2x Octane SE 2xR10000 195MHz
SPARCstation 20 SX 2x125MHz HyperSPARC | SPARCstation 20 TurboGX+ 2x60MHz SuperSPARC-II
SPARCstation IPC GX 25MHz SPARC | SPARCstation IPX GX 40MHz SPARC | SPARCclassic TurboGX 50MHz microSPARC
SPARCclassic X cg3 50MHz microSPARC | Sun Blade 100 Expert3D-Lite 500MHz UltraSPARC IIe
JavaStation-1 (Mr. Coffee) 110MHz microSPARC-IIe
https://halfmanhalftaco.com/inventory/
Re: New netboot utility - irixboot
Unread postby vishnu » Tue Jun 06, 2017 9:04 pm
Very nice, thanks for the effort! :)
