Midnight commander - F1-F10 keys
Unread postby Oxygen2 » Wed Apr 05, 2017 2:40 am
started mc in bash and found that issue - functional keys is not works. Also is there anything like gpm in linux to use mouse in mc? Thanks
God created the world. The rest made in china.
Image O2 R5K 512Mb RAM 73Gb Barco Chameleon neko
Image O2 R10K 1Gb RAM 73Gb Barco Chameleon AV1 tomcat
Image O2 R5K 256Mb RAM 73Gb kitty
Image Octane2 R10K 2x250Mhz 2Gb 73Gb MX grinch
Building Octane (65%): Case Octane, PSU Cherokee, XBow 1.4, Latest Mobo Octane2, Odyssey VPro V10
Re: Midnight commander - F1-F10 keys
Unread postby jan-jaap » Thu Apr 06, 2017 2:20 am
I think GPM is Linux-only, but try ESC-1 for F1 ... ESC-9 for F9, and ESC-0 for F10
NB: this also works on Linux, OS-X etc.
Unread postby kubatyszko » Mon Apr 10, 2017 10:06 am
Depending on terminal, ALT+key might also work, it's basically META+key and ALT+ or ESC+ are the same thing. IRIX accepts regular .Xdefaults for Xterm, might be doable.
