Mount SGI CDROM on Arch Linux
techgrrl
Unread postby techgrrl » Thu Mar 09, 2017 5:12 pm
I need a bit of help - and yes I've scoured the net for answers including the wiki here - but I'm hoping you guys would know or point me in the right direction.
I've an Octane2 with 'no' CDROM drive (external) - I'm trying to get some of my collection of SGI cdroms onto the Octane2 but can't find a viable way to transfer files - seems that 'mount' cannot recognize the file system type of any of the cdroms - short of finding an old working external scsi cdrom drive are there any accepted ways of reading SGI cdroms on non-sgi systems? Arch Linux in my case.
Thanks for any help!
Cheers,
Karyn
techgrrl - Image ImageImage ImageImage Image - button pusher, point'n'clicker, photon collector
Re: Mount SGI CDROM on Arch Linux
Unread postby Raion-Fox » Thu Mar 09, 2017 6:53 pm
You can't. Linux doesn't recognize EFS (the FS SGI images use).
Best get an external scsi cdrom or find someone with the IRIX cdroms in tar.gz format - obviously can't discuss that here though.
Unread postby robespierre » Thu Mar 09, 2017 7:37 pm
johnnym
Unread postby johnnym » Thu Mar 09, 2017 8:40 pm
techgrrl wrote:I've an Octane2 with 'no' CDROM drive (external) - I'm trying to get some of my collection of SGI cdroms onto the Octane2 but can't find a viable way to transfer files - seems that 'mount' cannot recognize the file system type of any of the cdroms - short of finding an old working external scsi cdrom drive are there any accepted ways of reading SGI cdroms on non-sgi systems? Arch Linux in my case.
I was successful with using the commands from the "Mounting IRIX CDs on Non-IRIX Systems" article on the Nekochan wiki on Ubuntu 12.04 and IIRC also on Ubuntu 14.04, specifically:
$ sudo mount -o ro,loop -t efs /dev/cdrom /mnt
$ ls -la /mnt
total 8
drwxrwxrwx  3 root   root  512 May 22  1998 .
drwxr-xr-x 24 root   root 4096 Mar  8 20:13 ..
drwxr-xr-x  2 root   root 1536 May 22  1998 dist
-rw-r--r--  1 nobody root    0 May 22  1998 .distribution
-rw-rw-rw-  1 root   root  185 May 22  1998 .IM
-rw-rw-rw-  1 root   root  185 May 22  1998 .IM_1401
-rw-r--r--  1 nobody root  753 May 22  1998 RELEASE.info
This might also work on Arch Linux, but as robespierre mentioned, you need EFS support.
techgrrl
Unread postby techgrrl » Fri Mar 10, 2017 4:17 am
Awesome! Will be giving this a try :)
robespierre wrote:https://www.aeschi.eu/efs/
techgrrl
Unread postby techgrrl » Fri Mar 10, 2017 4:18 am
Yeah - by default 'efs is not supported under Arch - thanks though.
Unread postby jan-jaap » Fri Mar 10, 2017 5:05 am
techgrrl wrote:Yeah - by default 'efs is not supported under Arch - thanks though.
That's the first time I heard that a distro came without EFS.
Debian stable here. Works like a charm and has done so for as long as I can remember. I keep images of all my IRIX CDs on my server:
root@tuxedo:/data/sgi/irix/cdrom/irix5.3# uname -a
Linux tuxedo 3.16.0-4-amd64 #1 SMP Debian 3.16.39-1+deb8u1 (2017-02-22) x86_64 GNU/Linux
root@tuxedo:/data/sgi/irix/cdrom/irix5.3# ls -l *.efs
-rw-r--r-- 1 root root 525074432 Nov 15  1994 812-0119-006_IRIX_5.3.efs
-rw-r--r-- 1 root root 530366464 Aug  5  1995 812-0119-008_IRIX_5.3_with_175Mhz_and_2MB_cache_support.efs
-rw-r--r-- 1 root root 607944704 Dec 21  1995 812-0119-010_IRIX_5.3_All_Indigo2_IMPACT.efs
-rw-r--r-- 1 root root 184467456 Dec 28  1994 812-0121-007_DIAGNOSTICS_5.3.efs
-rw-r--r-- 1 root root  23216128 Nov  9  1994 812-0127-004_Documenter's_Workbench_4.1.3.efs
-rw-r--r-- 1 root root  38125568 Nov 16  1994 812-0128-005_Network_File_System_5.3.efs
-rw-r--r-- 1 root root 334987264 Nov 14  1994 812-0129-005_IRIS_Development_Option_5.3.efs
-rw-r--r-- 1 root root  42483712 Nov 10  1994 812-0130-005_C++_Translator_4.0.efs
-rw-r--r-- 1 root root  25018368 Nov  8  1994 812-0131-005_Pascal_Compiler_1.4.4.efs
-rw-r--r-- 1 root root  24805376 Nov  9  1994 812-0218-005_4DDN_DECNet_Connectivity_4.1.efs
-rw-r--r-- 1 root root  65634304 Feb 28  1995 812-0241-003_European_Language_Module_1.3.efs
-rw-r--r-- 1 root root  25837568 Nov 11  1994 812-0274-004_Sirius_Video_1.1.efs
-rw-r--r-- 1 root root  51363840 Mar 13  1995 812-0288-003_MegaDev_3.0.efs
-rw-r--r-- 1 root root 536150016 Dec 21  1994 812-0323-001_IRIX_5.3_with_XFS.efs
-rw-r--r-- 1 root root 585859072 Dec 30  1994 812-0325-001_Varsity_5.3_Developer_Package_Update.efs
-rw-r--r-- 1 root root 525090816 Mar  1  1995 812-0336-001_IRIX_5.3_for_Indy_R4400_175MHz.efs
-rw-r--r-- 1 root root 527171584 Feb 10  1996 812-0336-004_IRIX_5.3_for_Indy_including_R5000.efs
-rw-r--r-- 1 root root 340770816 Aug 12  1995 812-0410-001_Desktop-Special_Edition_1.0.efs
-rw-r--r-- 1 root root 224493568 Dec 18  1995 812-0447-002_Impact_Demos_CD_for_5.3_Version_2.0.efs
-rw-r--r-- 1 root root  23494656 Nov 11  1995 812-0466-001_5.3_Patches_for_Indigo2_250MHz_R4400_1195.efs
root@tuxedo:/data/sgi/irix/cdrom/irix5.3# mount -o loop,ro -t efs 812-0119-006_IRIX_5.3.efs /cdimage
root@tuxedo:/data/sgi/irix/cdrom/irix5.3# df -t efs
Filesystem     1K-blocks   Used Available Use% Mounted on
/dev/loop0        478080 467879     10201  98% /cdimage
root@tuxedo:/data/sgi/irix/cdrom/irix5.3# ls -la /cdimage
total 24
drwxrwxrwx  8 root root  512 Nov 15  1994 .
drwxr-xr-x 24 root root   28 Jul  1  2016 ..
-r-xr-xr-x  1 root root  418 Nov 15  1994 CDgrelnotes
-rwxr-xr-x  1 root root 3658 Nov 15  1994 CDrelnotes
drwxrwxrwx  2 root root 4096 Nov 15  1994 dist
drwxrwxrwx  5 root root  512 Nov 15  1994 firmware
drwxrwxrwx  2 root root 1536 Nov 15  1994 help
drwxrwxrwx  3 root root  512 Nov 15  1994 insight
-rw-rw-rw-  1 root root 2365 Nov 15  1994 RELEASE.info
drwxrwxrwx 45 root root 1024 Nov 15  1994 relnotes
drwxrwxrwx  2 root root  512 Nov 15  1994 stand
Raion-Fox wrote:You can't. Linux doesn't recognize EFS (the FS SGI images use).
Right. :roll:
techgrrl
Unread postby techgrrl » Fri Mar 10, 2017 5:33 am
jan-jaap wrote:That's the first time I heard that a distro came without EFS.
Going to take my tub of CDs in to work today - barring that I'll spin up a VM and see if I can find one that will read them - I have a ton so it would be nice to check them out - I also have an Indigo2 eXtreme w/cdrom - but oh well - looks like I'm in the market for an external CDROM drive :)
Appreciate the post though :)
Karyn
Unread postby uunix » Fri Mar 10, 2017 5:55 am
techgrrl wrote: I also have an Indigo2 eXtreme w/cdrom - but oh well - looks like I'm in the market for an external CDROM drive :)Karyn
If you have an Indigo2 with CDROM, then why not share it over the network?
techgrrl
Unread postby techgrrl » Fri Mar 10, 2017 6:14 am
uunix wrote:If you have an Indigo2 with CDROM, then why not share it over the network?
I've not spun up the Indigo2 in years ... Weekend project :)
Unread postby uunix » Fri Mar 10, 2017 6:55 am
Would be much easier, but saying that, you may need one someday, so I should get one.
Unread postby Raion-Fox » Fri Mar 10, 2017 7:22 am
Ah, again I stand corrected. I didn't know EFS was supported on Linux, at least since the 2.4.x kernels.
