Using fsn on an Indigo2
itsvince725
Unread postby itsvince725 » Tue Mar 07, 2017 3:02 pm
Even though it's ridiculous and not particularly useful my endless love of Jurassic Park has me wanting to run fsn on my Indigo2. My question is: how much horsepower do I need to run it? I've got a 150MHz R4400, Newport graphics, and a currently unknown amount of RAM.
:Indigo2: :Indy:
Re: Using fsn on an Indigo2
Unread postby Raion-Fox » Tue Mar 07, 2017 3:42 pm
I used it on an Octane R10k 195MHz with MXE graphics and it was perfectly usable. You may have enough power to use it on there considering how well it runs on the Octane or not, it depends.
itsvince725
Unread postby itsvince725 » Tue Mar 07, 2017 4:13 pm
I've seen it run on an R10000 Indigo2 with Max IMPACT graphics but I don't know if it can run on anything lesser.
:Indigo2: :Indy:
Unread postby robespierre » Tue Mar 07, 2017 4:14 pm
As an IrisGL program without textures, it will run on just about anything.
Unread postby uunix » Tue Mar 07, 2017 5:38 pm
Brilliant program, I used it many years ago and it really is as slow and useless as it is in the film.
[Edit] Actually it was useful, it did enable them to lock the doors, although who in all of us would open up fsm as a first command on any unix system?
itsvince725
Unread postby itsvince725 » Tue Mar 07, 2017 6:03 pm
I mostly just want to do a video demonstrating it for friends and have an excuse to utter that infamous quote. :P
Great, I'll have to install it once the Indigo2 has its hard drive situation worked out.
:Indigo2: :Indy:
Krokodil
Unread postby Krokodil » Tue Mar 07, 2017 8:52 pm
uunix wrote: although who in all of us would open up fsm as a first command on any unix system?
Certainly not that person in the film. I can tell you that much.
Alphaserver DS10 - 466MHZ
Sun Ultra 5 - 440MHZ.
Unread postby Trippynet » Wed Mar 08, 2017 7:41 am
It's certainly worth trying. It runs OK on my Indigo2. I do have the R10000, but only SolidImpact graphics. But as robespierre says, it doesn't use texturing, so should run at least to a reasonable degree on your Indigo2!
jpstewart
Unread postby jpstewart » Wed Mar 08, 2017 8:00 am
For what it's worth, the README for fsn says:
Fsn requires Z-buffering and RGB support. You must be running IRIX release 4.0.1 or greater.
Those are some pretty low requirements. Later in the file, there's a warning that some things may not work so well on an Indigo. Your Indigo2 should be much more usable.
HP C8000
Digital DECstation 5000/125
Shiunbird
Unread postby Shiunbird » Wed Mar 08, 2017 11:42 am
uunix wrote:Brilliant program, I used it many years ago and it really is as slow and useless as it is in the film.
I'd go for some tcl stuff, like:
while {[gets $door_list door_number] >=0} {spawn "echo open > /dev/$door_number"}
Edit: forgot to close a quote.
:D
Unread postby ClassicHasClass » Thu Mar 09, 2017 9:47 pm
It runs fine on my Indy. I can't imagine your Indigo2 would run it any worse.
