Ruby
praetor242
Ruby
Unread postby praetor242 » Mon Feb 27, 2017 5:12 pm
I'm a Ruby developer and it would be kinda cool if I could do Ruby on my O2. Is there a port of it, or does it compile just fine using GCC, or is it no go?
I don't expect to run a rails app on IRIX, but just some gems and ruby scripts.
Re: Ruby
Unread postby Raion-Fox » Mon Feb 27, 2017 5:26 pm
It's been compiled. Ruby 1.8.4 to be exact.
praetor242
Re: Ruby
Unread postby praetor242 » Mon Feb 27, 2017 5:52 pm
Awesome! That makes me doubly excited! :D
necron2600
Re: Ruby
Unread postby necron2600 » Mon Feb 27, 2017 5:55 pm
I compiled ruby 2.0.. a bit more modern than 1.8.4:
viewtopic.php?f=15&t=16730169&p=7394935&hilit=ruby+2.0.0#p7394935
It works fine.. a lot of gems work great.. but a few specific ones that compile native extensions (nokogiri is one example) I could not get compiled. But if you work with pure ruby you should be ok... and many other native extensions do compile though.
In summary:
http://www.nekochan.net/downloads/necro ... .0.tardist
http://www.nekochan.net/downloads/necro ... .5.tardist
Over time.. a bug came out with remote install of gems. it is detailed in the link at the top.
In summary:
UPDATE/FIX for gem to install from rubygems.org due to an SSL issue
For the neko_ruby-2.0.0 installed package:
create a file:
/usr/nekoware/lib/ruby/site_ruby/2.0.0/rubygems/ssl_certs/GlobalSignRootCA.pem
with the following contents:
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
Should be good to go using gem install.
praetor242
Re: Ruby
Unread postby praetor242 » Mon Feb 27, 2017 6:11 pm
Thanks :D I bookmarked your post so I can try it
